SKU: K134
DinMeter is an embedded development board that adheres to the 1/32DIN standard, featuring a 1.14-inch ST7789 screen and a built-in rotary encoder with buttons for precise knob position recording. Additionally, it includes an RTC circuit, an onboard buzzer, and buttons for device interaction and wake-up alerts. The product is designed to support DC input ranging from 6V to 36V and includes a lithium battery interface and charging circuit to accommodate various power supply needs. The reserved PORT.A and PORT.B interfaces allow for easy expansion of I2C and GPIO devices. This product is suitable for applications such as parameter measurement and detection, smart home control, IoT projects, smart wearables, access control, industrial control, and educational maker projects.
Specification | Parameter |
SoC | ESP32-S3FN8@Xtensa LX7, 8M-Flash, WIFI, USB-OTG function |
Wide voltage input range | 6-36V |
Screen driver | ST7789V2 |
Screen resolution | 135 x 240 |
Charging current | 100mA |
Grove load capacity | PORT-A load capacity: DC 5V/Max:220mA PORT-B load capacity: DC 5V/Max:220mA |
Standby current (battery-powered standby current) | DC4.2V/38.4uA |
Battery holder specification | 1.25mm-2p |
Power supply methods | USB/DC power supply/battery |
Operating temperature | 0 ~ 40°C |
Product dimensions | 53.0 x 30.0 x 32.0mm |
Product weight | 17.8g |
Package dimensions | 136.0 x 93.0 x 23.0mm |
Gross weight | 47.0g |
Power Supply Methods | Three power supply methods: USB/DC/BAT
Din Size Standard
ESP32-S3FN8 | G12 | G11 | G40 | G41 | G3 | G42 |
RTC8563 | SCL | SDA | ||||
ENCODER | B | A | ||||
BEEP | beep | |||||
BUTTON (ENCODER) | BTN(WAKE) |
ESP32-S3FN8 | G7 | G6 | G4 | G5 | G8 | G9 |
ST7789V2 | CS | SCK | RS | MOSI | RESET | BL |
HY2.0-4P | Black | Red | Yellow | White |
PORT.A | GND | 5V | G13 | G15 |
PORT.B | GND | 5V | G2 | G1 |
Easyloader | Download Link | Notes |
DinMeter User Demo Easyloader | download | / |
