PaperDIY Assembly Kit
SKU:K159
PaperDIY Assembly Kit is a DIY e-paper development board kit that includes a main control board, an e-paper display, and a 140mAh lithium battery, with hardware assembly completed by the user. The main control board uses the ESP32-S3R8 core, featuring a standard 16MB Flash + 8MB PSRAM memory combination and supporting 2.4 GHz Wi-Fi connectivity. The kit is equipped with a 4.7" e-paper display with a resolution of 960×540, supporting 16-level grayscale display. It has an onboard battery connector, a microSD card slot, and a USB Type-C interface. The open structure allows users to design their own peripheral structures, making it suitable for building desktop information displays, electronic labels, maker DIY projects, and embedded hardware development experiments.
Tutorial
This tutorial will introduce how to control the PaperDIY device using the UiFlow2 graphical programming platform.
  • ESP32-S3R8 core:
    • 16MB Flash
    • 8MB PSRAM
    • 2.4 GHz Wi-Fi
  • 4.7" e-paper display, 960×540 resolution
  • 16-level grayscale display
  • Onboard DC 3.7V battery connector, includes a 140mAh lithium battery
  • microSD card slot
  • Low-power power management design
  • 1 x PaperDIY (e-paper display + main control board + 140mAh battery + acrylic screen pressure plate)
  • Electronic DIY creative projects
  • DIY desktop information display
  • Custom electronic labels, signage
  • Hardware development learning and experiments
SoC ESP32-S3-WROOM-1-N16R8 @ Xtensa® 32-bit LX7 dual-core processor, 240MHz
Flash 16MB
PSRAM 8MB Octal
Wi-Fi 2.4 GHz Wi-Fi
E-Paper Model: ET047TC1
540 x 960@4.7"
Grayscale: 16 levels
Expansion Storage microSD
Power Supply 3.7V battery, USB Type-C (DC 5V), 5V pad
Power Management M5PM1
Button 1x Power Button (ON / OFF / RESET / BOOT) + 2x User Button
Battery Capacity: 140mAh
Connector: SH1.0-2P
Expansion Interface 2x FPC 0.5mm-12P
Operating Power Consumption 4.2V@40.95mA (peak up to 161mA)
Product Size 115.3 x 62.5 x 5.5mm
Product Weight 26.4g
Package Size 137.0 x 78.0 x 19.0mm
Gross Weight 50.0g
Learn
Power On/Off
  • Single click the power button: Power on / Reset
  • Double-click the power button: Power off
Download Mode
Connect the device to a computer via a USB Type-C data cable. Press and hold the bottom power button until the red LED blinks, then release it. The device enters download mode.
Schematics
PinMap
E-Paper
ESP32-S3 G6 G14 G7 G12 G9 G11 G8 G10
ET047TC1 EPD_DB0 EPD_DB1 EPD_DB2 EPD_DB3 EPD_DB4 EPD_DB5 EPD_DB6 EPD_DB7
ESP32-S3 G16 G15 G13 G18 G17 G46
ET047TC1 EPD_XCL EPD_XLE EPD_XSTL EPD_CKV EPD_SPV BST_EN
The power supply to the e-paper display and its driver circuit is controlled via PYG2 (EPD_PWR) of the M5PM1 power management chip, and G46 (BST_EN) controls the enable of the e-paper boost circuit.
microSD
ESP32-S3 G40 G47 G39 G38 G48
microSD CARD_MISO CARD_CS CARD_SCK CARD_MOSI CARD_DET
Button
ESP32-S3 G4 G3
KEY KEY1(ButtonA) KEY2(ButtonB)
The power button is connected to the PY_BTN (BTN_PU) pin of the M5PM1 power management chip.
M5PM1
ESP32-S3 G42 G41
M5PM1 SYS_SCL SYS_SDA
M5PM1 DCDC3V3_EN_PP CHG_EN_PP BAT_ADC_EN_PP
3V3_L2 PY_MPWR_EN
Charge CHG_EN
Battery BAT_ADC_EN
M5PM1 5VIN_ADC_IN BAT_ADC_IN
Voltage Monitoring USB_ADC BAT_ADC
M5PM1 PYG0 PYG1 PYG2 PYG3 PYG4
FPC - I2S PY_G0
FPC - SPI PY_G1 PY_G4
E-Paper EPD_PWR
Charge CHG_STAT
  • PYG0(PY_G0): FPC - I2S interface expansion signal
  • PYG1(PY_G1): FPC - SPI interface switch signal
  • PYG2(EPD_PWR): Power enable for the e-paper display and its driver circuit
  • PYG3(CHG_STAT): Charging status
  • PYG4(PY_G4): FPC - SPI interface reset signal
FPC - I2S
FPC 0.5mm-12P PaperDIY
Pin1 G5 (SCLK)
Pin2 GND
Pin3 PY_G0
Pin4 G41 (SYS_SDA)
Pin5 G42 (SYS_SCL)
Pin6 GND
Pin7 G2 (LRCK)
Pin8 G1 (DSDIN)
Pin9 G0 (DOUT)
Pin10 G45 (MCLK)
Pin11 3V3_AU
Pin12 3V3_AU
FPC - SPI
Pin1 G39 (SCK)
Pin2 GND
Pin3 G21 (CS)
Pin4 G38 (MOSI)
Pin5 G40 (MISO)
Pin6 GND
Pin7 PY_G4 (RST)
Pin8 G43 (BUSY)
Pin9 G44 (IRQ)
Pin10 PY_G1 (SW)
Pin11 3V3_L2
Pin12 3V3_L2
Model Size
Structure
Datasheets
Softwares
ESP-IDF
Other
Video
Product Comparison
Product Compare PaperDIY Complete Kit
Assembly Type Hardware assembly completed at the factory, with pre-installed 3D printed enclosure User assembles by themselves, open structure
3D Printed Enclosure Standard PLA 3D printed enclosure, enclosure model is open-source, supports reprinting and custom modification ❌️ (Open structure, supports user-designed peripheral structures)
Package Contents E-paper display + main control board + 140mAh battery + acrylic screen pressure plate (pre-installed 3D printed enclosure) E-paper display + main control board + 140mAh battery + acrylic screen pressure plate
Main Control / Memory ESP32-S3R8, 16MB Flash + 8MB PSRAM ESP32-S3R8, 16MB Flash + 8MB PSRAM
E-Paper 4.7" ET047TC1, 540 x 960, 16-level grayscale 4.7" ET047TC1, 540 x 960, 16-level grayscale
Battery 140mAh 140mAh
