Atom DTU NBIoT
SKU:K059
Atom DTU NBIoT is a programmable data transmission unit (DTU) integrated with NB-IoT communication functionality. It features a built-in SIM7020G module, covering most Cat-NB frequency bands, and includes an SMA external antenna interface to enhance communication quality and signal stability. Unlike conventional DTUs that only support data passthrough, the Atom DTU NBIoT series adopts a more open architecture design. The Atom-Lite controller allows users to modify the program according to actual business needs. The device is equipped with multiple interfaces (RS485, I2C, custom interfaces) for user expansion, facilitating quick integration of sensors and actuators. It also comes with a rail mounting structure, making it easy to embed into various industrial control environments. Atom DTU NBIoT is ideal for applications requiring low latency and low throughput, such as remote control, asset tracking, remote monitoring, telemedicine, and shared bikes.
  • SIM7020G/Global version/Multi-band support
  • RS485 communication interface (with 12V input, internally integrated DC-DC step-down to 5V)
  • Modbus Master/Slave
  • Strong signal reception capability
  • AT command control
  • SIM card type: MicroSIM
  • External antenna: SMA antenna interface
  • Grove expansion interfaces:
    • I2C x1
    • Custom x1
  • Serial communication: UART 115200bps
  • Built-in rail mounting
  • Cat-NB frequency bands:
    • B1/B2/B3/B4/B5/B8/ B12/B13/B17/B18/B19/ B20/B25/B26/B28/ B66/B70/B71/B85
  • Data transmission (kbps):
    • 126(DL)/150(UL)
  • Network protocols:
    • TCP/UDP/HTTP/HTTPS/ TLS/DTLS/DNS/NTP/ PING/LWM2M/COAP/ MQTT/MQTTS
  • 1 x Atom-Lite
  • 1 x Atomic DTU NBIoT Base
  • 1 x SMA antenna
  • 1 x SMA red cap
  • 1 x M2 hex wrench
  • 1 x M2x16 screw
  • 1 x HT3.96-4P terminal
  • Smart metering
  • Remote monitoring
  • Shared bikes
Specification Parameters
Communication module SIM7020G
Supported Cat-NB bands B1/B2/B3/B4/B5/B8/ B12/B13/B17/B18/B19/ B20/B25/B26/B28/ B66/B70/B71/B85
Network protocols TCP/UDP/HTTP/HTTPS/ TLS/DTLS/DNS/NTP/ PING/LWM2M/COAP/ MQTT/MQTTS
Communication method UART 115200bps
Product Size 64 x 24 x 29mm
Product weight 32g
Package Size 91 x 42 x 24.5mm
Gross weight 40g
Certifications
  • RoHS/REACH/RCM/Telstra/CE(RED)/GCF/ATEX/TIM/Deutsche Telekom/Vodafone/FCC/PTCRB/T-Mobile/IC
Carrier Certifications
  • Telstra*/Vodafone/Deutsche Telekom
Schematics
PinMap
PIN LEFT RIGHT PIN
1 3V3
PORT.A 2 3 NBIoT2_UART_RX
PORT.A 4 5 NBIoT2_UART_TX
5V 6 7 RS485_TX
GND 8 9 RS485_RX
  • SIMCOM7020G
Atom G22(TX) G19(RX) 5V GND
SIMCOM7020G RX TX VIN GND
  • RS485
Atom G23 G33 5V GND
RS485 TX RX VIN GND
  • I2C
Atom G25 G21 5V GND
I2C SDA SCL VIN GND
Datasheets
Softwares
UiFlow1
Case Description
Connect to the MQTT server to perform message subscription and publishing. When a new subscribed message is received, the callback function is invoked and the topic name and data content are passed in. The output result will be printed to the USB serial port.
Protocol
Video
