AtomU
SKU:K117
AtomU is an ultra-compact and flexible IoT voice-recognition development board powered by Espressif’s ESP32. It is equipped with two low-power Xtensa® 32-bit LX6 microprocessors running at up to 240 MHz. The board integrates peripherals such as a USB Type-A interface, IR transmitter, and a programmable RGB LED, allowing true plug-and-play use for uploading, downloading, and debugging firmware.
With its built-in Wi-Fi module and on-board digital microphone SPM1423 (PDM), AtomU enables clear audio recording, making it ideal for human–machine interaction and speech-to-text (STT) applications in various IoT scenarios.
Tutorial
This tutorial shows you how to control the AtomU device via the UiFlow1 graphical programming platform.
This tutorial shows you how to control the AtomU device via the UiFlow2 graphical programming platform.
  • ESP32-PICO-D4 (2.4 GHz Wi-Fi)
  • USB-A programming/power interface
  • Integrated programmable RGB LED and button
  • Ultra-compact body
  • Built-in IR transmitter
  • Expandable pins and GROVE interface
  • Development Platform
    • UiFlow1
    • Arduino IDE
    • ESP-IDF
    • PlatformIO
  • 1 x AtomU
  • IoT controller
  • Voice recording & cloud STT recognition
SoC ESP32-PICO-D4 @ Xtensa® 32-bit LX6 dual-core processor, clock frequency up to 240MHz
DMIPS 600
SRAM 520KB
Wi-Fi 2.4 GHz Wi-Fi
Microphone SPM1423
Microphone Sensitivity 94 dB SPL @ 1 kHz, Typ.: −22 dBFS
Microphone SNR 94 dB SPL @ 1 kHz, A-weighted, Typ.: 61.4 dB
Standby Operating Current 40.4 mA
Supported Input Frequency 100 Hz ~ 10 kHz
Supported PDM Clock 1.0 ~ 3.25 MHz
Product Size 53.0 x 20.0 x 10.3mm
Product Weight 8.6 g
Package Size 114.2 x 65.6 x 20.6mm
Gross Weight 16.6 g
Schematics
schematics
PinMap
SPM1423 – PDM
ESP32-PICO-D4 G5 G19 3.3 V GND
SPM1423 MIC_CLK MIC_DATA VCC GND
IR & SK6812 & BUTTON
ESP32-PICO-D4 G12 G27 G39
IR TX
SK6812 DIN
BUTTON SW
HY2.0-4P
PORT.CUSTOM GND 5V G26 G32
Model Size
Datasheets
Softwares
UiFlow1
PlatformIO
[env:m5stack-atom]
platform = espressif32@6.7.0
board = m5stack-atom
framework = arduino
upload_speed = 1500000
monitor_speed = 115200
build_flags =
    -DCORE_DEBUG_LEVEL=5
lib_deps =
USB Driver
AtomU may not work without a driver on some systems. You can resolve this issue by manually installing the FTDI VCP driver.
  1. Select the driver file that matches your operating system from the list below, download it, and extract it. You can also visit the FTDI Chip official website for additional FTDI driver versions.
Driver Name Download Link
Windows_Desktop_x64 Download
Windows_Desktop_x86_32 Download
Windows_Desktop_ARM Download
MacOS_Intel Download
MacOS_ARM64 Download
  1. Connect the device to your PC, open Device Manager, and install the FTDI driver (the screenshot below uses Windows 10 as an example). (Note: On some systems, you may need to install the driver twice for it to take effect. The unrecognized device is usually named M5Stack or USB Serial.)
Video
Product Comparison
To compare information on the Atom series products, you can visit the Product Selection Table, check the target products, and get the comparison results. The selection table covers key information such as core parameters and functional features, and supports comparison of multiple products simultaneously.
