Input & Output Devices
Audio Playback Devices
Qwen2.5-1.5B
If git lfs is not installed, please refer to the git lfs installation guide to install it first.
git clone https://huggingface.co/AXERA-TECH/Qwen2.5-1.5B-Instruct-GPTQ-Int4
File Description
m5stack@raspberrypi:~/rsp/Qwen2.5-1.5B-Instruct-GPTQ-Int4$ ls -lh
total 2.9M
-rw-rw-r-- 1 m5stack m5stack    0 Aug 12 10:48 config.json
-rw-rw-r-- 1 m5stack m5stack 976K Aug 12 10:48 main_axcl_aarch64
-rw-rw-r-- 1 m5stack m5stack 999K Aug 12 10:48 main_axcl_x86
-rw-rw-r-- 1 m5stack m5stack 932K Aug 12 10:48 main_prefill
-rw-rw-r-- 1 m5stack m5stack  277 Aug 12 10:48 post_config.json
drwxrwxr-x 2 m5stack m5stack 4.0K Aug 12 10:49 qwen2.5-1.5b-gptq-int4-ax650
drwxrwxr-x 2 m5stack m5stack 4.0K Aug 12 10:48 qwen2.5_tokenizer
-rw-rw-r-- 1 m5stack m5stack 4.2K Aug 12 10:48 qwen2.5_tokenizer.py
-rw-rw-r-- 1 m5stack m5stack 6.8K Aug 12 10:48 README.md
-rw-rw-r-- 1 m5stack m5stack  521 Aug 12 10:48 run_qwen2.5_1.5b_gptq_int4_ax650.sh
-rw-rw-r-- 1 m5stack m5stack  526 Aug 12 10:48 run_qwen2.5_1.5b_gptq_int4_axcl_aarch64.sh
-rw-rw-r-- 1 m5stack m5stack  522 Aug 12 10:48 run_qwen2.5_1.5b_gptq_int4_axcl_x86.sh
If you have already created a qwen virtual environment before, you do not need to create it again, just activate it.
python -m venv qwen
source qwen/bin/activate
  1. Install dependency packages
  1. Start the tokenizer parser
python qwen2.5_tokenizer.py --port 12345
  1. Run the tokenizer service. The host IP defaults to localhost, and the port number is set to 12345. After running, the information is as follows:
(qwen) m5stack@raspberrypi:~/rsp/Qwen2.5-1.5B-Instruct-GPTQ-Int4 $ python qwen2.5_tokenizer.py --port 12345
None None 151645 <|im_end|>
<|im_start|>system
You are Qwen, created by Alibaba Cloud. You are a helpful assistant.<|im_end|>
<|im_start|>user
hello world<|im_end|>
<|im_start|>assistant
[151644, 8948, 198, 2610, 525, 1207, 16948, 11, 3465, 553, 54364, 14817, 13, 1446, 525, 264, 10950, 17847, 13, 151645, 198, 151644, 872, 198, 14990, 1879, 151645, 198, 151644, 77091, 198]
http://localhost:12345
The following operations require opening a new terminal for raspberrypi.
  1. Set executable permissions
chmod +x main_axcl_aarch64 run_qwen2.5_1.5b_gptq_int4_axcl_aarch64.sh
  1. Start the Qwen2.5 model inference service
./run_qwen2.5_1.5b_gptq_int4_axcl_aarch64.sh
After successfully starting, the information is as follows
m5stack@raspberrypi:~/rsp/Qwen2.5-1.5B-Instruct-GPTQ-Int4$ ./run_qwen2.5_1.5b_gptq_int4_axcl_aarch64.sh
bos_id: -1, eos_id: 151645
  3% | ██                                |   1 /  31 [0.00s<0.09s, 333.33 count/s] tokenizer init
  100% | ████████████████████████████████ |  31 /  31 [28.75s<28.75s, 1.08 count/s] init post axmodel ok
[I][                            Init][ 226]: max_token_len : 1024
[I][                            Init][ 231]: kv_cache_size : 256, kv_cache_num: 1024
    "enable_temperature": true,
    "penalty_window": 20,
    "repetition_penalty": 1.2,
    "temperature": 0.9,
    "top_k": 10,
    "top_p": 0.8
>> hello
[N][                             Run][ 610]: hit eos,avg 15.03 token/s
