Cardputer
SKU:K132
Cardputer is a card-sized computer designed for engineers, featuring an M5StampS3 as the main controller.
For human-machine interaction, it is equipped with a 56-key keyboard and a 1.14-inch TFT screen. The onboard SPM1423 digital MEMS microphone supports recording or wake-up functions, while the built-in cavity speaker enables audio playback. An infrared emitter provides IR control capability.
Expansion is provided via a Grove port for custom sensor connection, and a microSD card slot allows storage expansion.
Power is supplied by an internal 120 mAh battery plus a 1400 mAh battery in the base, greatly extending battery life. Integrated charge, boost and buck circuits are included.
The magnetic base can attach to metal surfaces and offers LEGO-compatible mounting holes.
Cardputer is ideal for rapid functional prototyping, industrial control, smart-home systems and more.
Disassembly Notice
When removing the StampS3 module from the front panel, be very careful with the FPC cable and connector on the back. Gently pull it out to avoid damaging the screen connector. Refer to the operation video in the Cardputer Accessory Kit.
Tutorial
This tutorial shows you how to program and control the Cardputer using the Arduino IDE.
This tutorial shows you how to control the Cardputer using the UiFlow2 graphical programming platform.
  • M5StampS3 microcontroller
  • 56-key keyboard
  • 1.14-inch TFT screen
  • Cavity speaker and SPM1423 digital MEMS microphone
  • Infrared emitter for IR control
  • HY2.0-4P port for connecting and expanding I2C sensors
  • microSD card slot for storage expansion
  • Built-in 120 mAh battery plus 1400 mAh battery in the base for long battery life
  • Magnetic base with LEGO-compatible mounting holes
  • Development Platform
    • Arduino IDE
    • ESP-IDF
    • PlatformIO
  • 1 x Cardputer
  • 1 x Hex Key L-Shape 2.0mm (For M2 Screw)
  • Rapid functional verification and prototyping
  • Industrial control and automation
  • Smart-home control systems
  • Data acquisition and sensor monitoring
  • Embedded system development and education
  • Wireless communication and IoT projects
SoC ESP32-S3FN8@Dual-core Xtensa LX7, 240MHz
USB USB OTG, USB Serial/JTAG
Flash 8MB
Wi-Fi 2.4 GHz Wi-Fi
Storage SD Card
Keyboard 56 keys (4 x 14)
Buttons 1 x Reset button + 1 x User button
Grove 1 x HY2.0-4P
Battery Capacity 120 mAh + 1400 mAh (in base)
Screen ST7789V2 @ 1.14 inch, 240 x 135 px
Speaker 8 Ω @ 1 W I2S @ NS4168
Microphone MEMS microphone @ SPM1423
IR Emitting Distance 410 cm at ∠0°, 170 cm at ∠45°, 66 cm at ∠90°
Sleep Current DC 4.2 V @ 0.26 µA
Working Current IR mode: DC 4.2 V @ 255.6 mA; Keyboard mode: DC 4.2 V @ 165.7 mA
Operating Temperature 0 ~ 40 °C
Product Size 84.0 x 54.0 x 19.7 mm
Product Weight 92.3 g
Package Size 145.7 x 95.0 x 20.7 mm
Gross Weight 109.9 g
Learn
Download Mode
If you want to enter download mode, set the power switch on the side of the Cardputer to the OFF position, then press and hold the G0 button before powering on. After supplying power to the device, release the button, and the device will enter download mode.
schematics
Charging Notes
When charging the Cardputer, please switch the power to ON.
Schematics
PinMap
SPM1423 MIC
ESP32-S3FN8 G46 G43 3.3V GND
SPM1423 DAT CLK VCC GND
microSD Socket
ESP32-S3FN8 G12 G14 G40 G39
microSD Socket CS MOSI CLK MISO
ST7789V2 & RGB LED
ESP32-S3FN8 G38 G33 G34 G35 G36 G37
ST7789V2 DISP_BL RST RS DAT SCK CS
RGB LED VDD
Keyboard & Battery Detect
ESP32-S3FN8 G10 G7/G6/G5/G4/G3/G15/G13 G11/G9/G8
Battery Detect (ADC) ADC
74HC138 Y7~Y0 A2/A1/A0
Speaker & IR
ESP32-S3FN8 G41 G42 G43 G44
NS4168 (Speaker) BCLK SDATA LRCLK
IR TX
HY2.0-4P
PORT.CUSTOM GND 5V G2 G1
Model Size
module size
Structure
Datasheets
Softwares
PlatformIO
[env:m5stack-cardputer]
platform = espressif32@6.7.0
board = esp32-s3-devkitc-1
framework = arduino
upload_speed = 1500000
build_flags =
    -DESP32S3
    -DCORE_DEBUG_LEVEL=5
    -DARDUINO_USB_CDC_ON_BOOT=1
          -DARDUINO_USB_MODE=1
lib_deps =
    M5Cardputer=https://github.com/m5stack/M5Cardputer
ESP-IDF
Easyloader
Easyloader Download Note
Cardputer User Demo Easyloader download /
Video
  • Cardputer Introduction
Product Comparison
To compare information on the Cardputer series products, you can visit the Product Selection Table, check the target products, and get the comparison results. The selection table covers key information such as core parameters and functional features, and supports comparison of multiple products simultaneously.
