Faces Kit
SKU:K005
Faces Kit is a collection of functional panels. The kit includes three commonly used panels: "GameBoy (gaming keyboard)", "Calculator (numeric keypad)", and "QWERTY (full keyboard)". A MEGA328 processor is integrated inside, working in slave mode via the I2C communication protocol (0x08). Choose any of these three panels as needed to enable human–machine interaction between the user and M5Core.
Tutorial
This tutorial shows you how to control the Gray device through the UIFlow graphical programming platform
This tutorial shows you how to control the Gray device through the UiFlow2 graphical programming platform
This tutorial shows you how to program and control the Gray device via the Arduino IDE
  • ESP32-based development
  • Built-in gyroscope, accelerometer, and magnetometer
  • Integrated speaker, buttons, LCD screen, and 1 × power/reset button
  • TF-card slot (expandable up to 16 GB)
  • M5-Bus female connector
  • Magnetic charging design
  • Built-in lithium battery
  • Extensible pins and interfaces
  • Development Platform
    • UiFlow1
    • Arduino IDE
    • ESP-IDF
    • PlatformIO
  • 1 × Gray
  • 1 × FACES Charging Base
  • 1 × FACES Lanyard
  • 1 × Panel Sticker
  • 3 × FACES Keyboards (GameBoy, Calculator, QWERTY)
  • 8 × Dupont Cables
  • 6 × M3 × 12 mm Screws
  • 1 × Hex Key L-Shape
  • 1 × USB Type-C Cable (100 cm)
  • Handheld game console
  • Calculator
  • Data-entry peripheral
  • IoT controller
Main Control Resources Parameter
SoC ESP32-D0WDQ6 @ Xtensa® 32-bit LX6 dual-core processor, clock frequency 240MHz
DMIPS 600
SRAM 520KB
Flash 16MB (Old version 4MB)
Wi-Fi 2.4 GHz Wi-Fi
Input Voltage 5V@500mA
Host Interface USB Type-C x 1, GROVE (I2C+I/O+UART) x 1
Core Base Interface PIN (G1, G2, G3, G16, G17, G18, G19, G21, G22, G23, G25, G26, G35, G36)
IPS Screen 2 inch, 320x240 Colorful TFT LCD, ILI9342C, Max brightness 853nit
Speaker 1W-0928
Buttons Custom buttons x 3
Antenna 2.4G 3D antenna
Lithium Battery 600mAh@3.7V
MEMS MPU6886+BMM150
2.4G Antenna Proant 440
Case Material Plastic (PC)
Product Size 58.2 x 54.2 x 18.7mm
Product Weight 94.0g
Package Size 120.0 x 85.0 x 65.0mm
Gross Weight 264.0g
Learn
BMM150 Magnetic Interference
Products with magnets may interfere with the BMM150 magnetic sensor, resulting in abnormal readings. When used with M5 main controllers that contain magnets, please remove the magnet and avoid placing the BMM150 near strong magnetic fields.
Power On/Off
  • Power On: Press the red power button on the left once
  • Power Off: Double-click the red power button on the left
Note: By default, the device cannot be powered off while it is powered via USB.
Upgrade
Schematics
PinMap
Mega328 ISP download-interface pin definition
ESP32 ADC/DAC
ADC1 ADC2 DAC1 DAC2
8 channels 10 channels 2 channels 2 channels
G32-39 G0/2/4/12-15/25-27 G25 G26
HY2.0-4P
PORT.A GND 5 V G21 G22
PORT.B GND 5 V G26 G36
PORT.C GND 5 V G17 G16
IP5306 Charging/Discharging Voltage Parameters
Charging Discharging
0.00 ~ 3.40 V → 0 % 4.20 ~ 4.07 V → 100 %
3.40 ~ 3.61 V → 25 % 4.07 ~ 3.81 V → 75 %
3.61 ~ 3.88 V → 50 % 3.81 ~ 3.55 V → 50 %
3.88 ~ 4.12 V → 75 % 3.55 ~ 3.33 V → 25 %
4.12 ~ / → 100 % 3.33 ~ 0.00 V → 0 %
M5-Bus
FUNC PIN LEFT RIGHT PIN FUNC
GND 1 2 G35 ADC
GND 3 4 G36 ADC
GND 5 6 RST EN
MOSI G23 7 8 G25 DAC/SPK
MISO G19 9 10 G26 DAC
SCK G18 11 12 3V3
RXD0 G3 13 14 G1 TXD0
RXD2 G16 15 16 G17 TXD2
Int SDA G21 17 18 G22 Int SCL
GPIO G2 19 20 G5 GPIO
I2S_SK G12 21 22 G13 I2S_WS
I2S_OUT G15 23 24 G0 I2S_MK
HPWR 25 26 G34 I2S_IN
HPWR 27 28 5V
HPWR 29 30 BAT
For more information on pin allocation and remapping, please refer to the ESP32 datasheet.
Structure
Datasheets
Softwares
UiFlow1
USB Driver
Click the links below to download the driver that matches your operating system. Two driver chip versions exist: CP210X (for CP2104 versions) and CP34X (for CH9102 versions). After unzipping, choose the installer matching your OS bitness. (If unsure which USB chip your device uses, install both drivers. CH9102_VCP_SER_MacOS v1.7 may report an error during installation, but the driver is actually installed—just ignore the message.)
Driver Name Applicable Chip Download
CP210x_VCP_Windows CP2104 Download
CP210x_VCP_MacOS CP2104 Download
CP210x_VCP_Linux CP2104 Download
Easyloader
Easyloader Download Note
Faces Kit Factory Firmware Easyloader download /
GameBoy Keyboard
If you want to play classic games with M5Core, the GameBoy panel paired with M5Core is the perfect solution. Simply upload a game-emulator program to M5Core and connect the GameBoy panel. Connection diagram:
ESPTool flashing tutorial: gameboy_burn_a_nes_game
Click here to flash a sample game with one click
The other two panels (Calculator keyboard and full keyboard) can be used in applications requiring data entry or complex control. When replacing panels, it is recommended to remove the M5Core first and then disassemble the panel to reduce difficulty.
Others
  • Key string values
Key AC M % ÷ 0-9 X - + = +/- .
Val A M % / 0-9 * - + = ` .
ESP32 Chip G23 G19 G18 G14 G27 G33 G32 G4
ILI9342C MOSI/MISO / CLK CS DC RST BL
TF Card MOSI MISO CLK CS
Key Int Values (Int values are the ASCII value of each key)
Val 65 77 37 47
48-57 42 45 43 61 96 46
Video
Case Description: This example runs the default FACES keyboard input test program. Reboot and select from the program list to switch between different panel test items.
Version Change
Release Date Product Changes
2019.7 TN screen changed to IPS screen
2019.6 MPU9250 changed to MPU6886+BMM150
2017.12 First release
Devices with 2018.2A PCB version do not support C2C (Type-C to Type-C) connection or PD power supply.
