Unit KMeter-ISO Home Assistant Integration
Unit KMeter-ISO is an integrated K-type thermocouple sensor unit that combines sensing, isolation, and communication. It uses an STM32F030 + MAX31855KASA 14-bit thermocouple digital conversion chipset to achieve high-precision temperature acquisition and conversion.
Because the Unit KMeter-ISO is only a standalone sensor platform, an additional host device (such as Atom series, Stamp series, Stick series, Core/Basic series, etc.) is required to integrate it into Home Assistant
Get the latest configuration from ESPHome
Configure the sensor
You need to enable the I²C component in your ESPHome configuration:
yaml
1 2 3 4 5
i2c:
  sda: GPIOXX
  scl: GPIOXX
  scan: true
The GPIO pins here will vary depending on the host device used. For example, when using Atom Lite as the host:
yaml
1 2 3 4
i2c:
  sda: GPIO26
  scl: GPIO32
Unit KMeterISO configuration example
yaml
1 2 3 4 5 6 7
  - platform: kmeteriso
    temperature:
      name: "KMeterISO Temperature"
    internal_temperature:
      name: "Internal Temperature"
    update_interval: 10s
Add the sensor to Home Assistant
After adding it to the Dashboard, you can view the sensor data in Home Assistant
