Cardputer Mesh Kit
SKU:K152
Cardputer Mesh Kit is a portable communication terminal kit that integrates LoRa Mesh networking with global positioning capabilities. The kit centers around the Cardputer-Adv core controller and the Cap LoRa-1262 communication expansion module.
Cardputer-Adv is a card-sized portable programmable controller built on the Stamp-S3A module (based on ESP32-S3FN8). It features a 1.14" LCD screen and a 56-key compact keyboard for convenient on-site information display and command input. A built-in 1500mAh lithium battery ensures extended standalone operation. The device integrates an ES8311 audio codec, MEMS microphone, 1W speaker, and 3.5mm audio jack for voice interaction and audio output. Additional features include a 6-axis IMU BMI270, an infrared emitter, a microSD card slot, an HY2.0-4P Grove interface, and an EXT 2.54-14P expansion bus. The chassis supports magnetic attachment and is compatible with LEGO mounting holes.
Cap LoRa-1262 serves as the communication expansion module of the kit. It connects to the Cardputer-Adv via the EXT 2.54-14P interface, drawing power and control signals directly from the host — plug-and-play with no additional configuration required. The module is built around the SX1262 LoRa solution, supporting the 868 ~ 923 MHz band with a receive sensitivity of -147 dBm and a transmit power of +22 dBm. An RP-SMA external antenna and RF shielding ensure reliable long-range communication with strong interference immunity. An integrated AT6668 GNSS module with a built-in ceramic antenna supports multi-constellation positioning including GPS, BeiDou, GLONASS, and Galileo. The module also includes an HY2.0-4P interface for connecting external sensors.
Cardputer Mesh Kit comes pre-installed with Meshtastic firmware, making it ready to use out of the box — no complex development required to join a LoRa Mesh network. The Cardputer-Adv and Cap LoRa-1262 work seamlessly together for easy configuration and intuitive positioning, making the kit well-suited for outdoor communications, node deployment, location tracking, and industrial inspection.
Tutorial
This tutorial explains how to use Meshtastic with the Cardputer Mesh Kit.
This tutorial introduces how to program and control the Cardputer-Adv using the UiFlow2 graphical programming platform.
This tutorial introduces how to program and control the Cardputer-Adv using Arduino IDE.
Core Controller (Cardputer-Adv):
  • Stamp-S3A core module (ESP32-S3FN8)
  • 56-key keyboard with 160gf comfortable key actuation
  • 1.14" LCD screen (240 x 135px)
  • ES8311 audio codec + NS4150B amplifier + 1W speaker + MEMS microphone
  • 3.5mm audio output jack
  • 6-axis IMU BMI270
  • Infrared emitter
  • microSD card slot
  • Built-in 1500mAh lithium battery
  • HY2.0-4P Grove interface + EXT 2.54-14P expansion bus
  • Magnetic attachment on the back, compatible with LEGO mounting holes
Communication Expansion Module (Cap LoRa-1262):
  • LoRa modulation technology + GNSS global positioning system
  • Operating frequency: 868 ~ 923 MHz
  • Receive sensitivity as low as -147 dBm, transmit power +22 dBm
  • External RP-SMA antenna interface with built-in ceramic GPS antenna
  • Supports GPS / QZSS / BD2 / BD3 / GAL / GLO multi-constellation positioning
  • HY2.0-4P expansion interface (for external sensor connection)
  • Development Platform
    • Arduino
    • ESP-IDF
    • PlatformIO
  • 1 x Cardputer-Adv (Green Back Shell Version)
  • 1 x Cap LoRa-1262
  • 1 x LoRa Rubber Duck Antenna (RP-SMA Connector)
  • 2 x M2 * 4mm cap head machine screw
  • 1 x Safety Warning Sticker
  • Remote GPS Tracker
  • Outdoor Mesh Networking
  • Rapid Prototyping and Functional Verification
  • Industrial Control and Automation
  • Smart City / Smart Home
  • In-Vehicle Positioning and Navigation
  • Embedded System Development and Learning
SoC ESP32-S3FN8 @ Xtensa® 32-bit LX7 dual-core processor, clock frequency 240MHz
Flash 8MB
External Storage microSD
Display ST7789V2 @ 1.14", 240 x 135px
Keyboard 56 keys (4 x 14), 160gf actuation force
Expansion Interface HY2.0-4P + EXT 2.54-14P
IR 1 x Infrared Emitter
Audio Codec ES8311
Speaker NS4150B amplifier + 8Ω @ 1W speaker
Microphone MEMS microphone, SNR: 65 dB
IMU BMI270
Battery Capacity 1500mAh
Operating Current DC 4.2V @ 120.2mA
LoRa Module SX1262
LoRa Frequency Range 868 ~ 923 MHz
Programmable Bitrate LoRa: up to 62.5kbps
FSK: up to 300kbps
LoRa Antenna Size: 108 x 9.3mm, Connector: RP-SMA (female), Gain: 3dBi
LoRa Transmit Power +22dBm
LoRa Receive Sensitivity -147dBm (low data rate mode)
LoRa Operating Current DC 5V @ 163.4mA
Supported Modulation FSK / GFSK / MSK / LoRa
GPS Module ATGM336H-6N @ AT6668
GPS Communication Interface UART, default 115200bps @ 8N1
Supported GNSS Systems GPS / QZSS / BD2 / BD3 / GAL / GLO
GPS Channels 50 channels
GPS Positioning Accuracy <1.5m (CEP50)
GPS Update Rate Up to 10Hz
GPS Time to First Fix Cold start: 23s, Hot start: 1s
Product Size Cardputer-Adv: 84.0 x 54.0 x 19.6mm
Cap LoRa-1262: 84.0 x 24.0 x 15.2mm
Product Weight 77.2g
Package Size 103.0 x 90.0 x 25.0mm
Gross Weight 127.2g
Learn
Cardputer-Adv Download Mode
Set the side power switch on the Cardputer-Adv to OFF. Hold down the G0 key, then power on the device. Release the key and the device will enter download mode.
RGB LED Power Supply
RGB LED Power Supply Instructions
The device uses Stamp-S3A as its main controller. To optimize overall power consumption, Stamp-S3A adds an independent electronic switch for the RGB LED power supply compared with the previous Stamp-S3. Before controlling the RGB LED in software, set GPIO38, which controls this switch, to a high level.
Charging Notes
Switch the power switch to ON before charging.
Assembly Instructions
The Cap LoRa-1262 connects to the Cardputer-Adv via the EXT 2.54-14P interface:
  1. Turn the Cardputer-Adv upside down and locate the EXT 2.54-14P interface (14-pin female header).
  2. Align the corresponding male header pins of the Cap LoRa-1262 with the interface and gently press until fully seated.
  3. Screw the LoRa rubber duck antenna into the RP-SMA antenna connector on the Cap LoRa-1262.
Device Registration
The Cardputer Mesh Kit has been officially licensed by Meshtastic. You can register it as an authorized device by following the steps below:
  1. Ensure that the device has been flashed with the Meshtastic firmware by referring to the Flashing Tutorial (the factory firmware is already pre-flashed).
  2. Ensure that the Cardputer-Adv is properly connected to the Cap LoRa-1262 expansion.
  3. Connect the Cardputer Mesh Kit to your computer via a USB Type-C cable, and visit the M5 Meshtastic Device registration page.
  4. On the registration webpage, click the Connect Device option, select the device port, then click Connect, and wait for the prompt indicating that the registration is complete.
After successful device registration, the Meshtastic app page will display the device model and authorization mark:
Only devices in the Cardputer Mesh Kit set can be registered. Other Cardputer/-Adv devices are not eligible for Meshtastic authorization registration. If registration fails, please contact M5Stack official after-sales support.
PinMap
Cardputer-Adv EXT 2.54-14P
FUNC PIN LEFT RIGHT PIN FUNC
RESET G3 1 2 5VIN
INT G4 3 4 GND
BUSY G6 5 6 5VOUT
SCK G40 7 8 G8 I2C_SDA
MOSI G14 9 10 G9 I2C_SCL
MISO G39 11 12 G13 UART_RX
CS G5 13 14 G15 UART_TX
Cardputer-Adv LCD
Stamp-S3A G38 G33 G34 G35 G36 G37
ST7789V2 DISP_BL RST RS DAT SCK CS
RGB LED PWR_EN
Cardputer-Adv Audio
Stamp-S3A G8 G9 G41 G46 G43 G42
ES8311 SDA SCL SCLK ASDOUT LRCK DSDIN
Cardputer-Adv IMU
Stamp-S3A G8 G9
BMI270 SDA SCL
Cardputer-Adv IR
Stamp-S3A G44
IR TX TX
Cardputer-Adv Battery
Stamp-S3A G10
Battery ADC
Cardputer-Adv Keyboard
Stamp-S3A G8 G9 G11
TCA8418RTWR SDA SCL INT
Cardputer-Adv microSD
Stamp-S3A G12 G14 G40 G39
microSD CS MOSI CLK MISO
Cardputer-Adv HY2.0-4P
PORT.CUSTOM GND 5V G2 G1
Cap LoRa-1262 Cap-Bus
PIN LEFT RIGHT PIN
GPS_TX 1 14 LoRa_NSS
GPS_RX 2 13 LoRa_MISO
SCL 3 12 LoRa_MOSI
SDA 4 11 LoRa_SCK
5V_OUT 5 10 LoRa_BUSY
GND 6 9 LoRa_IRQ
5V_IN 7 8 LoRa_RST
Cardputer-Adv G3 G4 G6 G40 G14 G39 G5
Cap LoRa-1262 (LoRa) RST IRQ BUSY SCK MOSI MISO NSS
Cardputer-Adv G13 G15
Cap LoRa-1262 (GPS) GPS-RX GPS-TX
Cardputer-Adv G8 G9
Cap LoRa-1262 (PI4IOE5V6408) SDA SCL
Cap LoRa-1262 (HY2.0-4P) SDA SCL
PI4IOE5V6408 P0
FM8625H SX_ANT_SW
The following steps are required to initialize the LoRa module:
  • Enable the RF antenna switch: set P0 of the PI4IOE I/O expander to HIGH
Cap LoRa-1262 HY2.0-4P
PORT.A GND 5V SDA SCL
Schematics
Model Size
Structure
Datasheets
Softwares
PlatformIO
[env:m5stack-cardputer-mesh-kit]
platform = espressif32@6.12.0
board = esp32-s3-devkitc-1
framework = arduino
upload_speed = 1500000
build_flags =
    -DESP32S3
    -DCORE_DEBUG_LEVEL=5
    -DARDUINO_USB_CDC_ON_BOOT=1
          -DARDUINO_USB_MODE=1
lib_deps =
    M5Cardputer=https://github.com/m5stack/M5Cardputer
    RadioLib=https://github.com/jgromes/RadioLib
    TinyGPSPlus=https://github.com/m5stack/TinyGPSPlus
Easyloader
Easyloader Download
Cardputer-Adv Factory Firmware Easyloader download
Video
Version Change
Release Date Product Change
2026.7.13 Battery capacity changed from 1750mAh to 1500mAh
