Atom Switch
SKU:K042
Atom Switch is a dual-channel programmable switch that supports ATOM, allowing simultaneous control of two AC/DC circuits. It features a built-in step-down module that provides 5V/1A DC power to the ATOM. The onboard relay supports up to 250V/10A mains (16A instantaneous current). To ensure safety, the DC circuit includes overheat and short-circuit protection, effectively disconnecting the circuit in case of excessive current or short-circuit. For industrial applications, we have integrated an SP485EE level conversion chip, providing an RS485 interface for connecting RS485 devices. The RS485 interface can also power the ATOM, supporting a voltage range of 9-24V. Additionally, a HY2.0 interface is provided for connecting I2C peripherals or general I/O devices. Leveraging the ATOM's WIFI capabilities, you can easily achieve remote control of the switch. If you have multiple Atom Switch units, they can be connected in parallel via the RS485 interface.
  • Built-in AC-DC power supply circuit
  • 2-channel relay
  • Built-in RS485 level conversion, supports Modbus
  • HY2.0 expansion
  • Short-circuit and overheat protection
  • Remote control via WIFI and RS485
  • 1 x Atom-Lite
  • 1 x Atom Switch
  • 1 x Double-sided tape
  • 1 x Rail clamp
  • 1 x HT3.96-4P terminal
  • 3 x 3.96 x 3P male headers
  • 1 x M4 hex key
  • 1 x M2 hex key
  • 2 x M4*10mm hex socket head screws
  • 1 x M2*20mm hex socket head machine screw
  • 1 x I/O Sticker
  • Smart switches
Specification Parameters
Relay Parameters AC 250V/10A (16A instantaneous)
Switch Power (AC-DC) AC 250V-DC 5V
RS485 Power Supply DC 9 ~ 24V
Interfaces 1 x HY2.0-4P (PORT.A), 1 x HT3.96-4P (RS485), 2 x HT3.96-2P (Relay), 1 x HT3.96-2P (AC/DC IN)
Housing Material Plastic (PC)
Product Size 72 x 40 x 30mm
Product Weight 134.0g
Package Size 150.0 x 77.0 x 35.0mm
Gross Weight 158.0g
Schematics
PinMap
PIN LEFT RIGHT PIN
1 3V3
PORT.A 2 3 RELAY1
PORT.A 4 5 RELAY2
5V 6 7 RS485_RX
GND 8 9 RS485_TX
Model Size
Datasheets
Softwares
UiFlow1
EasyLoader
Atom Switch Easyloader download /
Video
Switch & Switch-D Comparison
/ Switch Switch-D
Relay Current AC 250V/10A AC 250V/5A
Power Input HT3.96R 2P HT3.96R 3P
Relay Interface (NO,NC,COM) x2 (NO (directly connected to AC L), COM (directly connected to AC N)) x2
Learn
The kit includes rail mounting hardware. Please refer to the following images for installation instructions:
