VAMeter
SKU:K136
VAMeter is a professional, programmable, high-precision power meter designed for accurate voltage and current measurements. Powered by the Stamp-S3 module, it features Wi-Fi connectivity and two cascaded INA226 current/voltage sensing circuits, delivering current detection resolutions of 2.5 µA and 250 µA. The measurement range supports 0-5 A and 5-24 V (1-24 V in isolation mode).
The device offers flexible power-supply options through the USB-C port or the Base terminal, with built-in power and signal isolation. A slide switch lets users choose between isolated measurements powered via USB and non-isolated measurements powered directly from the test source, meeting various application needs.
The included expansion BASE provides relay on/off control and a Grove port for secondary development. Additional features include OTA firmware upgrades and USB MSC/OTG support, allowing users to view and edit data and configuration files stored in the main controller’s file system from a PC.
M5Stack also supplies a free online data API for uploading test data to the EZData platform, enabling remote access and visualization and greatly simplifying IoT application development.
VAMeter is a highly practical and developer-friendly instrument, ideal for projects requiring precise current and voltage measurements, as well as for industrial automation, equipment monitoring, smart grid, and related fields.
Tutorial
This tutorial introduces usage examples of VAMeter.
  • High-precision current detection (2.5 µA / 250 µA resolution switching)
  • Wide voltage input (5-24 V)
  • Cloud data display via EZData
  • PD input (no PD trigger built in)
  • Multiple power-supply methods (PD INPUT / Stamp-S3 / external terminal block)
  • Power and signal isolation
  • USB MSC/OTG support
  • Open-source hardware & software
  • Wireless OTA upgrade
  • Development Platform
    • Arduino IDE
    • ESP-IDF
    • PlatformIO
  • 1 x VAMeter
  • 1 x VAMeter Base
  • 2 x 3.81-2P Terminal Block
  • 4 x Hanger (Small)
  • Industrial automation
  • Equipment monitoring
  • Power testing & analysis
  • IoT devices
  • Remote monitoring & data acquisition
SoC ESP32S3FN8@Xtensa 32-bit LX7 dual-core processor, main frequency 240MHz
Power Detection Chip INA226
Flash 8MB
Wi-Fi 2.4 GHz Wi-Fi
INA226 Communication Address Dual detection chips INA226: 0x40 / 0x41
Display 1.3 inch @ 240 × 240 pixels
Display Driver ST7789
PD Input Power 5-24 V @ 0-5 A
Current Resolution 2.5 µA / 250 µA
Current Sampling Err Small current (1-100 mA): 1.01 %
Large current (100 mA-5 A): 0.94 %
µA-level current: 0.69 %
Voltage Error Measurement error: 0.11 %
Power Consumption Stamp-S3 USB powered: DC 5 V / 123.5 mA
PD INPUT: DC 5 V / 118 mA
DC 12 V / 66.8 mA
DC 24 V / 26 mA
PD OUTPUT Capability DC 24 V @ 3 A 68 ℃
DC 24 V @ 5 A 92 ℃
User Interface Rotary encoder switch, Reset button, Boot button, onboard buzzer
Relay DC 5 - 24 V @ 5 A
Operating Temp. 0 - 40 °C
Product Size 51.5 × 48.0 × 40.5 mm
Product Weight 43.4 g
Package Size 160.9 × 93.0 × 31.6 mm
Gross Weight 68.4 g
Learn
Download Mode
Download Mode
To enter download mode, press and hold the G0 button on VAMeter before power-on, then release it after powering up.
schematics
M5 EZData Cloud Platform Example
schematics
Schematics
VAMeter Internal Block Diagram
schematics
PinMap
VAMeter (INA226 & BUZZER)
INA226 (0x40) and INA226 (0x41) are used for measurements at different resolutions and ranges.
ESP32S3FN8 G5 G6 G41 G40 G14
INA226 (0x40) FSDA FSCL ALERT1
INA226 (0x41) FSDA FSCL ALERT2
BUZZER BUZ_PWM
VAMeter Expansion Pins
ESP32S3FN8 G10 G9 G8 G42
Expansion EXT_G10 EXT_G9 EXT_G8 EXT_G42
VAMeter Base
ESP32S3FN8 G10
Relay G10_REL
HY2.0-4P
PORT.CUSTOM GND 5V G8 G9
Model Size
module size
Structure
PCB
Datasheets
Softwares
Quick Start
ESP-IDF
Easyloader
Easyloader Download Note
VAMeter Firmware Easyloader download /
Other
Video
  • VAMeter Feature Introduction
Product Comparison
schematics
