CoreInk
SKU:K048
CoreInk is a main control device with an E-Ink display launched by M5Stack, using the ESP32-PICO-D4 controller. The front is embedded with a 1.54" E-Ink display with a resolution of 200x200, supporting black/white display. Compared to ordinary LCD screens, the E-Ink display provides a better text reading experience, with features such as low power consumption and image retention when powered off. For human-machine interaction, it offers a rotary switch and physical buttons, integrated LED indicator, and buzzer. It has a built-in 390mAh lithium battery, combined with an internal RTC (BM8563) to achieve timed sleep and wake-up functions, providing excellent battery life. There are independent power and reset (RST) buttons on the left side and bottom of the device, making it easy to use and debug. It offers a variety of peripheral interfaces (HY2.0-4P, M5-Bus, HAT module interface) to expand various sensor devices, providing infinite possibilities for subsequent application development.
Tutorial
This tutorial will show you how to control the CoreInk device through the UIFlow graphical programming platform.
This tutorial will show you how to control the CoreInk device through the UiFlow2 graphical programming platform.
This tutorial will show you how to control the CoreInk device using the Arduino IDE.
  • Developed based on ESP32, supports WiFi
  • Built-in 4M Flash
  • Low power consumption display panel
  • Nearly 180-degree viewing angle
  • Human-machine interaction interface
  • Magnetic back design
  • Built-in lithium battery
  • Rich expansion interfaces
  • Development Platform
    • UiFlow1
    • Arduino IDE
    • ESP-IDF
    • PlatformIO
  • 1 x CoreInk
  • IoT controller
  • E-book reader
  • Industrial instrument display panel
  • Electronic label
SoC ESP32-PICO-D4 @ Dual-core processor, 240MHz main frequency
DMIPS 600
SRAM 520KB
Flash 4MB
Wi-Fi 2.4 GHz Wi-Fi
Input Voltage 5V @ 500mA
Interface USB Type-C x 1, HY2.0-4P x 1, M5-Bus female connector, top HAT expansion interface
E-ink Screen GDEW0154M09, SPI interface, 200 x 200@1.54", Dpi:184, 1-bit black/white display (Grayscale: 2), Viewing area size (mm): 27.6 x 27.6, Dot pitch (mm): 0.138 x 0.138, Refresh time (s): 0.82, Partial refresh time (s): 0.24
Physical Button Programmable button x 1, reset button x 1, power button x 1
LED Green LED x 1
RTC BM8563
Buzzer Passive buzzer * 1
Antenna 2.4G 3D antenna
Pin breakout G25, G26, G36, G23, G34, G18, G21, G22, G14, G13
Battery 390mAh@3.7V
Case Material Plastic ( PC )
Product Size 56.0 x 40.0 x 16.0mm
Product Weight 31.5g
Package Size 80.0 x 45.0 x 20.0mm
Gross Weight 42.6g
Learn
Precautions:
When using, please avoid high-frequency refreshing for a long time. It is recommended to refresh at intervals of (15s/refresh). Do not expose to ultraviolet light for a long time, as this may cause irreversible damage to the E-Ink display. CoreInk uses a low-power power management scheme different from CORE and StickC devices. When using, the PWR button is used as the power-on button (long press for 2s). To shut down the device, you need to use the software API or press the reset button on the back.
Schematics
PinMap
E-Ink Screen
Screen Pixels: 200x200
ESP32-PICO-D4 G4 G0 G15 G9 G18 G23
GDEW0154M09 BUSY RST D/C CS SCK MOSI
Rotary Switch & Physical Buttons & LED & Buzzer
ESP32-PICO-D4 G37 G38 G39 G5 G10 G2 GPI12
Rotary Switch Right Center Left / / / /
Physical Button / / / Physical Button / / /
LED / / / / LED / /
Buzzer / / / / / Buzzer /
Power Control / / / / / / MOS
USB to Serial Download
ESP32-PICO-D4 G1 G3
CP2104 RXD TXD
Internal I2C Connection
ESP32-PICO-D4 G21 G22
BM8563 SDA SCL
ESP32 ADC/DAC Mappable Pins
ADC1 ADC2 DAC1 DAC2
8 Channels 10 Channels 2 Channels 2 Channels
G32-39 G0/2/4/12-15/25-27 G25 G26
For more information on pin assignments and pin remapping, please refer to the ESP32 datasheet
HY2.0-4P
PORT.CUSTOM GND 5V G32 G33
Model Size
Datasheets
Softwares
UiFlow1
USB Driver
Click the link below to download the driver for your operating system. There are currently two driver chip versions, CP210X (for CP2104 version) / CP34X (for CH9102 version) driver packages. After extracting the package, select the installation package corresponding to your operating system's bit version for installation. (If you are unsure which USB chip your device uses, you can install both drivers. CH9102_VCP_SER_MacOS v1.7 may show an error during installation, but it has actually completed the installation, so you can ignore it.)
CP210x_VCP_Windows CP2104 Download
CP210x_VCP_MacOS CP2104 Download
CP210x_VCP_Linux CP2104 Download
Easyloader
Easyloader Download Link Note
CoreInk Factory Test Easyloader v1.0.1 download /
Video
  • Demonstrating some basic features of CoreInk.
Product Comparison
To compare information on the Paper / CoreInk series products, you can visit the Product Selection Table, check the target products, and get the comparison results. The selection table covers key information such as core parameters and functional features, and supports comparison of multiple products simultaneously.
