SKU:K121
The Scales Kit is an electronic scale kit that uses four sets of half-bridge resistive strain gauges, with a total weighing capacity of up to 200kg. It is paired with a high-precision 24-bit A/D converter chip, the HX711, which features a built-in low-noise programmable amplifier supporting gain adjustments of 32, 64, and 128. When combined with the M5Stack main controller, it allows for the quick and easy construction of an IoT weighing application in just a few minutes.
| Specification | Parameter |
| HX711 | Output Sensitivity: High-precision 24-bit ADC Programmable Gain Amplification: 32, 64, 128 10SPS Output Data Rate |
| Half-Bridge Resistive Strain Gauge | Output Sensitivity: 1.0±0.1mV/V Non-linearity: 0.3% F.S Overall Accuracy: 0.3% F.S Zero Output: ±0.3mV/V Impedance Difference Between Upper and Lower Strain Gauges: 0.8Ω Output (Input) Impedance: 1000±5Ω |
| Product Size | 105.0 x 65.0 x 40.0mm |
| Product Weight | 5.2g |
| Package Size | 105.0 x 65.0 x 40.0mm |
| Gross Weight | 113.2g |
| M5Core | G36 | G26 | 5V | GND |
| Unit Weight | DATA Pin (DAT) | CLOCK Pin (CLK) | VCC | GND |
#include "HX711.h"
HX711 scale;
// 1. Set the ADC value at 0g and set it as the offset
scale.tare();
// 2. Read the average ADC value with a standard weight (e.g., 5kg)
long kg_adc = scale.read_average(20);
// 3. Read the current offset at 0g
kg_adc = kg_adc - scale.get_offset();
// 4. Calculate and configure the scale parameter
scale.set_scale( kg_adc / (5 * 1000.0));
| Product Compare | Unit Scales ![]() | Scales Kit ![]() | Unit Mini Scales ![]() | Unit Weight ![]() | Unit Weight-I2C ![]() |
| Communication Protocol | I2C | ADC | I2C | ADC | I2C |
| Chip Solution | STM32+HX711 | HX711 | STM32+HX711 | HX711 | STM32+HX711 |
| Sensor Range | 0 ~ 20kg | 0 ~ 200kg | 0 ~ 5kg | Depends on the strain gauge and controller chip | Depends on the strain gauge and controller chip |
