CoreS3 Thread BR
SKU:K149
CoreS3 Thread BR is a Thread Border Router kit. The core components consist of the CoreS3 controller and the Module Gateway H2 wireless module. The CoreS3 serves as the control core of the border router, running user applications and the OpenThread protocol stack.
The CoreS3 controller uses the ESP32-S3 SoC, with an onboard memory configuration of 16MB Flash and 8MB PSRAM. It supports 2.4 GHz Wi-Fi and integrates a 2.0" touch LCD display, camera, microphone, speaker, RTC, six-axis motion sensor, and other rich peripherals. The Module Gateway H2 module integrates the ESP32-H2-MINI-1 module and supports IEEE 802.15.4 wireless communication. It acts as an OpenThread Radio Co-Processor (RCP), providing Thread packet forwarding functionality for the CoreS3 main controller. CoreS3 Thread BR is suitable for applications such as smart homes, environmental monitoring, sensor networks, and low-power wireless communication nodes, helping developers quickly perform prototype verification and product development.
CoreS3 Core Controller
- ESP32-S3
- 16MB Flash
- 8MB PSRAM
- microSD Card Slot
- 9-axis IMU Sensor: BMI270 + BMM150
- RTC: BM8563
- USB-OTG
- 0.3MP Camera GC0308
- Proximity Sensor LTR-553ALS-WA
- Audio Codec ES7210
- Dual Microphone Input
- Hi-Fi Power Amplifier AW88298 + 1W Speaker
Module Gateway H2 (RCP)
- ESP32-H2-MINI-1
- IEEE 802.15.4
- Zigbee, Thread, Matter
Base DIN
- DIN rail mounting design
- Built-in 500mAh lithium battery
- Supports DC 9 ~ 24V input power supply
- Independent power switch
- 2x HY2.-4P expansion interfaces
- 1 x CoreS3 Thread BR
- 1 x Hex Key L-Shape 2.5mm (For M3 Screw)
- 4 x Screw Clips
- 1 x DIN Rail Base Clip
- Smart Home
- Sensor Networks
| Specification | Parameter |
| SoC | ESP32-S3 @ Xtensa® 32-bit LX7 dual-core processor, clock frequency 240MHz |
| Flash | 16MB |
| PSRAM | 8MB |
| Wi-Fi | 2.4 GHz Wi-Fi |
| Touch IPS LCD | 2.0"@320 x 240 ILI9342C / ILI9342E |
| Camera | GC0308@0.3MP |
| Proximity Sensor | LTR-553ALS-WA |
| Power Management | AXP2101 |
| 6-axis IMU | BMI270 |
| 3-axis Magnetometer | BMM150 |
| RTC | BM8563 |
| Speaker | 16bits-I2S Power Amplifier AW88298@1W |
| Audio Codec | ES7210, Dual Microphone Input |
| RCP | ESP32-H2-MINI-1 @ RISC-V 32-bit Single-core, 96 MHz |
| Base DIN Battery | Charging IC: TP4057 Battery Capacity: 500mAh |
| DC Power Port | Input: DC 9–24V, compatible with DC5521 (5.5 × 2.1 mm) plug, center positive |
| Product Size | 54.0 x 54.0 x 38.1mm |
| Product Weight | 91.0g |
| Package Size | 101.0 x 64.0 x 41.0mm |
| Gross Weight | 115.7g |
Learn
IMU Triaxial Direction Schematic Diagram
Schematics
PinMap
LCD
| ESP32-S3 | G37 | G36 | G3 | G35 |
| ILI9342C / ILI9342E | MOSI | SCK | CS | DC |
Touch
| ESP32-S3 | G12 | G11 |
| FT6336U (0x38) | I2C_SYS_SDA | I2C_SYS_SCL |
IMU
| BMI270 (0x69) | I2C_SYS_SDA | I2C_SYS_SCL |
| ESP32-S3 | BMI270_ASDx | BMI270_ASCx |
| BMM150 (0x10) | BMM_SDA | BMM_SCL |
RTC
| BM8563 (0x51) | I2C_SYS_SDA | I2C_SYS_SCL |
| AXP2101 | IRQ |
| BM8563 | AXP_WAKEUP |
Audio
| ESP32-S3 | G12 | G11 | G34 | G33 | G13 | G14 | G0 |
| ES7210 (0x40) | I2C_SYS_SDA | I2C_SYS_SCL | I2S_BCK | I2S_WCK | I2S_DATO | | I2S_MCLK |
| AW88298 (0x36) | I2C_SYS_SDA | I2C_SYS_SCL | I2S_BCK | I2S_WCK | | I2S_DATI | |
ALS & PS Sensor
| LTR-553ALS-WA (0x23) | I2C_SYS_SDA | I2C_SYS_SCL |
IO Expansion (AW9523B)
| AW9523B (0x58) | I2C_SYS_SDA | I2C_SYS_SCL |
| AW9523B | P0_0 | P0_1 | P0_2 | P0_3 | P0_4 | P0_5 |
| FT6336U | TOUCH_RST | | | | | |
| Power Control | | BUS_OUT_EN | | | | |
| AW88298 | | | AW_RST | | | |
| ES7210 | | | | ES_INT | | |
| microSD | | | | | TF_SW | |
| Power Control | | | | | | USB_OTG_EN |
| AW9523B | P1_0 | P1_1 | P1_2 | P1_3 | P1_7 |
| Camera | CAM_RST | | | | |
| LCD | | LCD_RST | | | |
| Touch | | | TOUCH_INT | | |
| AW88298 | | | | AW_INT | |
| Power Control | | | | | BOOST_EN |
microSD
| ESP32-S3 | G35 | G37 | G36 | G4 |
| microSD | MISO | MOSI | SCK | CS |
Camera
| GC0308 | Camera Pin | ESP32-S3 |
| SCCB Clock | SIOC | G11 |
| SCCB Data | SIOD | G12 |
| System Clock | XCLK | -1 |
| Vertical Sync | VSYNC | G46 |
| Horizontal Reference | HREF | G38 |
| Pixel Clock | PCLK | G45 |
| Pixel Data Bit 0 | D0 | G39 |
| Pixel Data Bit 1 | D1 | G40 |
| Pixel Data Bit 2 | D2 | G41 |
| Pixel Data Bit 3 | D3 | G42 |
| Pixel Data Bit 4 | D4 | G15 |
| Pixel Data Bit 5 | D5 | G16 |
| Pixel Data Bit 6 | D6 | G48 |
| Pixel Data Bit 7 | D7 | G47 |
| Camera Reset | RESET | -1 |
| Camera Power Down | PWDN | -1 |
| Module Gateway H2 | ESP32-S3 |
| RXD | G10 |
| TXD | G17 |
| MOSI | G37 |
| MISO | G35 |
| CLK | G36 |
| CS | G13 |
| WL_ACTIVE | G0 |
| BT_PRIORITY | G5 |
| BT_ACTIVE | G6 |
| EN | G7 |
| G9 | G18 |
HY2.0-4P
| HY2.0-4P | Black | Red | Yellow | White |
| PORT.A | GND | 5V | G2 | G1 |
| PORT.B | GND | 5V | G9 | G8 |
| PORT.C | GND | 5V | G17 | G18 |
CoreS3 M5-Bus
| FUNC | PIN | LEFT | RIGHT | PIN | FUNC |
| GND | 1 | 2 | G10 | ADC |
| GND | 3 | 4 | G8 | PB_IN |
| GND | 5 | 6 | RST | EN |
| MOSI | G37 | 7 | 8 | G5 | GPIO |
| MISO | G35 | 9 | 10 | G9 | PB_OUT |
| SCK | G36 | 11 | 12 | 3V3 | |
| RXD0 | G44 | 13 | 14 | G43 | TXD0 |
| PC_RX | G18 | 15 | 16 | G17 | PC_TX |
| Int SDA | G12 | 17 | 18 | G11 | Int SCL |
| PORT.A SDA | G2 | 19 | 20 | G1 | PORT.A SCL |
| GPIO | G6 | 21 | 22 | G7 | GPIO |
| I2S_DOUT | G13 | 23 | 24 | G0 | I2S_MCLK |
| HVIN(Base DIN) | 25 | 26 | G14 | I2S_DIN |
| HVIN(Base DIN) | 27 | 28 | 5V | |
| HVIN(Base DIN) | 29 | 30 | BAT | |
Model Size
Structure
Datasheets
Softwares
ESP-IDF
Other
Videos
Version Change
| Release Date | Product Change | Note |
| 2026.8.7 | LCD driver changed from ILI9342C to ILI9342E | M5GFX library version >= 0.2.27 is required |
