PM2.5 Kit
SKU:K023
PM2.5 Kit is an air quality monitoring kit composed of a Basic controller, Module Air Quality with a built-in PMSA003 digital particulate matter concentration sensor, and Base BTC with a built-in SHT20 temperature and humidity sensor. It can simultaneously collect environmental particulate matter concentration and temperature/humidity data. The kit supports suspended particulate matter detection across multiple particle size ranges and can output mass concentration data related to PM2.5 standard values. It is suitable for real-time air quality monitoring, data logging, and trend analysis at fixed locations such as homes, offices, classrooms, and laboratories. It can also provide data reference for environmental improvement devices such as air purifiers and fresh air systems.
  • Based on M5Stack Basic controller
    • Equipped with screen and buttons for local data display and interaction
  • Module Air Quality
    • Built-in PMSA003 particulate matter concentration sensor
    • Supports multi-particle-size particulate matter and PM2.5 mass concentration detection
    • Provides 2.54-8P expansion interface with SPI/I2C IO pins exposed
  • Base BTC
    • SHT20 temperature and humidity sensor for simultaneous environmental temperature and humidity data collection
  • Supports DC 5V / USB Type-C power supply, compatible with M5Stack modular stacking expansion system
  • 1 x Basic
  • 1 x Module Air Quality
  • 1 x Base
  • 1 x USB Type-C Cable (100cm)
  • 2 x M3x16 screw
PM2.5 Sensor PMSA003
Minimum Distinguishable Particle Size 0.3μm
Particulate Matter Mass Concentration Resolution 1μg/m³
Particulate Matter Measurement Range 0.3-1.0, 1.0-2.5, 2.5-10 μm
Particulate Matter Counting Efficiency 50%@0.3μm; 98%@≥0.5μm
Particulate Matter Mass Concentration Effective Range (PM2.5) 0 ~ 500μg/m³
Particulate Matter Mass Concentration Maximum Range (PM2.5) ≥1000μg/m³
Particulate Matter Mass Concentration Consistency (PM2.5) ±10%@100 ~ 500μg/m³
±10μg/m³@0 ~ 100μg/m³
Temperature & Humidity Sensor SHT20
Temperature Measurement Range -40 ~ 125°C
Temperature Measurement Accuracy Typ. 0 ~ 60°C, ±0.3°C
Humidity Measurement Range 0 ~ 100%RH
Humidity Measurement Accuracy ±3% RH
Supply Voltage DC 5V
Product Size 63.0 x 52.0 x 46.0mm
Product Weight 70.0g
Package Size 125.0 x 67.0 x 23.0mm
Gross Weight 135.0g
Schematics
Datasheets
Softwares
UiFlow1
EasyLoader
Easyloader Download Note
PM2.5 Kit Test Easyloader download /
Video
  • Temperature and humidity display, PM1.0 PM2.5 PM10 standard particulate matter concentration, environmental particulate matter concentration, and particle count display.
