Atom HDriver
SKU:K050
Atom HDriver is an H-bridge motor driver compatible with ATOM controllers. It features the DRV8876 motor driver chip, supports 9 - 24V / DC power input (with an embedded DC/DC circuit to power the entire device, and the ADC pin G33 is directly connected to a voltage divider circuit to monitor the power input status in real-time), and can output up to 1.5A of current, with a peak of 2A, suitable for DC motor speed control and forward/reverse control. The driver integrates an N-channel H-bridge, charge pump regulator, current sensing and regulation, current proportional output, and protection circuits (including under-voltage lockout (UVLO), charge pump under-voltage (CPUV), over-current protection (OCP), and thermal shutdown (TSD), with fault conditions indicated via the FAULT pin).
  • N-channel H-bridge motor driver
    • Drives one bidirectional brushed DC motor
    • Other resistive and inductive loads
  • DRV8876: 700mΩ (high-side + low-side)
  • High output current capability
    • Continuous output 1.5A, peak 2A
  • H-bridge control mode
  • 3.3V logic input
  • Spread spectrum clock reduces electromagnetic interference
  • Integrated protection features
    • Under-voltage lockout (UVLO)
    • Charge pump under-voltage (CPUV)
    • Over-current protection (OCP)
    • Auto-retry or latch output (IMODE)
    • Thermal shutdown (TSD)
    • Automatic fault recovery
    • Fault indicator pin (nFAULT)
  • 1 x Atom-Lite
  • 1 x Atomic HDriver Base
  • 1 x HT3.96-4P terminal
  • 1 x M2 hex wrench
  • 1 x M2*8 cup head machine screw
  • 1 x USB Type-C cable (20cm)
  • DC motor control
Input Voltage DC 9 ~ 24V
Output Current Continuous 1.5A, peak 2A
Dimensions 24 x 48 x 18mm
Weight 16g
Package Size 54 x 54 x 20mm
Gross Weight 36g
Learn
Fault Indication: When a fault occurs, the FAULT (G22) pin will be pulled low. G33 can obtain 1/10 of the input voltage, which can be used to detect the current power input status.
Schematics
PinMap
PIN LEFT RIGHT PIN
3V3 1
FAULT 2 3
IN1 4 5 5V
IN2 6 7 GDN
VIN-1/10 8 9
Datasheets
Softwares
UiFlow1
Easyloader
Atom HDriver Test Easyloader download /
Video
  • Press the middle button to control motor forward/reverse, long press to stop
