StackFlow AI Platform
Module LLM Applications
CV Vision Application
Vision Language Model (VLM)
Large Language Model (LLM)
Voice Assistant
M5Module-LLM Arduino API
M5Module-LLM Arduino Driver Library API Documentation.
M5ModuleLLM Class
M5ModuleLLM is used to initialize the Module LLM and provides internal members for quick initialization of various LLM units, making it easier to build applications according to your needs.
class M5ModuleLLM {
public:
    bool begin(Stream * targetPort);
    bool checkConnection();
    void update();
    m5_module_llm::ApiSys sys;
    m5_module_llm::ApiLlm llm;
    m5_module_llm::ApiAudio audio;
    m5_module_llm::ApiTts tts;
    m5_module_llm::ApiTts melotts;
    m5_module_llm::ApiKws kws;
    m5_module_llm::ApiAsr asr;
    m5_module_llm::ApiAsr yolo;
    m5_module_llm::ApiVad vad;
    m5_module_llm::ApiWhisper whisper;
    m5_module_llm::ApiDepthAnything depthanything;
    m5_module_llm::ModuleMsg msg;
    m5_module_llm::ModuleComm comm;
private:
begin
Function Prototype:
bool begin(Stream* targetPort);
Function Description:
  • Initializes the Module LLM UART interface configuration.
Parameters:
  • Stream* targetPort:
    • Pass the Serial pointer.
Return Value:
  • bool:
    • true: Initialization successful
    • false: Initialization failed
checkConnection
Function Prototype:
  • Sends the sys.ping command to check the connection status of the Module LLM.
Parameters:
  • None
Return Value:
  • bool:
    • true: Module responds
    • false: No response from module
update
Function Prototype:
void update();
  • Pulls the Module LLM UART response data, this API should be included in the Loop and executed continuously.
Parameters:
  • None
Return Value:
  • None
ApiSys Class
The internal member ApiSys sys of M5ModuleLLM is used to control the SYS unit, enabling operations like system reset.
ping
Function Prototype:
int ping();
Parameters:
  • None
Return Value:
  • int:
    • MODULE_LLM_OK / Error Code
reset
Function Prototype:
int reset(bool waitResetFinish = true);
  • Sends the sys.reset command to reset the software service.
Parameters:
  • bool waitResetFinish:
    • true: Blocks and waits for reset to finish
    • false: Performs reset without blocking
Return Value:
  • int:
reboot
Function Prototype:
int reboot();
  • Sends the sys.reboot command to reboot the system.
Parameters:
  • None
Return Value:
  • int:
ApiAudio Class
Note: This function has been deprecated in version 1.3 and later, and is now automatically configured internally.
The internal member ApiAudio audio of M5ModuleLLM is used to control the initialization and configuration of the Audio unit.
setup
Function prototype:
String setup(ApiAudioSetupConfig_t config = ApiAudioSetupConfig_t(), String request_id = "audio_setup");
Function description:
  • Initializes the Audio unit and activates the system sound card. (This feature must be enabled before using KWS and TTS)
Parameters:
ApiAudioSetupConfig_t config:
  • LLM unit initialization configuration:
  • String request_id:
    • Session ID, default can be used.
struct ApiAudioSetupConfig_t {
    int capcard      = 0;
    int capdevice    = 0;
    float capVolume  = 0.5;
    int playcard     = 0;
    int playdevice   = 1;
    float playVolume = 0.15;
Parameter Description Input Values
capcard Microphone sound card index Default sound card: 0
capdevice Microphone device index Onboard silicon microphone: 0
capVolume Input volume 0.0~10.0 (1<volume increases gain, default is 0.5)
playcard Speaker sound card index Default sound card: 0
playdevice Speaker device index Onboard speaker: 1
playVolume Output volume 0.0~10.0 (1<volume increases gain, default is 0.5)
Return Value:
  • String:
    • audio_work_id: audio unit work_id
ApiCamera Class
The internal member ApiCamera camera of M5ModuleLLM is used to control the initialization and configuration of the Camera unit.
setup
Function prototype:
String setup(ApiCameraSetupConfig_t config = ApiCameraSetupConfig_t(), String request_id = "camera_setup");
  • Initializes the Camera unit and activates camera input. (This feature must be enabled before using UVC)
Parameters:
ApiCameraSetupConfig_t config:
  • Camera unit initialization configuration:
struct ApiCameraSetupConfig_t {
    String response_format = "camera.raw";
    String input           = "/dev/video0";
    bool enoutput          = false;
    int frame_width        = 320;
    int frame_height       = 320;
input UVC index "/dev/video0"
enoutput Whether to output image data via serial Enable: true
Disable: false
frame_width Image width 320
frame_height Image height 320
Return Value:
  • String:
    • camera_work_id: camera unit work_id
ApiKws Class
The internal member ApiKws kws of M5ModuleLLM is used to control the initialization and configuration of the KWS unit.
setup
Function Prototype:
String setup(ApiKwsSetupConfig_t config = ApiKwsSetupConfig_t(), String request_id = "kws_setup",
             String language = "en_US");```
**Function Description:**
- Initializes the KWS unit and configures the wake-up keyword.
**Parameters:**
ApiKwsSetupConfig_t config:
- KWS unit initialization configuration:
- String request_id:
    - Session ID, default can be used.
```cpp
struct ApiKwsSetupConfig_t {
    String kws             = "HELLO";
    String model           = "sherpa-onnx-kws-zipformer-gigaspeech-3.3M-2024-01-01";
    String response_format = "kws.bool";
    String input           = "sys.pcm";
    bool enoutput          = true;
model Conversion Model English Model: "sherpa-onnx-kws-zipformer-gigaspeech-3.3M-2024-01-01"
Chinese Model: "sherpa-onnx-kws-zipformer-wenetspeech-3.3M-2024-01-01"
kws KWS Wake-up Word Text No mixing of Chinese and English; English must be in uppercase
enoutput Enable UART Output Enable: true
Disable: false
Return Value:
  • String:
    • kws_work_id: KWS unit work_id
ApiVad Class
The internal member ApiVad vad of M5ModuleLLM is used to control the initialization and configuration of the VAD unit.
setup
Function Prototype:
String setup(ApiVadSetupConfig_t config = ApiVadSetupConfig_t(), String request_id = "vad_setup");
  • Initializes the VAD unit.
Parameters:
ApiVadSetupConfig_t config:
  • VAD unit initialization configuration:
    String model           = "silero-vad";
    String response_format = "vad.bool";
    String input           = {"sys.pcm", "kws.1000"};
model Conversion Model Model: "silero-vad"
input Input KWS Wake-up Input: "kws.xxx" (input the KWS unit's work_id)
Onboard Microphone Input: "sys.pcm"
UART Stream Input: "vad.wav.stream.base64"
Disable: false
Return Value:
  • String:
    • vad_work_id: VAD unit work_id
ApiAsr Class
The internal member ApiAsr asr of M5ModuleLLM is used to control the initialization and configuration of the ASR unit.
setup
Function Prototype:
String setup(ApiAsrSetupConfig_t config = ApiAsrSetupConfig_t(), String request_id = "asr_setup",
  • Initializes the ASR unit and enables speech-to-text functionality.
Input Parameters:
ApiAsrSetupConfig_t config:
  • ASR unit initialization configuration:
    • Session ID, the default can be used.
struct ApiAsrSetupConfig_t {
    String model           = "sherpa-ncnn-streaming-zipformer-20M-2023-02-17";
    String response_format = "asr.utf-8.stream";
    String input           = ["sys.pcm", "kws.1000"];
    float rule1            = 2.4;
    float rule2            = 1.2;
    float rule3            = 30.0;
model Conversion model English Model: "sherpa-ncnn-streaming-zipformer-20M-2023-02-17"
Chinese Model: "sherpa-ncnn-streaming-zipformer-zh-14M-2023-02-23"
response_format Output format Normal output: "asr.utf-8"
Stream output: "asr.utf-8.stream"
input Input KWS wake input: "kws.xxx" (input kws unit work_id)
Onboard microphone input: "sys.pcm"
UART stream input: "asr.wav.stream.base64"
rule1 Timeout for unrecognized content wake Unit: seconds
rule2 Maximum recognition interval Unit: seconds
rule3 Maximum recognition timeout Unit: seconds
enoutput Enable UART output Enable: true
Disable: false
Return Value:
  • String:
    • asr_work_id: ASR unit work_id
ApiWhisper Class
The internal member ApiWhisper whisper of M5ModuleLLM is used to control the initialization and configuration of the Whisper unit.
setup
Function Prototype:
String setup(ApiWhisperSetupConfig_t config = ApiWhisperSetupConfig_t(), String request_id = "asr_setup",
  • Initializes the Whisper unit and enables speech-to-text functionality.
Input Parameters:
ApiWhisperSetupConfig_t config:
  • Whisper unit initialization configuration:
    String model           = "whisper-tiny";
    String response_format = "asr.utf-8";
    String input           = [ "sys.pcm", "kws.1000", "vad.1001" ];
    String language        = "en";
model Conversion model Model: "whisper-tiny"
language Language used for language recognition Default: "en"
Optional: "zh", "ja"
Disable: false
Return Value:
  • String:
    • whisper_work_id: Whisper unit work_id
ApiLlm Class
The internal member ApiLlm llm of M5ModuleLLM is used to control the initialization and configuration of the LLM unit.
setup
Function prototype:
String setup(ApiLlmSetupConfig_t config = ApiLlmSetupConfig_t(), String request_id = "llm_setup");
  • Initializes the LLM unit and supports configuring the input and output data format for the LLM unit.
Parameters:
  • ApiLlmSetupConfig_t config:
    • Session ID, the default value can be used.
struct ApiLlmSetupConfig_t {
    String prompt;
    String model           = "qwen2.5-0.5B-prefill-20e";
    String response_format = "llm.utf-8.stream";
    String input           = ["llm.utf-8", "kws.1000"];
    int max_token_len      = 127;
model Model used for conversion Predefined model "qwen2.5-0.5B-prefill-20e"
response_format Output format Normal output: "llm.utf-8"
Streaming output: "llm.utf-8.stream"
input Input format ASR input: "asr.xxx" (work_id of the ASR unit)
UART input: "llm.utf-8"
KWS wake-up interruption: "kws.xxx" (work_id of the KWS unit)
max_length Configures the maximum output token length (maximum returned inference text length) Maximum value: 1023
prompt Model initialization system prompt String
Disable: false
Return Value:
  • String:
    • llm_work_id: LLM unit work ID
inference
Function prototype:
int inference(String work_id, String input, String request_id = "llm_inference");
  • Sends input data to start inference. The result will be placed in the responseMsgList container in M5ModuleLLM.msg.
Parameters:
  • String work_id:
    • The LLM unit's work ID being called
  • String input:
    • Input text
    • Session ID, used to differentiate when multiple sessions exist.
Return Value:
  • int:
inferenceAndWaitResult
Function prototype:
int inferenceAndWaitResult(String work_id, String input, std::function<void(String&)> onResult, uint32_t timeout = 5000, String request_id = "llm_inference");
  • Sends input data to start inference, blocks while waiting for the result, then calls the callback function.
Parameters:
  • String work_id:
  • String input:
    • Input text
  • void onResult(String&)
    • Callback function for inference result
  • uint32_t timeout:
    • Timeout for waiting for inference result
Return Value:
  • int:
ApiVlm Class
The internal member ApiVlm vlm of M5ModuleLLM is used to control the initialization and configuration of the VLM unit.
setup
Function prototype:
String setup(ApiVlmSetupConfig_t config = ApiVlmSetupConfig_t(), String request_id = "vlm_setup");
  • Initializes the VLM unit and supports configuring the input and output data format for the VLM unit.
Parameters:
  • ApiVlmSetupConfig_t config:
    • VLM unit initialization configuration
struct ApiVlmSetupConfig_t {
    String prompt;
    String model           = "internvl2.5-1B-ax630c";
    String response_format = "vlm.utf-8.stream";
    String input           = ["vlm.utf-8", "kws.1000"];
    int max_token_len      = 1023;
model Model used for conversion Predefined model "internvl2.5-1B-ax630c"
response_format Output format Normal output: "vlm.utf-8"
Streaming output: "vlm.utf-8.stream"
Disable: false
Return Value:
  • String:
    • vlm_work_id: VLM unit work ID
inference
Function prototype:
int inference(String work_id, String input, String request_id = "vlm_inference");
Parameters:
  • String work_id:
    • The VLM unit's work ID being called
  • String input:
    • Input text
Return Value:
  • int:
Function prototype:
                           uint32_t timeout = 5000, String request_id = "vlm_inference");
Parameters:
  • String work_id:
  • String input:
    • Input text
  • uint32_t timeout:
Return Value:
  • int:
ApiTts Class
The internal member ApiTts tts of M5ModuleLLM is used to control the initialization and configuration of the TTS unit.
setup
Function prototype:
String setup(ApiTtsSetupConfig_t config = ApiTtsSetupConfig_t(), String request_id = "tts_setup");
  • Initializes the TTS unit and enables the text-to-speech functionality.
Parameters:
  • ApiTtsSetupConfig_t config:
    • Session ID, use the default if not needed.
struct ApiTtsSetupConfig_t {
    String model           = "single_speaker_english_fast";
    String response_format = "sys.pcm";
    String input           = ["tts.utf-8.stream", "kws.1000"];
    bool enaudio           = true;
Parameter Description Input values
model Conversion model English model: "single_speaker_english_fast"
Chinese model: "single_speaker_fast"
input Input LLM input: "llm.xxx" (input LLM unit's work_id)
UART input: "tts.utf-8"
UART stream input: "tts.utf-8.stream"
KWS wake-up interrupt: "kws.xxx" (input KWS unit's work_id)
Disable: false
enaudio Enable speaker playback Enable: true
Disable: true
Return value:
  • String:
    • tts_work_id: TTS unit work_id
inference
Function prototype:
int inference(String work_id, String input, uint32_t timeout = 0, String request_id = "tts_inference");
  • Input data and start the inference conversion. After completion, the speaker will automatically play.
Parameters:
  • String work_id:
    • Work ID of the TTS unit to be called.
  • String input:
    • Input text.
  • uint32_t timeout:
    • Timeout for waiting for inference.
    • Session ID, used to distinguish between multiple sessions.
Return value:
  • int:
ApiMelotts Class
The internal member ApiMelotts melotts of M5ModuleLLM is used to control the initialization and configuration of the Melotts unit.
setup
Function prototype:
String setup(ApiMelottsSetupConfig_t config = ApiMelottsSetupConfig_t(), String request_id = "melotts_setup",
  • Initializes the Melotts unit and enables the text-to-speech functionality.
Parameters:
  • ApiMelottsSetupConfig_t config:
    • Melotts unit initialization configuration:
struct ApiMelottsSetupConfig_t {
    String model              = "melotts_zh-cn";
    std::vector<String> input = {"tts.utf-8.stream"};
model Conversion model Chinese and English model: "melotts_zh-cn"
UART input: "melotts.utf-8"
UART stream input: "melotts.utf-8.stream"
Disable: false
Disable: true
Return value:
  • String:
    • melotts_work_id: Melotts unit work_id
inference
Function prototype:
Parameters:
  • String work_id:
    • Work ID of the Melotts unit to be called.
  • String input:
    • Input text.
  • uint32_t timeout:
Return value:
  • int:
ApiYolo Class
The internal member ApiYolo yolo of M5ModuleLLM is used to control the initialization and configuration of the Yolo unit.
setup
Function prototype:
String setup(ApiYoloSetupConfig_t config = ApiYoloSetupConfig_t(), String request_id = "yolo_setup");
  • Initializes the Yolo unit and enables image detection functionality.
Parameters:
  • ApiYoloSetupConfig_t config:
    • Yolo unit initialization configuration:
struct ApiYoloSetupConfig_t {
    String model              = "yolo11n";
    String response_format    = "yolo.box.stream";
    std::vector<String> input = {"yolo.jpeg.base64"};
model Conversion model Detection model: "yolo11n"
Pose model: "yolo11n-pose"
Hand pose model: "yolo11n-hand-pose"
response_format Output format Detection output: "yolo.box.stream"
Pose output: "yolo.pose.stream"
input Input UVC input: "camera.xxx" (input camera unit's work_id)
UART stream input: "yolo.jpeg.base64.stream"
Disable: false
Return value:
  • String:
    • yolo_work_id: Yolo unit work_id
ModuleMsg Class
The internal member ModuleMsg msg of M5ModuleLLM provides a container responseMsgList used to cache various information returned from the Module LLM. Refer to the following example, where the main loop iterates to retrieve the results.
    module_llm.update();
    // Handle response msg
    for (auto& msg : module_llm.msg.responseMsgList) {
        // KWS msg
        if (msg.work_id == kws_work_id) {
            Serial.printf(">> Keyword detected\n");
        // ASR msg
        if (msg.work_id == asr_work_id) {
            if (msg.object == "asr.utf-8.stream") {
                // Parse and get asr result
                JsonDocument doc;
                deserializeJson(doc, msg.raw_msg);
                String asr_result = doc["data"]["delta"].as<String>();
                Serial.printf(">> %s\n", asr_result.c_str());
    module_llm.msg.responseMsgList.clear();
VoiceAssistant Class
M5ModuleLLM_VoiceAssistant is used to quickly create an LLM voice assistant instance, achieving a fast implementation of KWS (keyword spotting) -> ASR (speech-to-text) -> LLM (large model inference) -> TTS (text-to-speech).
  • During initialization, simply pass the M5ModuleLLM instance to the constructor, and register the corresponding event callback functions to complete the voice assistant setup.
 * SPDX-FileCopyrightText: 2024 M5Stack Technology CO LTD
 * SPDX-License-Identifier: MIT
#include <Arduino.h>
#include <M5ModuleLLM.h>
M5ModuleLLM module_llm;
M5ModuleLLM_VoiceAssistant voice_assistant(&module_llm);
/* On ASR data callback */
void on_asr_data_input(String data, bool isFinish, int index)
    M5.Display.setTextColor(TFT_GREEN, TFT_BLACK);
    M5.Display.printf(">> %s\n", data.c_str());
    /* If ASR data is finish */
    if (isFinish) {
        M5.Display.setTextColor(TFT_YELLOW, TFT_BLACK);
        M5.Display.print(">> ");
/* On LLM data callback */
void on_llm_data_input(String data, bool isFinish, int index)
    M5.Display.print(data);
    /* If LLM data is finish */
    if (isFinish) {
        M5.Display.print("\n");
    M5.Display.setTextSize(2);
    M5.Display.setTextScroll(true);
    /* Init module serial port */
    Serial2.begin(115200, SERIAL_8N1, 16, 17);  // Basic
    // Serial2.begin(115200, SERIAL_8N1, 13, 14);  // Core2
    // Serial2.begin(115200, SERIAL_8N1, 18, 17);  // CoreS3
    /* Init module */
    module_llm.begin(&Serial2);
    /* Make sure module is connected */
    M5.Display.printf(">> Check ModuleLLM connection..\n");
    while (1) {
        if (module_llm.checkConnection()) {
            break;
    /* Begin voice assistant preset */
    M5.Display.printf(">> Begin voice assistant..\n");
    int ret = voice_assistant.begin("HELLO");
    if (ret != MODULE_LLM_OK) {
        while (1) {
            M5.Display.setTextColor(TFT_RED);
            M5.Display.printf(">> Begin voice assistant failed\n");
    /* Register on ASR data callback function */
    voice_assistant.onAsrDataInput(on_asr_data_input);
    /* Register on LLM data callback function */
    voice_assistant.onLlmDataInput(on_llm_data_input);
    M5.Display.printf(">> Voice assistant ready\n");
    /* Keep voice assistant preset update */
    voice_assistant.update();
Error Code
enum ModuleLLMErrorCode_t {
    MODULE_LLM_OK                              = 0,
    MODULE_LLM_RESET_WARN                      = -1,
    MODULE_LLM_JSON_FORMAT_ERROR               = -2,
    MODULE_LLM_ACTION_MATCH_FAILED             = -3,
    MODULE_LLM_INFERENCE_DATA_PUSH_FAILED      = -4,
    MODULE_LLM_MODEL_LOADING_FAILED            = -5,
    MODULE_LLM_UNIT_NOT_EXIST                  = -6,
    MODULE_LLM_UNKNOWN_OPERATION               = -7,
    MODULE_LLM_UNIT_RESOURCE_ALLOCATION_FAILED = -8,
    MODULE_LLM_UNIT_CALL_FAILED                = -9,
    MODULE_LLM_MODEL_INIT_FAILED               = -10,
    MODULE_LLM_MODEL_RUN_FAILED                = -11,
    MODULE_LLM_MODULE_NOT_INITIALISED          = -12,
    MODULE_LLM_MODULE_ALREADY_WORKING          = -13,
    MODULE_LLM_MODULE_NOT_WORKING              = -14,
    MODULE_LLM_NO_UPDATEABLE_MODULES           = -15,
    MODULE_LLM_NO_MODULES_AVAILABLE_FOR_UPDATE = -16,
    MODULE_LLM_FILE_OPEN_FAILED                = -17,
    MODULE_LLM_WAIT_RESPONSE_TIMEOUT           = -97,
    MODULE_LLM_RESPONSE_PARSE_FAILED           = -98,
    MODULE_LLM_ERROR_NONE                      = -99,
