This tutorial will guide you through completing the integration of Atom-Lite with Home Assistant for light control.
Settings -> Add-ons -> Add-on STORE.Show in sidebar on its management page to add it to the left navigation bar.
Click the button below to flash the firmware with one click. Follow the on-screen instructions to complete the configuration and quickly experience Atom-Lite integration with Home Assistant. For one-click flashing and subsequent configuration, please refer to the tutorial.
NEW DEVICE in the bottom right corner to create a new device.
CONTINUE button.
Atom-Lite.
Use recommended settings, then select ESP32 to enter the details page.
M5Stack-ATOM on the details page, select it, and click the NEXT button.
key and click INSTALL to enter the installation step.
Manual download to start the program compilation and wait for the compilation and installation to complete.
Atom-Lite device. Click the EDIT button to enter the yaml file editing page.
yaml file, and modify the ssid and password at the illustrated positions to your Wi-Fi account and password.esphome:
friendly_name: Atom-Lite
esp32:
board: m5stack-atom
flash_size: 4MB
framework:
type: esp-idf
logger:
api:
encryption:
key: "*********"
ota:
- platform: esphome
password: "*****************"
wifi:
ssid: "*********"
password: "***********"
ap:
ssid: "Atom-Lite Fallback Hotspot"
password: "jFsIc2XGuKRe"
captive_portal:
binary_sensor:
- platform: gpio
pin:
number: GPIO39
mode: INPUT
inverted: true
filters:
- delayed_on: 50ms
- delayed_off: 50ms
on_multi_click:
- timing:
- ON for at most 0.8s
- OFF for at most 0.5s
- OFF for at least 0.2s
then:
- logger.log: "Double Clicked"
- light.turn_on:
red: 100%
blue: 50%
green: 20%
brightness: 50%
- timing:
- ON for at least 0.8s
then:
- logger.log: "Single Long Clicked"
- light.turn_on:
green: 100%
blue: 50%
red: 30%
brightness: 100%
light:
rgb_order: GRB
pin: GPIO27
num_leds: 1
chipset: SK6812
name: "Atom RGB Light"
restore_mode: RESTORE_DEFAULT_OFF
effects:
- random:
transition_length: 1s
update_interval: 1s ESP-IDF. The original NeoPixelBus Light under Arduino does not support the ESP-IDF framework. For the new version of ESPHome, please use the ESP32 RMT LED Strip component.
SAVE button to save the yaml file first, then click the INSTALL button to start compiling the firmware and flashing.
Manual download again to start compiling the firmware and wait for completion.
DOWNLOAD button, and the flashing method selection interface will appear. Here we select Factory format to save to the local machine.
INSTALL to enter the flashing selection interface, this time select Plug into this computer, and connect the device to the computer with USB to flash.
Open ESPHome Web to enter the flashing interface.
CONNECT button first, then select the serial port device connected to the computer and connect (if no serial port appears here, please check if the hardware connection is incorrect).
INSTALL to enter the local firmware file selection interface.
INSTALL and wait for the flashing to finish.
Flashing completed:
Settings to enter the settings interface to view the device at Discovered, click ADD to add the device.
Settings to enter the settings interface and select Devices & services.
ESP in the search bar to find ESPHome, enter and select Atom-Lite.
Atom-Lite configuration page, you can see two Entities: Atom RGB Light and Atom Button. Automation is achieved by configuring various Entities to implement logic. We click the + sign to add Automations, and then follow the guide operations.
In this way, we used two entities, Atom Button and Atom RGB Light, to form an Automation. The effect of this automation is that clicking the button will toggle the light state.
Overview menu to enter the component control interface, click the edit button in the upper right corner to enter the editing interface.
By card interface, search for Light and select the Atom RGB Light entity component.
The component configuration is as follows:
The status of the RGB light will not only be reflected on the component but can also be directly controlled through the component.
