BASIC
SKU:K001
Tutorial
This tutorial will show you how to control Basic devices through the UIFlow graphical programming platform
This tutorial will show you how to control the Basic device through the UIFlow2.0 graphical programming platform
This tutorial will show you how to program and control Basic devices through Arduino IDE
This tutorial will show you how to control Basic devices through Micropython programming
M5Stack BASIC Kit, like its namesake, is a starter kit among the M5Stack development kit series. It’s a modular, stackable, scalable, and portable device which is powered with an ESP-32 core, which makes it open source, low cost, full-function, and easy for developers to handle new product development on all stages including circuit design, PCB design, software, mold design and production. This Basic kit provides a friendly price and full-featured resources which makes it a good starter kit for you to explore IoT.
If you want to explore the fastest way of IoT prototyping, M5Stack development board is the perfect solution. Not like others, M5Stack development board is highly efficient, covered with industrial grade case and ESP32-based development board. It integrates with Wi-Fi modules and contains a dual-core and 16MB of SPI Flash . Together with 30+ M5Stack stackable modules , 40+ extendable units and different levels of program language, you can create and verify your IoT product in a very short time.
Supportive development platforms and programming languages: Arduino, Blockly language with UIFlow , Micropython. Regardless of what level programming skill you have, M5Stack would guide you in every step of the way to realize your idea as well as to the final productization. e If you ever played with ESP8266, you would realize that ESP32 is a perfect upgrade out of ESP8266. In comparison, ESP32 has more GPIOs, more analog inputs and two analog outputs, multiple extra peripherals( like a spare UART ). Official developing platform ESP-IDF has transplanted with FreeRTOS. With dual-core and real time OS you can get more organized code and much high speed processor.
M5Stack Basic is consist with two separable parts. The upside part has all kinds of processors, chips and some other slot components. The bottom part has a lithium battery, M-BUS socket and extendable pins on both sides.
Power on/off:
Power on: click the red power button on the left
Power off: Quickly double-click the red power button on the left
Note: By default, when USB is powered, it cannot be shut down
This product is EOL now.
Product Features
  • ESP32-based
  • Built-in Speaker, Buttons,Color LCD, Power/Reset button
  • TF card slot (16G Maximum size)
  • Magnetic suction at back
  • Extendable Pins & Holes
  • M-Bus Socket & Pins
  • Compatible with multi-platform development:
Include
  • 1x BASIC
  • 10x Dupont
  • 1x Type-C USB(20cm)
  • 1x User Manual
  • 1x Sticker
  • Internet of things terminal controller
  • Stem education product
  • DIY creation
  • Smart home equipment
Specification
Resources Parameter
ESP32-D0WDQ6-V3 240MHz dual core, 600 DMIPS, 520KB SRAM, Wi-Fi
Flash Memory 16MB
Power Input 5V @ 500mA
Port TypeC x 1, GROVE(I2C+I/0+UART) x 1
Core Bottom Port PIN (G1,G2,G3,G16, G17, G18, G19, G21, G22, G23, G25, G26, G35, G36)
IPS Screen 2 inch, 320x240 Colorful TFT LCD, ILI9342C, max brightness 853nit
Button Custom button x 3
Speaker 1W-0928
Battery 110mAh @ 3.7V
Antenna 2.4G 3D Antenna
Operating Temperature 0°C to 60°C
Net weight 47.2g
Gross weight 93g
Product Size 54 x 54 x 18mm
Package Size 95 x 65 x 25mm
Case Material Plastic ( PC )
Driver Installation
Click the link below to download the driver that matches the operating system. There are currently two driver chip versions (CP210X/CH9102). Please download the corresponding driver compressed package according to the version you are using. After decompressing the compressed package, select the installation package corresponding to the number of operating systems to install. (If you are not sure of the USB chip used by your device, you can install both drivers at the same time. During the installation process of CH9102_VCP_SER_MacOS v1.7, an error may occur, but the installation is actually completed, just ignore it.)
Driver name Applicable driver chip Download link
CP210x_VCP_Windows CP2104 Download
CP210x_VCP_MacOS CP2104 Download
CP210x_VCP_Linux CP2104 Download
EasyLoader
EasyLoader is a concise and fast program writer, which has a built-in case program related to the product. It can be burned to the main control by simple steps to perform a series of function verification.
Download Windows Version Easyloader Download MacOS Version Easyloader
Description:
This case will perform hardware running tests for speakers, wifi, buttons, accelerometer, TF-card(microSD), screen, etc.
PinMap
LCD & TF card
LCD :320x240 TF card Maximum size 16GB
ESP32 Chip GPIO23 GPIO19 GPIO18 GPIO14 GPIO27 GPIO33 GPIO32 GPIO4
ILI9342C MOSI/MISO / CLK CS DC RST BL
TF Card MOSI MISO CLK CS
Button & Speaker
ESP32 Chip GPIO39 GPIO38 GPIO37 GPIO25
Button Pin BUTTON A BUTTON B BUTTON C /
Speaker / / / DA PIN
GROVE Port A & IP5306
ESP32 Chip GPIO22 GPIO21 5V GND
GROVE A SCL SDA 5V GND
IP5306 SCL SDA 5V GND
IP5306 charging/discharging,Voltage parameter
charging discharging
0.00 ~ 3.40V -> 0% 4.20 ~ 4.07V -> 100%
3.40 ~ 3.61V -> 25% 4.07 ~ 3.81V -> 75%
3.61 ~ 3.88V -> 50% 3.81 ~ 3.55V -> 50%
3.88 ~ 4.12V -> 75% 3.55 ~ 3.33V -> 25%
4.12 ~ / -> 100% 3.33 ~ 0.00V -> 0%
M5PORT DEFINE
PORT PIN Note:
PORT-A(Red) G21/22 I2C
PORT-B(Black) G26/36 DAC/ADC
PORT-C(Blue) G16/17 UART
ESP32 ADC/DAC
ADC1 ADC2 DAC1 DAC2
8 channels 10 channels 2 channels 2 channels
G32-39 G0/2/4/12-15/25-27 G25 G26
M-BUS
M_BUS
Charging current measured value
charging current Fully charged current(Power OFF) Fully charged current(Power ON)
0.55A - 0.066A
For more information about Pin assignment and Pin Remapping, Please refer to ESP32 Datasheet
Schematic
Learn
It is a device that assists in verifying body temperature information so that people can meet with ease at the Corona disaster.
An attempt to create a realtime "Artificial Horizon" on the M5.
Brew your own beer in a fridge with M5Stack.
There are bound to be times when you need to add music or SFX to your M5Stack projects. Here's how to do so with MicroPython.
LoRaWAN module is supported by UIFlow!
A customizable ESP32-based touchscreen project to control MQTT switches or HomeKit accessories (through the Home App).
This is the clock developed to take away the viewer's time
Use MicroPython to connect your M5Stack to Wi-Fi or a device to AP and create a simple web page to control some functions of the M5Stack.
Tree style menu for M5Stack. Features SD updater, battery level indicator, on-screen keyboard, and more.
A simple, analog-style digital tester (voltage meter, DVM) created using the compact development module M5Stack.
Make cool App controllable projects with ease by combining M5Stack, Tuniot and MIT App inventor.
Use your M5Stack ESP32 Basic to receive little Logo programs via MQTT and show the results.
Out of the M5Stack family only the M5StickC has an inbuilt RTC. Here's how to add one to your other M5Stack devices
It is possible to turn a lamp or fan on and off through an SMS message.
#M5Stack 3.3V端子にEDLC付けといたらUSB挿抜してもリセット掛からないぜ…! (無理やり感)
Voice notifications have been added to the tool to automatically share the timeline to family members.
WebBluetooth経由でM5Stackに文字列送信してQRコード化、さらにそれをPWA製QRスキャナで読み取りできた! ここまでの処理が全部JavaScriptで書けるの最高では?
We developed a stereo web radio for the M5Stack with software, audio board, 3d printed enclosure and documentation.
We have programmed a game to give to children.
A technology which increases efficiency in signing in or out during peak hour areas when entering the campus while the SafeEntry implies.
This year's Christmas, I decorated the tree with M5Stack devices.
I tried to communicate with Unity-M5Stack via WebSocket. M5Stack is a gadget with a built-in ESP32 module that enables Wi-Fi commun
Scratch Cat want to catch Xmas gift. So you control giftbox for Scratch Cat!! This project use M5Stack and Scratch 1.4 with M5Scratch.
I was able to control the focus adjustment of the telescope mak127 sp by the stepping motor which connected to M5Stack.
The mechanism is simple to monitor the value of the water temperature sensor with the M5Stack, and heater power is controlled by the relay
TCS3472 color recognition module can distinguish different colors of objects, and map the colors to pitch through algorithm
Colorimeter/Color recognition/Color overlay
Tuner for an Ukulele/Guitar, made using a M5 Core + M5Go bottom
A Dji Tello Drone wifi controller based on M5Stack Core
Using M5Stack and Nodemcu with python to control Youtube vids remotely from a distance.
ReaMima, is the open and free hardware design so that anyone can help by building respirators with easily available materials.
The "Social Distancing LED" that alerts you when someone gets too close within 2m.
I used mqtt to control the switching of the scene of OBS moving on PC from other devices.
Realize the "offline cloud platform" interaction function of operation information based on mqtt information transmission technology
Technology to protect puddle pudding!
I checked whether Amazon FreeRTOS is the only candidate to use M5 Stack.
Thanks to @ghibi for providing material. This project will measure the power consumption of the Sigfox module (IFS-M01) with M5Stack.
M5Stack Multi-Tool has Distances measurement, Spirit level, Voltage sensor, Find my phone, Torch, Home automation controls
M5Stack works as a pc mouse with the help of pyautogui.
M5Stack robot car which we can control with mpu6050 module through Wi-Fi with NodeMCU
Thanks for the source code and project information provided by @沧海
On hand gesture, you can open the door without touching the handle M5STACK AND NODEMCU USED.
In this project, I'm using an ultrasonic sensor to measure distance and calculate the area of a circle and square and display it on screen
Measure the current value used by equipment using M5Stack and clamp type current sensor.
My family has eaten the pudding I have saved! Do you have such experience? I want to keep the peace of my home. I made pudding alert-V.
An expandable turntable created using M5Stack Products.
A library for MicroPython for drawing tiles and sprites on an RGB SPI screen.
M5Stack and Micro:bit can control each other, thanks to the M5:Bit
Tilt left and right to move the ball
Make a simple watch device using UIFlow.
This project is based on the use of the development system M5StickV, for the classification of emotions.
M5Stack ESP32 Basic Core based maker watch.
Using UIFlow and Blynk to complete the interaction experiment
Making a pulse oximeter with alert function based on M5Stack Basic and LPWA Network.
A inner maker competition of M5Stack.
Example
  • Click here to get Arduino code
Video
M5Stack Introduce
Version Change
Release Date Product Change Note:
2017.7 Initial public release /
2019.7 TN screen changed to IPS screen before use . pls upgrade your M5Stack lib to the latest version (after 0.2.8) to solve screen reverse color problem.
2020.3 Battery capacity changed from 150mAh to 110mAh /
2020.6 Flash size changed from 4MB to 16MB /
Note: 2018.2A PCB version of the device does not support C2C (TypeC to TypeC) connection and PD power supply.
