StickS3
SKU:K150
StickS3 is a compact and high-performance programmable controller designed for remote control and IoT applications. It is powered by the ESP32-S3-PICO-1-N8R8 main control chip, supporting 2.4 GHz Wi-Fi wireless communication, with built-in 8MB Flash and 8MB PSRAM to meet diverse application development needs, delivering excellent performance and scalability.
For human–machine interaction, it features a 1.14" LCD display, a 6-axis IMU sensor, and programmable buttons. The audio system adopts the ES8311 mono audio codec, combined with a high-sensitivity MEMS microphone and AW8737 power amplifier, enabling clear audio capture and high-fidelity audio output, empowering voice recognition and interactive experiences. It also integrates IR transmitter and receiver, a 250mAh lithium battery, making it suitable for smart home control, AI voice assistants, and IoT project development scenarios.
Tutorial
This tutorial introduces how to program and control the StickS3 device using the Arduino IDE.
This tutorial will introduce how to control the StickS3 device through the UiFlow2 graphical programming platform.
This tutorial introduces how to use the StickS3 device to flash the Xiaozhi voice assistant firmware via M5Burner and build a personal voice assistant application.
This tutorial introduces how to flash the ESP-Claw firmware onto the StickS3, enabling users to quickly configure their StickS3 as an intelligent terminal capable of AI interaction, hardware programming, and automation control.
EXT_5V_EN Input Power Supply Notice
The device 5V power interface can be configured as DC 5V output / input mode. The interface defaults to input mode. In this state, DC 5V power can be supplied via the Grove interface, the EXT_5V on the top Hat2-Bus, or the 5VIN interface. When configured to output mode, power input is only allowed via USB or the 5VIN on the top Hat2-Bus. Do not supply power through other output interfaces, otherwise there is a risk of short circuit and device damage.
Infrared Reception Notes
1.The infrared receiving and decoding of StickS3 must use the ESP32 RMT peripheral and does not support receiving and decoding via GPIO method.
2. When using the infrared receiver function, the speaker amplifier must be turned off; otherwise, reception will not work properly. The operation method can be referenced in the tutorial
3. Ensure that the transmitter and receiver are aligned as directly as possible, and keep a distance of no less than 30 cm between them. If the distance is too short, abnormal reception may occur.
Speaker Volume Notice
When powered by battery (USB not connected), it is recommended to keep the speaker volume below 75% to avoid unexpected device reboot caused by excessive power consumption.
Abnormal Device Noise
Early batches of StickS3 may produce slight abnormal noise after startup, which does not affect functional use.
Precautions for Use
Do not disassemble the product enclosure without authorization. Disassembly may damage the antenna PFC circuit and affect normal device operation.
  • Integrated ESP32-S3-PICO-1-N8R8 main controller
  • 8MB Flash and 8MB PSRAM
  • ES8311 mono audio codec chip
  • MEMS microphone + speaker
  • Integrated IR transmitter + IR receiver
  • Magnetic back design
  • Expansion interfaces:
    • Expandable Hat2 bus (2.54-16P)
    • HY2.0-4P interface
  • Development Platform
    • Arduino
    • ESP-IDF
    • PlatformIO
  • 1 x StickS3
  • Smart home control
  • AI voice assistant
  • IoT project development
SoC ESP32-S3-PICO-1-N8R8 @ Xtensa® 32-bit LX7 dual-core processor, clock frequency 240MHz
Flash 8MB
PSRAM 8MB Octal
IMU BMI270
Wi-Fi 2.4 GHz Wi-Fi
Display Model: ST7789P3
Resolution: 135x240
Input Power USB Type-C DC 5V
Audio Codec ES8311: 24-bit resolution, I2S protocol
Microphone MEMS microphone, Signal-to-Noise Ratio (SNR): 65 dB
Speaker AW8737 power amplifier + 8Ω@1W 2011 cavity speaker
Battery Capacity 250mAh
Grove Load Capacity No load: 5V
Max: 4.88V@0.38A
Power Consumption Power off: 4.2V@14.02uA
L1 state: 4.2V@52.47uA
L2 state: 4.2V@102.40uA
L3A state: 4.2V@36.69mA
Full load: 4.2V@519.02mA
Product Size 48.0 x 24.0 x 15.0mm
Product Weight 20.0g
Package Size 65.0 x 25.0 x 15.0mm
Gross Weight 22.4g
Learn
Compatibility Notes
StickS3 is structurally incompatible with the following Hat series products: Hat Mini JoyC (SKU: U156), Hat Mini EncoderC (SKU: U157), and Hat 18650C (SKU: U080).
Download Mode
Connect the device with a USB cable and press and hold the reset button on the side of the device. When the internal green LED flashes, the device has successfully entered download mode.
Button Operation Instructions
  • Long press: Enter download mode
  • Double click: Power off
  • Single click: Power on / Reset
EXT_5V_EN
In the default initialization of M5Unified, EXT_5V_EN is disabled. This operation turns off the power supply to the Grove, Hat EXT_5V interfaces, and IR TX/RX, and switches them to input mode. In this state, an external 5V power input is required for IR TX/RX to operate properly. For use cases without an external power supply, you can re-enable the EXT_5V output mode through the following API to restore power to IR TX/RX.
M5.Power.setExtOutput(true); // EXT_5V OUTPUT
// M5.Power.setExtOutput(false); // EXT_5V INPUT
IMU Triaxial Direction Schematic Diagram
Schematics
PinMap
LCD
ESP32‑S3 G39 G40 G45 G41 G21 G38
ST7789P3 MOSI SCK RS CS RST BL
IMU & M5PM1
ESP32‑S3 G48 G47
BMI270 (0x68) SCL SDA
M5PM1 (0x6e) SCL SDA
M5PM1
M5PM1 G0 G1 G2 G3 G4
Battery Charge PYG0_CHG_STAT
ESP32-S3 PYG1_IRQ
L3B Power PYG2_L3B_EN
Speaker PYG3_SPK_Pulse
IMU INT PYG4_IMU_INT
Audio
ESP32‑S3 G18 G14 G17 G15 G16 G48 G47
ES8311 (0x18) MCLK DOUT BCLK LRCK DIN SCL SDA
Button
ESP32‑S3 G11 G12
KEY1 Input
KEY2 Input
IR
ESP32‑S3 G46 G42
IR IR_TX IR_RX
HY2.0-4P
  • PORT.A
PORT.CUSTOM GND 5V G9 G10
Hat2-Bus
PIN LEFT RIGHT PIN
GND 1 2 G5
EXT_5V 3 4 G4
Boot 5 6 G6
G1 7 8 G7
G8 9 10 G43
BAT 11 12 G44
3V3_L2 13 14 G2
5V_IN 15 16 G3
Model Size
Structure
Datasheets
Softwares
Quick Start
Protocol
Other
PlatformIO
[env:m5stack-sticks3]
platform = espressif32@6.12.0
board = esp32-s3-devkitc-1
framework = arduino
board_build.arduino.partitions = default_8MB.csv
board_build.arduino.memory_type = qio_opi
build_flags =
    -DESP32S3
    -DBOARD_HAS_PSRAM
    -mfix-esp32-psram-cache-issue
    -DCORE_DEBUG_LEVEL=5
    -DARDUINO_USB_CDC_ON_BOOT=1
    -DARDUINO_USB_MODE=1
lib_deps =
    M5PM1=https://github.com/m5stack/M5PM1
Video
Product Comparison
If you need to compare information for Stick series products, you can visit the Product Selector, select the target products, and obtain the comparison results. The selector covers key information such as core parameters and functional features, and supports simultaneous comparison of multiple products.
