StackFlow AI Platform
Module LLM Applications
CV Vision Application
Vision Language Model (VLM)
Large Language Model (LLM)
Voice Assistant
Module LLM Serial Communication Pin Switching Tutorial
Pin Switching Description
Because M5Stack's Module series products adopt a stacking design, when multiple products are used simultaneously, pin conflicts may occur. Therefore, Module LLM supports manual switching of communication pins. Since it uses serial communication, the user only needs to adjust the RX and TX pins. Depending on the connected host, you can flexibly choose the appropriate pins.
Pin Switching Position
  • Pin Mapping
When connecting Module LLM with different hosts, the selectable RX and TX pins are as follows:
Module LLM RXD TXD
Core (Basic) G16/G13/G34/G35 G17/G15/G12/G0
Core2 G13/G19/G34/G35 G14/G2/G27/G0
CoreS3 G18/G7/G14/G10 G17/G13/G6/0
Pin Switching Operation
  1. Taking the CoreS3 + Module LLM pairing as an example, by default, the factory setting uses G18 as TX and G17 as RX for communication.
  1. If you need to switch the TX pin, change it from G18 to G7. Use a blade or other sharp tool to cut the connection between the two solder pads (be careful to avoid injury), and if necessary, use a multimeter to check whether the solder pads have been cut.
  • As shown in the image below, the solder pad connection has been successfully cut:
  1. Then, use a soldering iron to solder the G7 pin.
  • The soldering result is as follows:
At this point, you have successfully switched the communication pins of CoreS3 + Module LLM: G7 for TX and G17 for RX. If you need to modify the RX pin, repeat the above steps; both TX and RX pins have four selectable options.
