Stamp-Pico Mate
SKU:K051
Stamp-Pico Mate is an accessory kit for the Stamp-Pico minimum core board. The kit includes a Stamp-Pico along with female headers, male headers, a HY2.0-4P female socket and other practical accessories, allowing you to integrate the Stamp-Pico into your circuit quickly and easily.
Stamp-Pico is a cost-effective Wi-Fi minimum core board powered by the ESP32 SoC with two low-power Xtensa® 32-bit LX6 microprocessors running at up to 240 MHz. Thanks to its compact size and outstanding performance, Stamp-Pico can be effortlessly embedded into your application circuit to build IoT solutions.
Tutorial
This tutorial shows you how to control the Stamp-Pico with the UIFlow graphical programming platform.
This tutorial shows you how to control the Stamp-Pico with the UiFlow2 graphical programming platform.
This tutorial shows you how to program the Stamp-Pico with the Arduino IDE.
  • ESP32-PICO-D4 (2.4 GHz Wi-Fi)
  • Multiple I/O breakouts supporting various mounting methods (SMT, DIP, flying leads)
  • Integrated programmable RGB LED and button
  • ESP32 minimum system board
  • High-temperature plastic armor for better protection of the 3D antenna and components
  • On-board 5 V → 3.3 V DC/DC circuit, 12 × GPIO, 1 × programmable RGB LED, 1 × button
  • Professionally tuned RF circuit for stable and reliable wireless communication
  • Development Platform
    • UiFlow1
    • Arduino IDE
    • ESP-IDF
    • PlatformIO
  • 1 × Stamp-Pico
  • 1 × 2.54-9P Male Header
  • 1 × 2.54-9P Female Header
  • 1 × 2.54-6P Male Header
  • 1 × 2.54-6P Female Header
  • 1 × High-temperature Sticker
  • 1 × HY2.0-4P Female Socket (90°)
  • 1 × Hex Key L-Shape 1.5 mm (For M2 Screw)
  • Smart home
  • Wearable devices
  • Medical equipment
SoC ESP32-PICO-D4@dual-core processor, 240MHz
Package LGA48 (7×7mm)
Flash 4MB
Wi-Fi 2.4 GHz Wi-Fi
DMIPS 600
SRAM 520KB
Input Voltage 5V@500mA
Power Consumption Normal standby: 5 V@29 mA / Wi-Fi STA mode: 5 V@60 mA / Classic Bluetooth TX: 5 V@84 mA / DeepSleep: 5 V@0.35 mA
Wireless Range AP mode: 16 m / BLE mode: 110 m / Classic Bluetooth mode: 90 m
HMI 1 × Programmable physical button, 1 × Programmable RGB LED (SK6812)
Antenna Type 2.4 G 3D antenna
Wi-Fi 802.11 b/g/n (up to 150 Mbps with 802.11 n), spectrum range: 2.4 GHz ~ 2.5 GHz
Peripheral Interface ADC, DAC, Touch Sensor, SD/SDIO/MMC Host Controller, SPI, SDIO/SPI Slave Controller, EMAC, Motor PWM, LED PWM, UART, I2C, I2S, IR Remote Controller, GPIO, PCNT
IO (12 pins) G0, G1, G3, G26, G36, G18, G19, G21, G22, G25, G32, G33
IO Pitch 2.54 mm
Operating Temp. 0 ~ 60 °C
Mounting Screws M2 × 4 Countersunk Hex Socket Machine Screws
Product Size 24.0 × 18.0 × 4.6 mm
Product Weight 2.6 g
Package Size 138.0 x 93.0 x 7.0mm
Gross Weight 7.6 g
Learn
Download Program
Stamp-Pico adopts an ultra-simplified circuit design and therefore does not include an onboard download circuit. To burn firmware, connect a USB-TTL downloader as shown below.
Reflow Soldering Temperature Curve for the Shell
Schematics
PinMap
SK6812, Button
ESP32-PICO-D4 G27 G39
SK6812 DI /
Button / SW
Model Size
PCB
Datasheets
Softwares
UiFlow1
USB Driver
Before flashing, you need to connect a USB-TTL downloader board to the Stamp-Pico according to the silkscreen. Install the corresponding driver for the downloader on your PC.
The easiest way is to purchase the Stamp-Pico kit with downloader. The cable order matches STAMP-PICO, allowing direct plug-in flashing without wiring. M5 currently provides downloaders with two driver chips: CP210X (for CP2104) / CH9102 (for CH9102). After extracting the package, choose the installer matching your OS bitness. (If you are unsure which USB chip your device uses, install both drivers.)
Driver Name Applicable Chip Download Link
CP210x_VCP_Windows CP2104 Download
CP210x_VCP_MacOS CP2104 Download
CP210x_VCP_Linux CP2104 Download
Video
Product Comparison
