Atom CAN
SKU:K057
Atom CAN is a CAN bus communication unit that uses the CA-IS3050G transceiver solution (the built-in DC-DC isolation power chip can effectively isolate interference and prevent damage to sensitive circuits). The communication bus can support up to 110 nodes, with a signal transmission rate of up to 1Mbps and multiple electrical line protection functions. It is very suitable for applications such as vehicle transportation and security systems.
  • CAN bus multi-point communication
  • Built-in isolated DC-DC
  • Signal rate up to 1Mbps
  • Common-mode voltage range from –12V to 12V
  • Protection features:
    • Signal isolation
    • Current limiting
    • Overvoltage protection
    • Thermal shutdown
    • Ground loss protection (-40V to 40V)
  • 1 x Atom-Lite
  • 1 x Atomic CAN Base
  • 1 x HT3.96-4P terminal
  • CAN bus communication
  • Vehicle equipment control
  • Industrial field control
External port HT3.96-4P
CAN transceiver model CA-IS3050G
Maximum speed 1Mbps
Supported nodes 110
Low loop delay 150ns
Common-mode voltage -12V ~ 12V
Protection features Current limiting, overvoltage, active timeout, thermal shutdown
Operating temperature 0 ~ 40°C
Housing material Plastic (PC)
Product Size 24 x 48 x 18mm
Product weight 14.0g
Package Size 54 x 54 x 20mm
Gross weight 33.0g
Schematics
PinMap
PIN LEFT RIGHT PIN
3V3 1
UART_TX 2 3
UART_RX 4 5 5V
6 7 GND
8 9
Datasheets
Softwares
UiFlow1
EasyLoader
Atom CAN Sender Easyloader download /
Atom CAN Receive Easyloader download /
Video
