Core2
SKU:K010
Core2 is the second generation main unit in the M5Stack development kit series, further enhancing the functionality of the original first-generation main unit with more comprehensive hardware features. The core controller Core2 is equipped with ESP32-D0WDQ6-V3, featuring two independently controllable Xtensa® 32-bit LX6 processors with a main frequency of up to 240 MHz, supporting Wi-Fi functionality. It has onboard 16MB Flash and 8MB PSRAM, and programs can be downloaded via the USB Type-C interface. Its powerful configuration meets the resource demands of complex applications. The front is equipped with a 2.0-inch integrated capacitive touch screen, providing users with a smoother human-computer interaction experience.
The body has a built-in vibration motor, providing haptic feedback and vibration alert functions. The built-in RTC module provides precise timing functionality. The power section is equipped with an AXP192 power management chip that effectively controls the power consumption of the body, with a built-in green power indicator light. The body also includes a microSD slot and a speaker. To ensure higher quality sound effects, it uses a power amplifier chip with an I2S digital audio interface, effectively preventing signal distortion. The left side and bottom of the body have independent power and reset (RST) buttons, and the three dots on the front of the screen are part of the touch screen, which can be programmed to map hot zones as three virtual buttons. The back of the body integrates a small expansion board with a 6-axis IMU sensor and a microphone.
Tutorial
This tutorial introduces how to control the Core2 device through the UIFlow graphical programming platform.
This tutorial introduces how to control the Core2 device through the UiFlow2 graphical programming platform.
This tutorial introduces how to program and control the Core2 device using the Arduino IDE.
  • The built-in vibration motor of Core2 interferes structurally with the Base series bases. To prevent equipment damage, do not stack Core2 with any Base series functional bases.
  • When stacking Core2 with M5 modules, you need to remove the battery bottom of Core2. If you want to retain the I2S microphone, IMU, and battery functions of the base while stacking other modules, the M5GO Bottom2 is recommended. The PCB of Core2 has reserved interfaces for the CP2104 chip and a lithium battery connector.
  • Some screens may exhibit non-linear touch response at the edges. You can try upgrading the screen firmware using M5Tool to resolve this issue.
  • Developed based on ESP32, supports WiFi
  • 16MB Flash, 8MB PSRAM
  • Built-in speaker, power indicator light, vibration motor, RTC, I2S amplifier, capacitive touch screen, power button, reset button
  • TF card slot
  • Built-in lithium battery with power management chip
  • Independent small board with built-in 6-axis IMU, PDM microphone
  • M5-Bus socket
  • Development Platform
    • UiFlow1
    • Arduino IDE
    • ESP-IDF
    • PlatformIO
  • 1 x Core2
  • 1 x USB Type-C cable (20cm)
  • 1 x Hex wrench
  • IoT controller
  • STEM education
  • DIY projects
  • Smart home devices
SoC ESP32-D0WDQ6-V3 @ Xtensa® 32-bit LX6 dual-core processor, clock frequency 240MHz
DMIPS 600
SRAM 520KB
Flash 16MB
PSRAM 8MB Quad
Wi-Fi 2.4 GHz Wi-Fi
Input Voltage 5V@500mA
Host Interface USB Type-C x 1, GROVE (I2C+I/O+UART) x 1
LED Green power indicator LED
Button Power button, RST button, screen virtual buttons x 3
Vibration Alert Vibration motor
IPS LCD Screen 2.0"@320 x 240 ILI9342C / ILI9342E
Capacitive Touch IC FT6336U
Speaker Amplifier NS4168
Microphone SPM1423
I2S Amplifier NS4168
IMU MPU6886
RTC BM8563
PMU AXP192
USB Chip CP2104/CH9102F (two chip versions, no functional or usage differences)
DC-DC Boost SY7088
Lithium Battery 500mAh@3.7V
Charging Parameters Charging current: 0.219A
Fully charged current (powered off): 0.055A
Fully charged current (powered on): 0.147A
Antenna 2.4G 3D antenna
Base Screw Spec Hex socket countersunk head M3
Reserved Internal PCB Ports Battery port (Spec: MX1.25-2P) USB cable port (Spec: 1.25mm-4P)
Product Size 54.0 x 54.0 x 16.5mm
Product Weight 54.9g
Package Size 80.0 x 59.9 x 21.6mm
Gross Weight 100.8g
Learn
Power On/Off
  • Single click the left power button: Power on
  • Long-press the left power button: Power off
  • Single click the bottom reset button: Reset
IMU Triaxial Direction Schematic Diagram
Certifications
  • CE/MIC/FCC/RCM
  • IEC62133
Schematics
PinMap
LCD Screen & TF Card
LCD Pixels: 320x240
ESP32-D0WDQ6-V3 G38 G23 G18 G5 G15
ILI9342C / ILI9342E MISO MOSI SCK CS DC
AXP192 AXP_IO4 AXP_DC3 AXP_LDO2
ILI9342C / ILI9342E RST BL PWR
microSD
ESP32-D0WDQ6-V3 G38 G23 G18 G4
TF Card MISO MOSI SCK CS
CAP.TOUCH
ESP32-D0WDQ6-V3 G21 G22 G39
FT6336U (0x38) SDA SCL INT
AXP192 AXP_IO4
FT6336U RST
Microphone & NS4168 Amplifier
ESP32-D0WDQ6-V3 G12 G0 G2 G34
NS4168 BCLK LRCK DATA
Mic CLK DATA
AXP192 AXP_IO2
NS4168 SPK_EN
AXP Power Indicator & Vibration Motor
AXP192 AXP_IO1 AXP_LDO3
Green LED Vcc
Vibration Motor Vcc
RTC
BM8563 (0x51) SDA SCL
AXP192 AXP_PWR
BM8563 INT
IMU (3-axis Gyroscope + 3-axis Accelerometer)
MPU6886 (0x68) SDA SCL
USB to Serial Download
ESP32-D0WDQ6-V3 G1 G3
CP2104/CH9102F RXD TXD
Internal I2C Connection
MPU6886 SDA SCL
AXP192 (0x34) SDA SCL
BM8563 SDA SCL
FT6336U SDA SCL
HY2.0-4P
PORT.A GND 5V G32 G33
PORT.B GND 5V G26 G36
PORT.C GND 5V G14 G13
M5-Bus
FUNC PIN LEFT RIGHT PIN FUNC
GND 1 2 G35 ADC
GND 3 4 G36 ADC
GND 5 6 RST EN
MOSI G23 7 8 G25 DAC
MISO G38 9 10 G26 DAC
SCK G18 11 12 3V3
RXD0 G3 13 14 G1 TXD0
RXD2 G13 15 16 G14 TXD2
Int SDA G21 17 18 G22 Int SCL
PORT.A SDA G32 19 20 G33 PORT.A SCL
GPIO G27 21 22 G19 GPIO
I2S_DOUT G2 23 24 G0 I2S_LRCK
NC 25 26 G34 I2S_DATA
NC 27 28 5V
NC 29 30 BAT
M5Core2 BUS (Comparison with M5Stack)
M5Core2 Port Description
PORT PIN Note:
PORT-A (Red) G32/33 I2C
PORT-B (Black) G26/36 DAC/ADC
PORT-C (Blue) G13/14 UART
Model Size
module size
Structure
Datasheets
Softwares
UiFlow1
PlatformIO
[env:m5stack-core2]
platform = espressif32@6.12.0
board = m5stack-core2
framework = arduino
upload_speed = 921600
monitor_speed = 115200
board_build.partitions = default_16MB.csv
build_type = debug
build_flags =
    -DBOARD_HAS_PSRAM
    -DCORE_DEBUG_LEVEL=5
lib_deps =
ESP-IDF
USB Driver
Driver
Click the link below to download the driver for your operating system. There are currently two driver chip versions, CP210X (for CP2104 version) / CP34X (for CH9102 version) driver package. After extracting the package, select the installation package for your operating system's bit version to install. (If you are unsure which USB chip your device uses, you can install both drivers. CH9102_VCP_SER_MacOS v1.7 may report an error during installation, but it has actually completed the installation, so you can ignore it.) If you encounter issues with downloading programs (such as timeout or "Failed to write to target RAM"), try reinstalling the device driver.
CP210x_VCP_Windows CP2104 Download
CP210x_VCP_MacOS CP2104 Download
CP210x_VCP_Linux CP2104 Download
Easyloader
Easyloader Download Link Note
Core2 Factory FirmWare download /
Other
The book 《ESP32 formats and communication protocols》 introduces the M5Stack Core2 module in several chapters. The M5Stack Core2 module integrates a touch LCD screen, and Wi-Fi communication, a microphone and speaker, as well as an accelerometer and gyroscope, making the M5Stack Core2 module very versatile. The book uses communication protocols to build projects, from connecting a smartwatch to a phone (BLE) to remote communication with satellites orbiting above the earth (LoRa) and audio signal transmission between devices (I2S). QR codes are used to control external devices via the internet, while ESP-MESH and ESP-NOW protocols enable communication between microcontrollers without an internet connection.
Video
Product Comparison
To compare information on the controller series products, you can visit the Product Selection Table, check the target products, and get the comparison results. The selection table covers key information such as core parameters and functional features, and supports comparison of multiple products simultaneously.
Version Change
Release Date Product Changes Note
2026.8.7 LCD screen model changed from ILI9342C to ILI9342E When compiling programs with the M5GFX library, M5GFX library version >= 0.2.27 is required
2023.10 Lithium battery capacity changed from 390mAh to 500mAh /
2023.2 Removed RTC button battery Does not affect timing functions
2021.7 CP2104 replaced with CH9102F Actual shipments include CP2104 and CH9102F chip versions; there is no difference in function or use
2020.6 First release /
