Atom Motion
SKU:K053
Atom Motion is a servo & DC motor driving solution designed for the ATOM main control series. It integrates an STM32 control chip and uses I2C communication for control. It provides 4 channels for servo control and 2 channels for DC motor interfaces. It comes with a built-in 16340/18350 lithium battery (700mAh capacity). It features two HY2.0-4P expansion interfaces, with 4 pins exposed, allowing for the connection of external sensors and expansion devices. It is suitable for multi-servo/motor control scenarios, such as multi-axis servo robotic arm control or car motor driving.
  • 4-channel servo control
  • 2-channel DC motor control
  • Removable lithium battery
  • Magnetic back design
  • Independent power switch
  • 2 HY2.0-4P expansion interfaces
  • 1 x Atom-Lite
  • 1 x Atomic Motion Base
  • 1 x M2 hex wrench
  • 1 x M2*8 cup head machine screw
  • 1 x USB Type-C cable (20cm)
  • DC motor car control
  • Servo robotic arm control
MCU STM32F030F4P6
Communication Interface I2C Communication @0x38
Removable lithium battery Model: 16340/18350, Capacity: 700mAh
Motor interface pin spacing 2.54mm
Full load steering current 3A
Single-channel motor peak current 1A
Single-channel servo peak current 0.4A
Product Size 24 x 72 x 21mm
Product weight 40g
Package Size 95 x 65 x 25mm
Gross weight 77.1g
Schematics
PinMap
PIN LEFT RIGHT PIN
1 3V3
I2C_SCL 2 3 PORT.C
I2C_SDA 4 5 PORT.C
5V 6 7 PORT.B
GND 8 9 PORT.B
Datasheets
Softwares
UiFlow1
Protocol
  • Protocol Type: I2C
  • I2C Address: 0x38
Function Reg Address Length Data Range R/W
Servo (1~4) 0x00~0x03 1Byte MSB angle: 0-180 R/W
Servo (1~4) 0x10, 0x12, 0x14, 0x16 2Byte MSB pulse: 500-2500 R/W
Motor (1~2) 0x20~0x21 1Byte MSB speed: -127-127 R/W
EasyLoader
Atom Motion Test Easyloader download /
Video
  • Controlling 4 servos and 2 DC motors, pressing the ATOM center button to switch the DC motor rotation direction
  • Atom Motion UiFlow Example (Lego car construction)
