BalaC
SKU:K038
BalaC is a DIY two-wheeled balancing car. Its base uses an STM32 series main controller, with two motor driver ICs onboard, a power indicator, and a replaceable rechargeable battery. The lightweight design and 360° servo drive form allow you to write balancing programs using the UiFlow graphical interface. The kit includes a StickC, which uses the built-in MPU6886 for attitude calculation, controlling the servo in real-time to achieve balance by calculating offset values. The Lego-compatible design allows you to change different tires. If you want to learn about PID-related content or need an interesting programming toy, BalaC might be a good choice.
  • Based on ESP32+STM32
  • Personalized DIY
  • Detachable design
  • Dual-wheel motor drive
  • Replaceable battery
  • Development platforms:
  • 1 x StickC
  • 1 x BalaC Base
  • 2 x Tires
  • 2 x Tire adapters
  • 2 x 9G Servos
  • 2 x Rubber bands
  • 2 x Screws
  • 1 x Hex wrench
  • 1 x 16340 700mAh Battery
  • 1 x USB Type-C Cable (20cm)
  • Balancing car
Specification Parameters
ESP32-Pico-D4 240MHz dual core, 600 DMIPS, 520KB SRAM, Wi-Fi
MCU STM32F030F4P6
Servo Rotation angle: 360°, no-load speed: 0.12 sec/60° (4.8V)
Driver L9110S
Communication MCU STM32F030F4P6
Communication Protocol I2C: 0x38
Battery 16340, 700mAh rechargeable lithium battery
Net Weight 162.0g
Gross Weight 206.0g
Product Size 30 x 100 x 105mm
Package Size 148 x 118 x 42mm
Learn
Softwares
UiFlow1
Easyloader
BalaC Test Easyloader download /
Video
  • After powering on, press the power button briefly to calibrate. The LED will flash, and once calibration is successful, it will automatically maintain balance.
