6060-Push
SKU: K028
6060-Push is a motion control module within the M5Stack structural system. It features a high-precision stepper motor, a Mega328 microprocessor, and a 1515 aluminum profile frame. By writing control programs, you can control the stepper motor. The module communicates via the RS485 serial bus, enabling high-precision displacement. It is suitable for various motion control scenarios, such as 3D printing and linear motion control.
  • Built-in Mega328: GRBL
  • Customizable: Body length & effective stroke
  • RS485 communication
  • 1515 aluminum profile frame
  • 48 stepper motor: Two-phase, four-wire system
  • Stroke: 57mm
  • Input voltage: 12-24V
  • Motor power: 10W
  • 1x 6060-Push module
  • 3D printing
  • Linear motion control
Product Size 166.0 x 60.0 x 60.0mm
Product Weight 556.8g
Package Size 166.0 x 60.0 x 60.0mm
Gross Weight 556.8g
Model Size
Datasheets
Softwares
#include <M5Stack.h>
#define RX_PIN      16
#define TX_PIN      17
#define X_LOCAL 40
#define Y_LOCAL 40
#define X_OFF 160
#define Y_OFF 30
int distance = 0;    // Stepper motor movement step value
void header(const char *string, uint16_t color){     // Title
    M5.Lcd.fillScreen(color);
    M5.Lcd.setTextSize(1);
    M5.Lcd.setTextColor(TFT_MAGENTA, TFT_BLUE);
    M5.Lcd.fillRect(0, 0, 320, 30, TFT_BLUE);
    M5.Lcd.setTextDatum(TC_DATUM);
    M5.Lcd.drawString(string, 160, 3, 4);
    M5.Power.begin();
    header("PUSH 6060", TFT_BLACK);
    M5.Lcd.setTextFont(2);
    M5.Lcd.setTextColor(TFT_WHITE, TFT_BLACK);
    Serial2.begin(9600, SERIAL_8N1, RX_PIN, TX_PIN);  // Configure Serial2
    delay(500);
    Serial2.print("ID=123\r\n");                     // Serial2 outputs ID=123\r\n, configuring 6060 motor ID to 123
    if(M5.BtnA.wasPressed()){                      // Button A pressed, send ID\r\n to check 6060 motor ID
      Serial2.print("ID\r\n");
    if(M5.BtnB.wasPressed()){                      // Button B pressed, send ID123:X%d\r\n to control absolute movement, where %d is the variable distance
      if(distance < 50){
         distance +=10;
         Serial2.printf("ID123:X%d\r\n",distance);
    if(M5.BtnC.wasPressed()){                      // Button C pressed, send ID123Z\r\n to return motor to origin
      Serial2.print("ID123Z\r\n");
    if(Serial2.available()){                       // Serial2 receives messages from 6060 and prints them
      char c = Serial2.read();
      Serial.print(c);
Internal Firmware
