ToughC5
SKU:K162
ToughC5 is an outdoor waterproof IoT controller. Built around the ESP32-C5HR8 core module, it features a RISC-V 32-bit single-core processor running at 240MHz, with 16MB Flash and 8MB PSRAM. It supports 2.4 & 5 GHz dual-band Wi-Fi 6, BLE 5, and IEEE 802.15.4 (Zigbee, Thread) multi-protocol connectivity, meeting access requirements across a variety of network scenarios. It integrates a 2.0" color LCD display (resolution 320 × 240) with a highly sensitive capacitive touch panel, and includes an onboard buzzer, microSD card slot, and RX8130CE real-time clock. The housing is made of PC + ABS (with UV powder), providing resistance to UV aging. Internally, the device offers I2C, GPIO, UART, and RS485 expansion interfaces as well as a battery connector, which are routed externally through the M12 connectors on both sides of the body for additional expansion. The system uses M5PM1 + M5IOE1 for multi-level power management and supports low-power wake-up. The device provides standard water and dust resistance (not designed for immersion), making it suitable for a wide range of applications such as outdoor edge data collection, smart buildings, and industrial gateways.
Tutorial
This tutorial introduces how to control the ToughC5 device using the UiFlow2 graphical programming platform.
This tutorial will introduce how to program and control the ToughC5 device via Arduino IDE.
  • ESP32-C5HR8 Core Main Controller
    • 16MB Flash
    • 8MB PSRAM
    • 2.4 & 5 GHz Dual-Band Wi-Fi 6
    • Supports BLE 5 / IEEE 802.15.4 (Zigbee, Thread)
  • Human-Machine Interaction
    • 2.0" LCD Capacitive Touch Screen, 320 x 240 Resolution
    • Onboard Passive Buzzer
  • Clock and Power
    • Onboard RX8130CE RTC Clock
    • RTC Clock Battery (CR2032 Coin Cell Battery DC 3V@220mAh)
    • M5PM1 + M5IOE1 Multi-Level Power Management
    • DC 3.7V Battery Interface
  • Interfaces and Expansion
    • USB Type-C for Debugging / Program Download
    • Internal Interface Expansion Board: HY2.0-4P x 4 (RS485/I2C/GPIO/UART)
    • 2x M12 Body Cable Routing Holes
    • microSD Card Slot
  • Easy Wiring, Magnetic Mounting
  • PC + ABS (with UV Powder) Housing Material, Resistant to UV Aging
  • 1 x ToughC5
  • 1 x USB Type-C Cable (1m)
  • 1 x Hex Key L-Shape 2.5mm (For M3 Screw)
  • 1 x 1.25-2P Single-Head Terminal Cable
  • 1 x 1.25-4P Single-Head Terminal Cable
  • 1 x Waterproof O-Ring
  • Outdoor edge data collection
  • Outdoor industrial field control
  • Outdoor environment gateway monitoring
  • Field low-power sensor terminals
SoC ESP32-C5HR8 @ RISC-V® 32-bit single-core processor, up to 240MHz
Flash 16MB
PSRAM 8MB Quad
Wireless Connectivity 2.4 & 5 GHz dual-band Wi-Fi 6 / BLE 5 / IEEE 802.15.4 (Zigbee, Thread)
Input Voltage USB (DC 5V@500mA) / RS485 interface input power (DC 6 ~ 24V@1A) / Battery (DC 3.7V)
Interface USB Type-C x 1, HY2.0-4P x 4 (RS485/I2C/GPIO/UART)
RS485 Signal Conversion RS485 @ SP485EEN-L/TR
LCD Screen 2.0" @ 320 x 240 ILI9342C IPS panel, maximum brightness 853nit
Touch Panel Driver IC CHSC6540
RTC RTC Chip: RX8130CE
RTC Battery Spec: DC 3V@220mAh, Size 20 x 3.2mm
Battery Socket Spec: SH1.0-2P
Battery Connector Spec MX1.25-2P
Buzzer Onboard passive buzzer @8530
FPC Antenna 2.4 GHz & 5 GHz, IPEX‑2nd Gen, 14.3x5.3mm, cable length 50mm
Power Management M5PM1 + M5IOE1
Power Consumption Shutdown state: DC 4.2V@10.41uA
Full load state: DC 4.2V@320mA
Housing Material PC + ABS (with UV powder)
Product Size 75.9 x 58.0 x 42.5mm
Product Weight 119.0g
Package Size 101.0 x 83.0 x 46.0mm
Gross Weight 161.4g
Learn
Power On/Off
  • Single click the power button: Power on / Reset
  • Double-click the power button: Power off
Enter Download Mode
Under normal circumstances, the device can be flashed with programs directly via the USB cable. During development and debugging, if an abnormal program flash occurs, the housing can be removed and the power button long-pressed to force entry into download mode.
Schematics
PinMap
LCD
ESP32-C5HR8 G25 G26 G7 G8 G9
ILI9342C CS DC MOSI MISO SCK
The screen enable is controlled via PYG5 (PYB_LCD_EN) of the M5IOE1 expansion chip, and the screen reset is controlled via PYG4 (PYB_LCD_RST).
microSD
ESP32-C5HR8 G7 G8 G9 G10
microSD MOSI MISO SCK CS
The microSD card slot enable is controlled via PYG6 (PYB_TF_EN) of the M5IOE1 expansion chip, and PYG14 (PYB_TF_DET) detects the microSD card insertion status.
PYG14_PYB_TF_DET Status
LOW Inserted
HIGH Not Inserted
Touch
ESP32-C5HR8 G2 G3
CHSC6540 SDA SCL
The touch screen interrupt signal input is captured via PMG0 (PM_TP_INT) of the M5PM1 power management chip, and PYG2 (PM_TP_RST) controls the touch driver chip reset.
I2C Devices (TP & M5IOE1 & M5PM1)
ESP32-C5HR8 G2 G3
CHSC6540 (0x2E) SDA SCL
M5IOE1 (0x4F) SDA SCL
M5PM1 (0x6E) SDA SCL
RS485
ESP32-C5HR8 G23 G24
SP485EEN-L/TR RS485_RX RS485_TX
HY2.0-4P
PORT.A GND 5V G2 G3
PORT.B GND 5V G6 G1
PORT.C GND 5V G12 G11
PORT.RS485 GND DC 6 ~ 24V INPUT A B
M5-Bus
FUNC PIN LEFT RIGHT PIN FUNC
GND 1 2 G0 ADC
GND 3 4 G1 ADC
GND 5 6 RST EN
MOSI G7 7 8 G4 DAC
MISO G8 9 10 G6 DAC
SCK G9 11 12 3V3
RXD0 G12_PC_RX 13 14 G11_PC_TX TXD0
RXD2 G12_PC_RX 15 16 G11_PC_TX TXD2
Int SDA G2 17 18 G3 Int SCL
PORT.A SDA G2 19 20 G3 PORT.A SCL
GPIO G23 21 22 G24 GPIO
GPIO G27 23 24 G28 GPIO
NC 25 26 G5 GPIO
NC 27 28 5V
NC 29 30 BAT
M5PM1
M5PM1 PYG0 PYG1 PYG2 PYG3 PYG4
TOUCH PM_TP_INT PM_TP_RST
ESP32-C5HR8 PM_G1_IRQout
RTC PM_RTC_INT
BUZZER PM_BUZZER_EN
  • PYG0(PM_TP_INT): Touch screen interrupt wake-up signal
  • PYG1(PM_G1_IRQout): Interrupt output signal connected to ESP32-C5
  • PYG2(PM_TP_RST): Touch screen reset
  • PYG3(PM_RTC_INT): RTC interrupt wake-up signal
  • PYG4(PM_BUZZER_EN): Buzzer drive signal
M5IOE1
M5IOE1 PYG1 PYG3 PYG4 PYG5 PYG6 PYG10 PYG14
CHARGE PYB_CHG_PROG PYB_CHG_STAT
LCD PYB_LCD_RST PYB_LCD_EN PYB_BL_EN
microSD PYB_TF_EN PYB_TF_DET
  • PYG1(PYB_CHG_PROG): Charge current control
  • PYG3(PYB_CHG_STAT): Charge status detection
  • PYG4(PYB_LCD_RST): LCD screen reset
  • PYG5(PYB_LCD_EN): LCD screen enable
  • PYG10(PYB_BL_EN): LCD screen backlight drive signal
  • PYG6(PYB_TF_EN): microSD card slot enable
  • PYG14(PYB_TF_DET): microSD card slot insertion status detection
PYG1_CHG_PROG CHARGE CURRENT
LOW 650mA
High Impedance 180mA (Default)
Model Size
Datasheets
Softwares
PlatformIO
[env:m5stack-toughc5]
platform = https://github.com/pioarduino/platform-espressif32.git#55.03.37
upload_speed = 1500000
monitor_speed = 115200
build_type = debug
framework = arduino
board = esp32-c5-devkitc-1
build_flags =
    -DBOARD_HAS_PSRAM
    -DCORE_DEBUG_LEVEL=5
    -DARDUINO_USB_CDC_ON_BOOT=1
    -DARDUINO_USB_MODE=1
lib_deps =
    M5Unified = https://github.com/M5Stack/M5Unified
    M5GFX = https://github.com/M5Stack/M5GFX
Other
Video
Product Comparison
Product Comparison ToughC5 ToughC5 Tough Tough
SoC ESP32-C5HR8 @ RISC-V 32-bit single-core processor, up to 240MHz ESP32-D0WDQ6-V3 @ Xtensa 32-bit LX6 dual-core processor, up to 240MHz
SRAM 384 KB HP SRAM + 16 KB LP SRAM 520KB
Flash 16MB 16MB
PSRAM 8MB Quad 8MB Quad
Wireless Connectivity 2.4 & 5 GHz dual-band Wi-Fi 6 / Zigbee / Thread (802.15.4) 2.4 GHz Wi-Fi
Antenna FPC antenna, 2.4G & 5G, IPEX-2nd Gen, 14.3 x 5.3mm, cable length 50mm 3D Wi-Fi antenna
LCD Screen 2.0" 320 x 240 ILI9342C full-color display, maximum brightness 853nit 2.0" 320 x 240 ILI9342C full-color display, maximum brightness 853nit
Touch Panel Driver IC CHSC6540 CHSC6540
Audio Onboard passive buzzer @8530 NS4168 16bit I2S amplifier + 1W speaker
PMU M5PM1 AXP192
IO Expansion M5IOE1 peripheral control system /
RTC Clock Chip RX8130CE BM8563
