AtomS3R-AI Chatbot
SKU:K147
AtomS3R-AI Chatbot is an AI voice development kit consisting of two core parts: a controller and a voice base. The controller adopts AtomS3R, which is powered by the ESP32-S3 chip and provides a generous 8MB Flash + 8MB PSRAM memory combo. It also integrates a 9-axis IMU (BMI270 + BMM150), an IR transmitter, and other rich peripherals. The voice base is the Atomic Voice Base, built on the ES8311 audio codec, delivering high-fidelity audio decoding together with microphone and speaker driving capability.
The kit supports multiple voice assistants such as XiaoZhi Voice Assistant, OpenAI Voice Assistant, and Volcano Engine Voice Assistant, enabling real-time voice interaction, custom wake-words, and low-latency recognition.
Tutorial
This tutorial will introduce how to use the AtomS3R + Atomic Voice Base hardware combination to burn the Xiaoling Voice Assistant firmware via M5Burner and build a personal voice assistant application
This tutorial introduces how to build a personal voice assistant application with the AtomS3R + Atomic Voice Base hardware combo by flashing the OpenAI Voice Assistant firmware using M5Burner.
This tutorial introduces how to build a personal voice assistant application with the AtomS3 series + Atomic Voice Base hardware combo by flashing the XiaoZhi Voice Assistant firmware using M5Burner.
  • Supports XiaoZhi Voice, OpenAI Voice Assistant, etc.
  • AI speech recognition
  • Cloud-edge collaboration & model management
  • Integrated ESP32-S3 main controller
  • 9-axis sensor system
  • Edge AI inference
  • 8MB Flash and 8MB PSRAM
  • IR transmitter control capability
  • Expandable pins and interfaces
  • Full-duplex I2S audio
  • 24-bit audio codec
  • MEMS digital microphone
  • Class-D amplifier (8 Ω @ 1 W speaker)
  • Development Platform
    • ESP-IDF
    • PlatformIO
    • Arduino
  • 1 x AtomS3R
  • 1 x Atomic Voice Base
  • Voice assistant
  • Smart home
SoC ESP32-S3-PICO-1-N8R8 @ Xtensa® 32-bit LX7 dual-core processor, clock frequency 240MHz
USB USB OTG, USB Serial/JTAG
Flash 8MB
PSRAM 8MB
Wi-Fi 2.4 GHz Wi-Fi
TFT Driver ST7735
Color IPS Resolution 128 x 128
6-Axis IMU (BMI270) Accuracy: 0.05 % (accel), 0.05 °/s (gyro) I2C Addr: 0x68
3-Axis Magnetometer (BMM150) Accuracy: 0.3 μT, mounted on BMI270, magnetometer data acquired via BMI270
IR 12.46 m transmitting distance @ 180° (unobstructed)
Expansion Interface Bottom GPIO: G5/G6/G7/G8/G38/G39 and HY2.0-4P port
Audio Codec ES8311: 24-bit resolution, I2S protocol
MEMS Microphone MSM381A3729H9BPC, SNR ≥ 65 dB
Power Amplifier NS4150B, Class-D
Speaker 2014 cavity speaker: 1 W @ 8 Ω
Operating Temperature 0 ~ 40 °C
Product Size AtomS3R: 24.0 x 24.0 x 12.9mm Atomic Voice Base: 24.0 x 24.0 x 14.14mm
Product Weight AtomS3R: 6.6g Atomic Voice Base: 6.3g
Package Size 120.0 x 65.0 x 16.0mm
Gross Weight 21.6g
Learn
BMM150 Magnetic Interference
Products with magnets may interfere with the BMM150 magnetic sensor, causing abnormal readings. When used with M5 controllers that contain magnets, remove the magnets and avoid placing the BMM150 near strong magnetic fields.
Download Mode
Connect the device to a computer via a USB Type-C data cable. Press and hold the power button until the internal green LED lights up, then release it. The green LED turns off, indicating that the device has entered download mode.
schematics
When controlling the LCD back-light, a PWM frequency of 500 Hz is recommended.
Schematics
PinMap
module size
RGB & BMI270 & IR & BUTTON
ESP32-S3-PICO-1-N8R8 G0 G45 G47 G41
LP5562 (RGB Controller) SYS_SCL SYS_SDA
BMI270 SYS_SCL SYS_SDA
IR IR_LED_DRV
BUTTON USER_BUT
BMM150
BMI270 BMI270_ASDx BMI270_ASCx
BMM150 A_SDA A_SCL
BMM150 Mounted on BMI270
The BMM150 is connected via the BMI270 Sensor Hub auxiliary I2C interface to achieve unified 9-axis sensor data acquisition.
SCREEN
ESP32-S3-PICO-1-N8R8 LP5562_W G48 G42 G21 G15 G14
0.85-Inch IPS LCD_BL DISP_RST DISP_RS SPI_MOSI SPI_SCK DISP_CS
HY2.0-4P
PORT.CUSTOM GND 5V G2 G1
Atomic Voice Base
Atomic Voice Base SCL SDA SD/DSDIN WS/LRCK ASDOUT SCK/SCLK
AtomS3R G39 G38 G5 G6 G7 G8
Model Size
Structure
Datasheets
Softwares
Quick Start
ESP-IDF
Video
