SKU:K131
Air Quality is a low-power, all-in-one air-quality monitoring device. It integrates the multifunctional air-quality sensor SEN55 and the CO₂ sensor SCD40, enabling the measurement of PM1.0, PM2.5, PM4, PM10 particulate matter, temperature, humidity, VOC, and CO₂ concentration. Powered by the StampS3 MCU with 8MB Flash, it features a 1.54-inch E-Ink display (200 × 200) that retains the last image even when power is off. A built-in 600 mAh battery together with an RTC low-power management circuit supports sleep and timer wake-up functions.
The factory firmware uploads data to M5’s EZDATA cloud platform and automatically generates a monitoring page, allowing convenient remote access for users. The bottom of the device provides LEGO mounting holes, magnets, and four detachable mounting ears for versatile installation. It is ideal for long-term online monitoring in environments such as homes, schools, industrial sites, and medical facilities.
Tutorial
This tutorial shows how to control the Air Quality device using the Arduino IDE.
This tutorial demonstrates how to control the Air Quality device with the UiFlow2 graphical programming platform.
  • SEN55 and SCD40 sensors
  • 1.54-inch E-Ink display (200 × 200 px)
  • Built-in 600 mAh battery
  • Grove interface
  • EZDATA cloud access
  • RTC timer wake-up
  • Development Platform
    • Arduino IDE
    • ESP-IDF
    • PlatformIO
  • 1 x Air Quality
  • 1 x User Manual
  • Home environment monitoring
  • Industrial automation
  • Medical facilities
  • Research laboratories
  • Remote monitoring
  • HVAC system optimization
  • Construction sites
Module Model StampS3
SoC ESP32-S3FN8 @ Xtensa® 32-bit LX7 dual-core processor, clock frequency 240MHz
USB USB OTG, USB Serial/JTAG
Flash 8MB
Wi-Fi 2.4 GHz Wi-Fi
Display GDEY0154D67 @ 1.54"
Resolution 200 × 200 px
SEN55 I2C address: 0x69
SCD40 I2C address: 0x62
Environmental Measurements PM1.0, PM2.5, PM4, PM10, temperature, humidity, VOC, CO₂ concentration
RTC RTC8563
Battery 600 mAh @ 3.7 V
Buttons Button A (G0), Button B (G8), power button, reset/power-off
Grove Interface HY2.0-4P
Buzzer On-board passive buzzer
Mounting LEGO holes, magnet, 4 x M3 detachable mounting ears
Operating Temperature 0 ~ 40 °C
Product Size 72.0 x 56.0 x 24.1 mm
Product Weight 91.9 g
Package Size 100.8 x 74.3 x 30.5 mm
Gross Weight 120.0 g
Learn
Power On/Off
  • Power On: When the device is powered only by the battery, press the WAKE button or wake it via an IRQ signal triggered by the RTC timer. After the wake-up signal is triggered, set the HOLD (GPIO46) pin to high (1) in the program initialization to maintain power; otherwise, the device will return to sleep.
  • Power Off: When no external USB power is connected (battery power only), use either of the following methods: (1) Press the RST button; (2) Set HOLD (GPIO46) to 0 during program execution to cut off battery power.
Download Mode
With the device powered off, press and hold the G0 button on the Stamp-S3 or the BOOT button on the Air Quality while connecting the device to a computer via a USB Type-C data cable. Release the button after the device is powered on; the device enters download mode.
User Manual
Schematics
PinMap
Power Control
ESP32-S3 G10 G46 G42 G14
SEN55 POWER SWITCH AirPWREN
HOLD HOLD
WAKE WAKE
BATTERY DETECT G14
Display
ESP32-S3 G1 G2 G3 G4 G5 G6
GDEY0154D67 BUSY RST D/C CS SCK MOSI
Input Interaction
ESP32-S3 G9 G0 G8
BEEP beep
BUTTON A USER_A
BUTTON B USER_B
Sensors
ESP32-S3 G11 G12
SEN55 SDA SCL
SCD40 SDA SCL
RTC8563 SDA SCL
HY2.0-4P
PORT.A GND 5 V G13 G15
Model Size
module size
Structure
Datasheets
Softwares
PlatformIO
Restore to Factory State
If the Air Quality device has previously flashed UiFlow firmware and been bound to a user account, please unbind the device in the UiFlow2 device list before flashing the factory firmware. Otherwise, data may fail to upload to EzData after reflashing.
[env:m5stack-stamp-s3]
platform = espressif32
board = esp32-s3-devkitc-1
framework = arduino
upload_speed = 1500000
build_flags =
    -DESP32S3
    -DCORE_DEBUG_LEVEL=5
    -DARDUINO_USB_CDC_ON_BOOT=1
    -DARDUINO_USB_MODE=1
lib_deps =
Easyloader
Easyloader Download Note
Air Quality User Demo download /
Other
Video
