The speech recognition endpoint accepts an audio file and returns text using a speech recognition model running on the device. This example uses the SenseVoice model for AI Pyramid.
Before calling the endpoint, install the speech recognition model and tools required by the example. Refer to the model library for platform support.
apt install llm-model-sense-voice-small-10s-ax650 ffmpeg tool.apt install ffmpeg systemctl restart llm-openai-api On the PC side, use the OpenAI API to pass an audio file to implement the speech-to-text function. Before running the example program, modify the IP part of base_url below to the actual IP address of the device.
from openai import OpenAI
client = OpenAI(
api_key="sk-",
base_url="http://192.168.20.186:8000/v1"
audio_file = open("speech.mp3", "rb")
transcript = client.audio.transcriptions.create(
model="sense-voice-small-10s-ax650",
file=audio_file
print(transcript) | Parameter Name | Type | Required | Example Value | Description |
| file | file | Yes | - | Audio file object to be transcribed (not the file name). Supported formats include flac, mp3, mp4, mpeg, mpga, m4a, ogg, wav, webm |
| model | string | Yes | sense-voice-small-10s-ax650 | SenseVoice models support automatic multilingual recognition, including Chinese, English, Japanese, Cantonese, Korean, etc. |
| language | string | No | - | Language is automatically detected by the model internally |
| response_format | string | No | json | Response format. Currently, only json is supported. The default value is json. |
Transcription(text=' Thank you. Thank you everybody. All right everybody go ahead and have a seat. How\'s everybody doing today? .....',
logprobs=None, task='transcribe', language='en', duration=334.234, segments=12, sample_rate=16000, channels=1, bit_depth=16)
