AI Pyramid OpenAI-Compatible API Chat Example
This example explains how to deploy a StackFlow chat model and the OpenAI-compatible API on AI Pyramid, then invoke the local model through cURL, the Python SDK, and Chatbox.
Preparation
  1. Refer to AI Pyramid Software Package Update to complete the installation of the following model packages and software packages.
apt install lib-llm llm-sys llm-llm llm-openai-api
apt install llm-model-qwen2.5-1.5b-int4-ax650
After installing a new model each time, you need to manually execute systemctl restart llm-openai-api to update the model list.
Curl Call
curl http://127.0.0.1:8000/v1/models \
  -H "Content-Type: application/json"
curl http://127.0.0.1:8000/v1/chat/completions \
  -d '{
    "model": "qwen2.5-1.5B-Int4-ax650",
    "messages": [
Python Call
from openai import OpenAI
client = OpenAI(
    api_key="sk-",
client.models.list()
print(client.models.list())
client = OpenAI(
    api_key="sk-",
  model="qwen2.5-1.5B-Int4-ax650",
  messages=[
    {"role": "user", "content": "Turn on the light!"}
print(completion.choices[0].message)
ChatBox Call
Get ChatBox
Click Setup Provider to add a model provider.
In Add provider, set Name to AI Pyramid, and select OpenAI API Compatible for API Mode.
In API Host, enter the IP address and API path of AI Pyramid, then retrieve and add the installed models.
Add the qwen2.5-1.5B-Int4-ax650 model provided by LLM8850.
Set the maximum context message length to 0.
Streaming output is supported.
