Tough
SKU:K034
Tough is an industrial-grade programmable embedded controller. It is equipped with the Espressif ESP32 main control chip, which integrates Wi-Fi and features a dual-core low-power Xtensa® 32-bit LX6 microprocessor with a main frequency of up to 240MHz. The board includes 8MB PSRAM + 16MB Flash memory, a 2.0-inch 320x240 full-color IPS display, a high-sensitivity capacitive touch panel, and a variety of peripheral and expansion interfaces. The fully enclosed casing offers dustproof and waterproof protection, ensuring stable circuit operation even in complex industrial environments. This controller is suitable for scenarios such as industrial field control, smart buildings, and outdoor data acquisition nodes.
Tutorial
This tutorial introduces how to control the Tough device using the UiFlow1 graphical programming platform.
This tutorial introduces how to control the Tough device using the UiFlow2 graphical programming platform.
This tutorial introduces how to program and control the Tough device using the Arduino IDE.
Do not immerse the casing in water. This product is not designed for immersion protection.
- Developed based on ESP32, supports Wi-Fi
- 16MB Flash + 8MB PSRAM
- Onboard microSD slot
- Built-in speaker, I2S power amplifier
- IPS display, capacitive touch
- AXP192 power management chip
- BM8563-RTC clock, supports RTC timer wake-up
- Integrated DC 6 ~ 24V to 5V DC-DC step-down circuit
- Dustproof and waterproof design, UV-resistant plastic
- Supports FreeRTOS
- Development Platform
- UiFlow1
- UiFlow2
- Arduino IDE
- ESP-IDF
- PlatformIO
- 1 x Tough
- 1 x USB Type-A data cable (1m, pre-installed on the device)
- 1 x 2.5mm hex wrench
- 1 x 1.5mm hex wrench
- 1 x 1.25-2P single-ended terminal wire
- 1 x 1.25-4P single-ended terminal wire
- 1 x Waterproof O-ring
- 1 x HY2.0-4P connector
- IoT Controller
- Data Acquisition
- Timer Controller
| Specification | Parameter |
| SoC | ESP32-D0WDQ6-V3 @ Xtensa® 32-bit LX6 dual-core processor, clock frequency 240MHz |
| SRAM | 520KB |
| Flash | 16MB |
| PSRAM | 8MB Quad |
| Wi-Fi | 2.4 GHz Wi-Fi |
| Input Voltage | USB (5V@500mA) / RS485 interface power input (6 ~ 24V@1A) |
| Interfaces | USB Type-C x 1, HY2.0-4P x 4 (RS485 / I2C / GPIO / UART interfaces) |
| IPS LCD | 2.0" 320 x 240 ILI9342C full-color display, max brightness 853 nits |
| Touch Controller | CHSC6540 |
| Speaker Setup | NS4168 16-bit I2S amplifier + 1W speaker |
| RTC Clock Chip | BM8563 |
| PMU | AXP192 |
| USB Chip | CH9102 USB-TTL serial/programming interface |
| microSD Slot | Supports memory cards up to 16GB |
| Antenna | 3D Wi-Fi antenna |
| Casing Material | UV-resistant plastic |
| Product Size | 76.0 x 58.0 x 41.6mm |
| Product Weight | 117.5g |
| Package Size | 101.0 x 83.0 x 46.0mm |
| Gross Weight | 151.0g |
Schematics
PinMap
LCD & microSD
| ESP32-D0WDQ6-V3 | G38 | G23 | G18 | G5 | G15 |
| ILI9342C | MISO | MOSI | SCK | CS | DC |
| AXP192 | AXP_IO4 | AXP_LDO3 | AXP_LDO2 |
| ILI9342C | RST | BL | PWR |
| ESP32-D0WDQ6-V3 | G38 | G23 | G18 | G4 |
| microSD | MISO | MOSI | SCK | CS |
Cap.Touch
| ESP32-D0WDQ6-V3 | G21 | G22 | G39 |
| CHSC6540 (0x2E) | SDA | SCL | INT |
| AXP192 | AXP_IO4 |
| CHSC6540 | RST |
MIC & NS4168
| ESP32-D0WDQ6-V3 | G12 | G0 | G2 | G34 |
| NS4168 | BCLK | LRCK | DATA | |
| MIC | | CLK | | DATA |
| AXP192 | AXP_IO2 |
| NS4168 | SPK_EN |
RTC-BM8563
| BM8563 (0x51) | SDA | SCL |
RS485
| M5-Bus | G27 | G19 | (DC-DC 6 ~ 24V->5V) | GND |
| RS485 | RX | TX | 6 ~ 24V | GND |
HY2.0_RESET
| M5-Bus | EN | G25 | VCC | GND |
| RESET | EN | G25 | 5V | GND |
HY2.0-4P
| HY2.0-4P | Black | Red | Yellow | White |
| PORT.A | GND | 5V | G32 | G33 |
| PORT.B | GND | 5V | G26 | G36 |
| PORT.C | GND | 5V | G14 | G13 |
M5-Bus
| FUNC | PIN | LEFT | RIGHT | PIN | FUNC |
| GND | 1 | 2 | G35 | ADC |
| GND | 3 | 4 | G36 | ADC |
| GND | 5 | 6 | RST | EN |
| MOSI | G23 | 7 | 8 | G25 | DAC |
| MISO | G38 | 9 | 10 | G26 | DAC |
| SCK | G18 | 11 | 12 | 3V3 | |
| RXD0 | G3 | 13 | 14 | G1 | TXD0 |
| RXD2 | G13 | 15 | 16 | G14 | TXD2 |
| SYS_SDA | G21 | 17 | 18 | G22 | SYS_SCL |
| EXT_SDA | G32 | 19 | 20 | G33 | EXT_SCL |
| GPIO | G27 | 21 | 22 | G19 | GPIO |
| GPIO | G2 | 23 | 24 | G0 | GPIO |
| NC | 25 | 26 | G34 | ADC |
| NC | 27 | 28 | 5V | |
| NC | 29 | 30 | BAT | |
Model Size
Structure
Datasheets
Softwares
UiFlow1
USB Driver
USB Driver
Click the link below to download and install the driver for your operating system. If you encounter issues such as failed program downloads (e.g., timeout or "Failed to write to target RAM"), try reinstalling the device driver.
| Driver Name | Supported Chip | Download Link |
| CH9102_VCP_SER_Windows | CH9102 | Download |
| CH9102_VCP_CDC_Windows | CH9102 | Download |
| CH9102_VCP_MacOS_v1.7 | CH9102 | Download |
CH9102_VCP_MacOS_v1.7 may display system error messages during installation, but the installation is actually complete and can be ignored.
Video
Product Comparison
To compare information on the controller series products, you can visit the Product Selection Table, check the target products, and get the comparison results. The selection table covers key information such as core parameters and functional features, and supports comparison of multiple products simultaneously.
