Station-485
SKU:K123
Station-485 is a versatile industrial-grade programmable embedded controller. It uses the Espressif ESP32 as the main control chip, integrates a Wi-Fi solution, and is equipped with a dual-core low-power Xtensa® 32-bit LX6 microprocessor with a clock speed of up to 240MHz. It comes with 16MB Flash and integrates a 240 x 135 1.14-inch full-color HD IPS display panel, physical button panel, rich peripherals, and two sets of six expansion interfaces. It also features low-power sleep/timed wake-up functionality.
It supports multiple power supply methods, including USB Type-C, PWR485, and an internal rechargeable battery (battery socket reserved on the board). The board integrates a high-power-density fully integrated boost DC/DC converter SCT12A0DHKR, ensuring stability in complex application scenarios.
This controller is suitable for various application scenarios such as industrial field control, smart buildings, multi-channel data acquisition nodes, and developer prototyping.
Tutorial
This tutorial will introduce how to control the Station device via the UIFlow graphical programming platform
This tutorial will introduce how to control the Station device via the UiFlow2 graphical programming platform
This tutorial will introduce how to program and control the Station device using the Arduino IDE.
  • Interactive Design:
    • 1.14-inch IPS display panel
    • 3 programmable physical buttons
    • 1 power button
    • 7 programmable RGB LEDs
  • Power Design:
    • Input:
      • Integrated 9~24V to 5V DC/DC SY8303 step-down circuit
      • AXP192 power management chip
    • Output:
      • Each interface (5 Grove, 1 USB-A) uses an electronic switch SGM2553D for independent on/off control
      • 6 Grove interfaces use INA3221 for voltage/current monitoring, and USB-A uses INA199 for current monitoring
      • Integrated high-power-density fully integrated boost DC/DC converter SCT12A0DHKR
    • Low Power Consumption:
      • Integrated RTC BM8563 for low-power sleep/timed wake-up
  • Port Design:
    • 6 Grove expansion interfaces
      • Port A1/A2 share power and signal pins
      • Port B1/B2/C1/C2 have independent power and signal pins
    • PWR485 interface (4-wire HT3.96)
      • RS485
      • 9~24V power input
    • USB Type-A is for power output only, with no signal pins
  • Structural Design:
    • DIN rail
    • Magnetic
    • Wall-mounted
    • Screws
    • Cable ties
  • Development Platform
    • UiFlow1
    • Arduino IDE
    • ESP-IDF
    • PlatformIO
  • 1 x Station-485
  • 1 x USB Type-C cable (100cm)
  • 1 x Hex key
  • 1 x I/O Sticker
  • IoT controller
  • Multi-channel data acquisition
  • IoT product prototyping
  • DIY projects
Specification Parameters
SoC ESP32-D0WDQ6-V3@dual-core processor, main frequency 240MHz
DMIPS 600
SRAM 520KB
Flash 16MB
Wi-Fi 2.4 GHz Wi-Fi
USB Power 5V@1A
RS485 Power 9 ~ 24V@1A
Host Ports USB Type-C x 1, HY2.0-4P (I2C+I/O+UART) x 6, Full-Size USB Type-A (OUTPUT), PWR485
LED SK6812 x 7
Buttons Power button, physical buttons x 3
IPS LCD Screen 1.14"@240 x 135 ST7789V2
RTC BM8563
PMU AXP192
Voltage/Current Monitor INA3221 + INA199
USB Chip CH9102F
TTL-RS485 SP3485
Step-Down Chip SY8303
DC/DC Boost SCT12A0DHKR
Power Distribution Switch SGM2553D
Antenna 2.4G 3D antenna
Base Screw Specification M2 x 8 hex socket screws
Internal PCB Reserved Interfaces Battery interface (1.25mm-4P), USB line interface (1.25mm-4P)
Housing Material ABS+PC
Product Size 88.0 x 65.0 x 35.0mm
Product Weight 63.6g
Package Size 104.0 x 73.0 x 54.5mm
Gross Weight 105.3g
Learn
Power On/Off Operation:
Power On: Click the central power button
Power Off: Long press the central power button for 4 seconds
Schematics
PinMap
Button
ESP32-D0WDQ6-V3 G37 G38 G39
Buttons BUTTON A BUTTON B BUTTON C
Color TFT Screen
Driver Chip: ST7789v2 Resolution: 135 x 240 @1.14"
ESP32-D0WDQ6-V3 G5 G15 G18 G19 G23
AXP192 Chip
LCD CS(Chip Select) RESET SCK(SCLK) RS(Date/Command) MOSI
AXP192 Chip AXP_LDO3
LCD LCD_BL
RTC
ESP32-D0WDQ6-V3 G21 G22
BM8563 SDA SCL
AXP192
AXP192 AXP_PWR
BM8563 INT
Current/Voltage Monitor
ESP32-D0WDQ6-V3 G21 G22 Control Channel
INA3221 (0x40) SDA SCL AXP_GPIO0, AXP_GPIO1
INA3221 (0x41) SDA SCL AXP_GPIO2, AXP_GPIO3, AXP_GPIO4
Internal I2C Connection
AXP192(0x34) SDA SCL
BM8563(0x51) SDA SCL
INA3221(0x40、0x41) SDA SCL
PWR485
Chip G3 G1 G2 (DC-DC 9~24V to 5V) GND
SP3485 TXD RXD Send-High Active/Receive-Low Active GND
SY8303 VIN_12V
Power Management Chip (AXP192)
RTC LCD BackLight ESP32-3.3V SK6812, INA3221, CH902F
LDO1 LDO3 DC-DC1
USB to Serial
ESP32-D0WDQ6-V3 G3 G1
CH9102F TXD RXD
HY2.0-4P
PORT.A1 GND 5V G32 G33
PORT.A2 GND 5V G32 G33
PORT.B1 GND 5V G25 G35
PORT.B2 GND 5V G26 G36
PORT.C1 GND 5V G14 G13
PORT.C2 GND 5V G17 G16
Power Consumption Test
Operating Current (LCD, LED, Wi-Fi On) Standby Current (LCD, LED On)
161mA 105mA
Model Size
module size
Datasheets
Softwares
UiFlow1
USB Driver
Click the link below to download the driver for your operating system. After extracting the compressed file, select the installation package corresponding to your operating system's bit version. (CH9102_VCP_SER_MacOS v1.7 may report an error during installation, but it is actually installed successfully. Ignore the error.) If you encounter issues such as timeout or "Failed to write to target RAM" when downloading the program, try reinstalling the device driver.
Easyloader
Easyloader Download Link Remarks
Station-485 Test Easyloader Download /
Product Comparison
Station-485 Station-BAT
Equipped with PWR485 (RS485 + Power Input) Onboard MPU6886, can be equipped with two 18650 batteries (parallel)
To compare information on the Station series products, you can visit the Product Selection Table, check the target products, and get the comparison results. The selection table covers key information such as core parameters and functional features, and supports comparison of multiple products simultaneously.
