Unit ENV-IV Sensor Home Assistant Integration
This chapter introduces the configuration methods and practical steps for integrating the Unit ENV-IV sensor platform into Home Assistant.
Preparation
  1. Confirm that the sensors used support ESPHome integration:
  2. Refer to the official ESPHome documentation for the latest configuration instructions:
Unit ENV-IV is a standalone sensor platform and requires an additional main controller (such as Atom series, Stamp series, Stick series, Core/Basic series, etc.) to be integrated into Home Assistant.
Learn
  1. The I²C component needs to be enabled in the ESPHome configuration:
i2c:
  sda: GPIOXX
  scl: GPIOXX
  scan: true
The GPIO pins here will vary depending on the main controller used. For example, using Atom Lite as the main controller:
i2c:
  sda: GPIO26
  scl: GPIO32
Unit ENV-IV configuration example:
yaml
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19
  - platform: sht4x
    temperature:
    humidity:
      name: "Relative Humidity"
    address: 0x44
  - platform: bmp280_i2c
    temperature:
      name: "BMP280 Temperature"
      oversampling: 16x
    pressure:
      name: "BMP280 Pressure"
    address: 0x76
Similarly, you can calculate values such as altitude, absolute humidity, and dew point based on empirical formulas (calculation results are for reference only):
yaml
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26
  # add the following under the previous sensor declarations
  - platform: template
    lambda: |-
      const float STANDARD_SEA_LEVEL_PRESSURE = 1013.25; //in hPa, see note
      return ((id(bmp280_temp).state + 273.15) / 0.0065) *
        (powf((STANDARD_SEA_LEVEL_PRESSURE / id(bmp_pressure).state), 0.190234) - 1); // in meter
    update_interval: 15s
    icon: 'mdi:signal'
    unit_of_measurement: 'm'
  - platform: absolute_humidity
    name: "Absolute Humidity"
    temperature: sht40_temp
    humidity: sht40_humi
    lambda: |-
      return (243.5*(log(id(sht40_humi).state/100)+((17.67*id(sht40_humi).state)/
      (243.5+id(sht40_temp).state)))/(17.67-log(id(sht40_humi).state/100)-
      ((17.67*id(sht40_temp).state)/(243.5+id(sht40_temp).state))));
    unit_of_measurement: °C
    icon: 'mdi:thermometer-alert'
To accurately calculate altitude using the BMP280 pressure sensor, you must first obtain the sea level standard pressure for your location and the current day. This can be achieved by replacing the global constant STANDARD_SEA_LEVEL_PRESSURE, for example, by fetching the value in real-time from the internet or via the MQTT protocol from a fixed sensor.
Getting Started
  1. After adding it to the Dashboard, you can view the sensor data in Home Assistant.
  1. Monitor temperature change curves.
Since the BMP280 also has a temperature sensor, there will be two temperature curves here.
  1. Monitor atmospheric pressure changes.
Video
