Input & Output Devices
Audio Playback Devices
Qwen3-0.6B
Tip
If git lfs is not installed, please refer to the git lfs installation guide for installation.
git clone https://huggingface.co/AXERA-TECH/Qwen3-0.6B
File Description
m5stack@raspberrypi:~/Qwen3-0.6B $ ls -lh
total 4.4M
-rw-r--r-- 1 m5stack m5stack    0 Jul 25 15:48 config.json
-rw-r--r-- 1 m5stack m5stack 959K Jul 25 15:54 main_ax650
-rw-r--r-- 1 m5stack m5stack 1.7M Jul 25 15:54 main_axcl_aarch64
-rw-r--r-- 1 m5stack m5stack 1.8M Jul 25 15:54 main_axcl_x86
-rw-r--r-- 1 m5stack m5stack  277 Jul 25 15:47 post_config.json
drwxr-xr-x 2 m5stack m5stack 4.0K Jul 25 15:47 qwen2.5_tokenizer
drwxr-xr-x 2 m5stack m5stack 4.0K Jul 25 15:47 qwen3-0.6b-ax630c
drwxr-xr-x 2 m5stack m5stack 4.0K Jul 25 15:47 qwen3-0.6b-ax650
drwxr-xr-x 2 m5stack m5stack 4.0K Jul 25 15:47 qwen3_tokenizer
-rw-r--r-- 1 m5stack m5stack 7.6K Jul 25 15:47 qwen3_tokenizer_uid.py
-rw-r--r-- 1 m5stack m5stack  11K Jul 25 15:47 README.md
-rw-r--r-- 1 m5stack m5stack  577 Jul 25 15:47 run_qwen3_0.6b_int8_ctx_ax630c.sh
-rw-r--r-- 1 m5stack m5stack  574 Jul 25 15:47 run_qwen3_0.6b_int8_ctx_ax650.sh
-rw-r--r-- 1 m5stack m5stack  594 Jul 25 15:47 run_qwen3_0.6b_int8_ctx_axcl_aarch64.sh
-rw-r--r-- 1 m5stack m5stack  590 Jul 25 15:47 run_qwen3_0.6b_int8_ctx_axcl_x86.sh
python -m venv qwen
source qwen/bin/activate
  1. Install dependencies
  1. Start the tokenizer parser
python qwen3_tokenizer_uid.py --port 12345
  1. Run the tokenizer service. The Host IP is set to localhost by default, and the port number should be set to 12345. Once running, the information will be as follows:
(qwen) m5stack@raspberrypi:~/Qwen3-0.6B $ python qwen3_tokenizer_uid.py --port 12345
Tip
The following operations require opening a new terminal on the raspberrypi.
  1. Set executable permissions
chmod +x main_axcl_aarch64 run_qwen3_0.6b_int8_ctx_axcl_aarch64.sh
  1. Start the Qwen3 model inference service
./run_qwen3_0.6b_int8_ctx_axcl_aarch64.sh
Once started successfully, the information will be as follows:
m5stack@raspberrypi:~/rsp/Qwen3-0.6B$ ./run_qwen3_0.6b_int8_ctx_axcl_aarch64.sh
[I][                            Init][ 136]: LLM init start
[I][                            Init][  57]: uid: abf93a3d-2d6a-4ddb-8c9b-42a208a012f7
bos_id: -1, eos_id: 151645
  3% | ██                                |   1 /  31 [1.11s<34.47s, 0.90 count/s] tokenizer init ok[I][Init][  45]: LLaMaEmbedSelector use mmap
  6% | ███                               |   2 /  31 [1.11s<17.25s, 1.80 count/s] embed_selector init ok
  96% | ███████████████████████████████   |  30 /  31 [31.91s<32.98s, 0.94 count/s] init 27 axmodel
  100% | ████████████████████████████████ |  31 /  31 [36.09s<36.09s, 0.86 count/s] init post axmodel ok,remain_cmm(5068 MB)
[I][                            Init][ 237]: max_token_len : 2559
[I][                            Init][ 240]: kv_cache_size : 1024, kv_cache_num: 2559
[I][                            Init][ 248]: prefill_token_num : 128
[I][                            Init][ 252]: grp: 1, prefill_max_token_num : 1
[I][                            Init][ 252]: grp: 2, prefill_max_token_num : 512
[I][                            Init][ 252]: grp: 3, prefill_max_token_num : 1024
[I][                            Init][ 252]: grp: 4, prefill_max_token_num : 1536
[I][                            Init][ 252]: grp: 5, prefill_max_token_num : 2048
[I][                            Init][ 256]: prefill_max_token_num : 2048
________________________
|    ID| remain cmm(MB)|
|     0|           5068|
    "enable_temperature": false,
    "penalty_window": 20,
    "repetition_penalty": 1.2,
    "temperature": 0.9,
    "top_k": 1,
    "top_p": 0.8
[I][                            Init][ 279]: LLM init ok
[I][          GenerateKVCachePrefill][ 335]: input token num : 21, prefill_split_num : 1 prefill_grpid : 2
[I][          GenerateKVCachePrefill][ 372]: input_num_token:21
[I][                            main][ 236]: precompute_len: 21
[I][                            main][ 237]: system_prompt: You are Qwen, created by Alibaba Cloud. You are a helpful assistant.
prompt >> hello
[I][                      SetKVCache][ 628]: prefill_grpid:2 kv_cache_num:512 precompute_len:21 input_num_token:12
[I][                      SetKVCache][ 631]: current prefill_max_token_num:1920
[I][                             Run][ 869]: input token num : 12, prefill_split_num : 1
[I][                             Run][ 901]: input_num_token:12
[I][                             Run][1030]: ttft: 670.51 ms
<think>
</think>
[N][                             Run][1182]: hit eos,avg 12.88 token/s
[I][                      GetKVCache][ 597]: precompute_len:46, remaining:2002
prompt >>
Model Quantization tftt (ms) token/s
Qwen3-0.6B w8a16 670.51 12.88
Qwen3-1.7B w8a16 796.38 7.38
Qwen2.5-0.5B w4a16 - 27.05
Qwen2.5-1.5B w4a16 - 15.06
