本案例将演示将 LLM630 Compute Kit 作为一台 LLM 计算服务器,并在 PC 端执行脚本,通过 StackFlow 的 API 接口实现 LLM 推理。
下载客户端测试脚本,确保 PC 与 LLM630 Compute Kit 处于同一网段下。执行脚本,并传入设备 IP 地址参数。
python .\llm-qwen2.5-1B.py --host 192.168.20.24
Setup LLM...
Setup LLM finished.
import socket
import json
import argparse
sock.connect((host, port))
return sock
def send_json(sock, data):
def receive_response(sock):
response = ''
while True:
response += part
if '\n' in response:
break
return response.strip()
def close_connection(sock):
if sock:
sock.close()
def create_init_data():
return {
"request_id": "llm_001",
"work_id": "llm",
"action": "setup",
"object": "llm.setup",
"data": {
"model": "qwen2.5-0.5B-prefill-20e",
"response_format": "llm.utf-8.stream",
"input": "llm.utf-8.stream",
"enoutput": True,
"max_token_len": 1023,
"prompt": "You are a knowledgeable assistant capable of answering various questions and providing information."
def parse_setup_response(response_data, sent_request_id):
request_id = response_data.get('request_id')
if request_id != sent_request_id:
print(f"Request ID mismatch: sent {sent_request_id}, received {request_id}")
return None
return None
def setup(sock, init_data):
send_json(sock, init_data)
return parse_setup_response(response_data, sent_request_id)
send_json(sock, deinit_data)
print("Exit Response:", response_data)
return None
return response_data.get('data')
def main(host, port):
sock = create_tcp_connection(host, port)
try:
print("Setup LLM...")
init_data = create_init_data()
llm_work_id = setup(sock, init_data)
print("Setup LLM finished.")
while True:
user_input = input("Enter your message (or 'exit' to quit): ")
if user_input.lower() == 'exit':
break
send_json(sock, {
"work_id": llm_work_id,
"action": "inference",
"object": "llm.utf-8.stream",
"data": {
"delta": user_input,
"index": 0,
"finish": True
while True:
data = parse_inference_response(response_data)
if data is None:
break
delta = data.get('delta')
finish = data.get('finish')
print(delta, end='', flush=True)
if finish:
print()
break
exit_session(sock, {
"request_id": "llm_exit",
"action": "exit"
finally:
if __name__ == "__main__":
parser = argparse.ArgumentParser(description='TCP Client to send JSON data.')
parser.add_argument('--host', type=str, default='localhost', help='Server hostname (default: localhost)')
parser.add_argument('--port', type=int, default=10001, help='Server port (default: 10001)')
args = parser.parse_args()
main(args.host, args.port)
Enter your message (or 'exit' to quit): who are you?
I am a large language model created by Alibaba Cloud. I am called Qwen. I am designed to assist with a wide range of tasks, from simple questions to complex problem-solving. I can answer a wide variety of questions and provide information on various topics. I can also help with language translation, writing, and more. My goal is to be a helpful and informative assistant to those who use me.
