Product Guides
StamPLC
VAMeter
Unit RollerCAN
Display & Interaction
Tab5 Keyboard
Chain DualKey
Robotics & Maker Projects
Atom Printer
BalaC Plus
Faces Kit Gameboy
RoverC & JoyC
StampFly & Atom Joystick
Module LoRa868 v1.2 DIP Switch Documentation
1. Feature Overview
To avoid pin conflicts when stacking Module LoRa868 v1.2 with the host, the module uses four DIP switches to flexibly reassign key pins.
  • The four function pins NSS, BUSY, RST, IRQ can be assigned to different GPIOs via the DIP switches.
  • Compatible with various M5Stack hosts: Core (Basic), Core2, CoreS3, etc.
  • Users can adjust the pin mappings as needed to ensure stable system operation.
Host compatibility schematicCore2 compatibility schematicBasic compatibility schematic
2. DIP Switch Overview
2.1 Physical Location of DIP Switches
The four DIP switches are located on the bottom of the module, as shown in the red frames below.
DIP switch overview DIP switch close-up
2.2 Pin Mapping Table
Depending on the host, the available mappings for the key pins are as follows:
Module Model MOSI MISO SCK RST BUSY NSS IRQ
Core (Basic) G23 G19 G18 G25 / G13 G36 / G2 G15 / G12 / G5 / G0 G35 / G34 / G26
Core2 G23 G38 G36 G25 / G19 G36 / G32 G2 / G27 / G33 / G0 G35 / G34 / G26
CoreS3 G37 G35 G36 G5 / G7 G8 / G2 G13 / G6 / G1 / G0 G10 / G14 / G9
  • For example, when using Module LoRa868 v1.2 with a Core (Basic) host, refer to the first row for the mapping:
    • NSS: choose one of G15, G12, G5, or G0
    • BUSY: choose one of G36 or G2
    • RST: choose one of G25 or G13
    • IRQ: choose one of G35, G34, or G26
Set the corresponding DIP switch to the ON side for each selected pin.
3. DIP Switch Configuration Example
Below is an example configuration for Core (Basic) + Module LoRa868 v1.2, showing how to set the four DIP switches:
DIP switch configuration example
In the above example (Core (Basic) + Module LoRa868 v1.2): NSS → G12 BUSY → G2 RST → G13 IRQ → G35
  • After setting the DIP switches, reconnect the module and apply power for use.
