SKU:C148/K148
PowerHub is a programmable controller integrating multi-channel power management. It adopts the ESP32-S3-WROOM-1U-N16R8 main control module equipped with a dual-core Xtensa LX7 processor (up to 240MHz), supporting 2.4 GHz Wi-Fi, with 16MB Flash and 8MB PSRAM onboard. A built-in STM32G031G8U6 coprocessor, combined with multiple INA226 voltage/current detection ICs and electronic switch design, enables precise management of power states for multiple expansion interfaces, achieving accurate power consumption control and providing low-power wake-up functionality for the whole device. The USB Type-C port can be used for program download and USB OTG functions. Inside, a USB interface switch allows the bottom USB port to be switched to the front USB Type-A or USB Type-C interface for convenient expansion of USB peripherals. The device features an efficient power management system, supporting multiple power supply modes (DC power + 2S battery power + PWR485/PWR CAN input power). It is equipped with 2x HY2.0-4P Grove ports, RS485, and CAN communication interfaces, facilitating connections to various sensors and industrial control devices. Suitable for industrial automation control, smart home, and other scenarios, it provides developers with stable and reliable IoT solutions.
Tutorial
This tutorial explains how to program and control PowerHub using Arduino IDE.
This tutorial introduces the usage of PowerHub's factory firmware, including button operations, controlling interface on/off through the EZData app or web page, and methods for monitoring voltage and current data.
This article shows how to add PowerHub into your Home Assistant
  • ESP32-S3-WROOM-1U-N16R8 main control core
  • Supports low-power timed wake-up
  • USB Type-A / USB Type-C expansion interfaces
  • 2 x HY2.0-4P expansion ports
  • 2.54-16P expansion bus interface
  • RS485 communication interface (with built-in 120Ω terminal resistor switch)
  • CAN bus communication interface (with built-in 120Ω terminal resistor switch)
  • 2.4 GHz SMA mini antenna
  • Multiple power supply modes:
    • PWR485/PWR CAN input power
    • 2S battery power supply
    • DC 9 ~ 20V power supply
  • Human-machine interaction:
    • Multi-channel status indicator lights
    • 3 x physical buttons
  • Multiple mounting methods:
    • Magnetic design for mounting on metal surfaces
    • Rear cross mounting holes for wall installation
    • Lego mounting holes
    • M2 screw holes
Product Note
The PowerHub Kit is an integrated set equipped with a removable NP-F550 lithium battery, while the standard PowerHub does not include a battery and requires an external power source or separate battery purchase.
PowerHub (SKU:C148)
  • 1 x PowerHub
PowerHub Kit (SKU:K148)
  • 1 x PowerHub
  • 1 x NP‑F550 2000mAh removable battery
  • Industrial automation
  • Smart home
SoC ESP32-S3-WROOM-1U-N16R8@Dual-core Xtensa LX7 processor, up to 240MHz
MCU STM32G031G8U6
Flash 16MB
PSRAM 8MB Octal
Wi-Fi 2.4 GHz Wi-Fi
RTC RTC Chip: RX8130CE, RTC supercapacitor specification: 70000μF/3.3V, size Φ4.8×1.4mm
Expansion Ports 2 x HY2.0-4P + EXT 2.54-16P
RS485 Port Spec: HT3.96-4P, with 120Ω terminal resistor switch
Reverse power input voltage: DC 9 ~ 20V
CAN Port Spec: XT30 (2+2), with 120Ω terminal resistor switch
USB Ports 1 x USB Type-A, 2 x USB Type-C
RGB LED 8 x WS2812
Antenna Spec Size 15 x 14mm, SMA (female thread, female core) connector, 2.4 GHz band, 2dB gain, VSWR ≤1.8
Compatible Battery NP-F550/750/950, 2S lithium battery @ 7.4V
DC Power Input Voltage: DC 9 ~ 20V, spec: 5.5 x 2.1mm, polarity: inner positive, outer negative
Operating Temp. 0 ~ 40°C
Product Size 88.0 x 56.0 x 38.5mm
Product Weight PowerHub: 71.0g
PowerHub Kit (with battery): 174.8g
Package Size 110.0 x 73.0 x 42.0mm
Gross Weight PowerHub: 105.5g
PowerHub Kit (with battery): 208.2g
Interface Output Capability
Power Supply Method Output Method Output Capability
USB Power Supply (No Battery, No DC) PORT.A (Red) 200mA@4.77V
PORT.C (Blue) 300mA@4.74V
USB Type-A 400mA@4.70V
USB Type-C 300mA@4.74V
EXT 2.54-16P 5V 400mA@4.72V
RS485 410mA@11.72V
CAN 410mA@11.71V
DC Power Jack Supply (Ext.PORT Power) PORT.A (Red) 500mA@4.70V
PORT.C (Blue) 600mA@4.74V
USB Type-A 700mA@4.71V
USB Type-C 600mA@4.71V
EXT 2.54-16P 5V 800mA@4.72V
RS485 1700mA@11.57V
CAN 1700mA@11.57V
2S Battery Power Supply PORT.A (Red) 1100mA@4.72V
PORT.C (Blue) 1300mA@4.81V
USB Type-A 1300mA@4.92V
USB Type-C 1300mA@4.82V
EXT 2.54-16P 5V 1300mA@5.02V
RS485 1400mA@11.59V
CAN 1400mA@11.56V
RS485 / CAN Power Input PORT.A (Red) 390mA@4.70V
PORT.C (Blue) 570mA@4.70V
USB Type-A 600mA@4.70V
USB Type-C 520mA@4.70V
Ext.PORT_5VOUT 700mA@4.70V
Learn
Download Mode
Connect the device to the computer using a USB-C data cable, press and hold the side BtnPWR button for 3 seconds until the indicator light next to the black antenna flashes blue multiple times. At this point, the device enters download mode.
Charging Instructions
When the battery is over-discharged and its voltage drops below 6V, it enters protection mode. Before recharging, remove the battery, reset the device, reinstall it, and then charge via the device’s USB Type-C port.
During the initial charging phase, since the battery is still in protection mode, the charging chip trickle-charges with a small current. This state lasts several minutes, depending on the battery voltage level. Once the voltage rises above 6V, the chip automatically switches to normal charging mode.
Schematics
PinMap
RS485 & CAN
ESP32-S3 G8 G18 G17 G39 G40
RS485 MCU_485_TXD MCU_485_DIR MCU_485_RXD
CAN MCU_CAN_TXD MCU_CAN_RXD
ESP32-S3 G11
User Button USR_SW2 (Yellow round button)
ESP32-S3 G19 G20
USB MCU_USB_DM MCU_USB_DP
STM32G031
ESP32-S3 G45 G48 G0
STM32G031 SYS_SDA SYS_CL G0_BOOT
RGB LED & PMU Button
STM32G031 PA7 PB4 PA4 PA2
WS2812C LED_DATA LED_EN PMU_SW2 (side button) PMU_SW1 (top translucent button)
USB
STM32G031 PB3 PA15
USB_SWITCH_L1 USB_CON_LV1
USB_SWITCH_L2 USB_CON_LV2
PowerHub’s USB interface adopts a two-level switch design:
  • ESP32-S3 is directly connected to the bottom USB Type-C port of the device.
  • USB_CON_LV1: Controls ESP32-S3 USB pins connection to the bottom USB Type-C port, or routing to the USB_CON_LV2 switch.
  • USB_CON_LV2: Controls routing from USB_CON_LV1 to the front USB Type-C port or USB Type-A port.
USB Port Power Supply Note
The bottom USB Type-C port only supports input power, while the front USB Type-C / USB Type-A ports only support output power.
Power Manager
STM32G031 PA12 PA11
INA226(0x40) - USB PM_SDA PM_SCL
INA226(0x42) - PORT.A PM_SDA PM_SCL
INA226(0x43) - PORT.C PM_SDA PM_SCL
INA226(0x44) - PWRCAN PM_SDA PM_SCL
INA226(0x45) - PWR485 PM_SDA PM_SCL
INA226(0x46) - Battery PM_SDA PM_SCL
SC8721 PM_SDA PM_SCL
RX8130CE(0x32) PM_SDA PM_SCL
STM32G031 PA1 PA0 PB8 PC14 PC15 PB1 PA8 PC6
INA226_PWR nVA_EN
DC_INPUT_DETECT VIN_DET
USB_PWR OEN_USB
PORT.A_PWR OEN_GRV_R
PORT.C_PWR OEN_GRV_B
RS485_CAN_PWR OEN_PWROUT PDCDC_REFLOW
SC8721_DCDC_PWR PDCDC_EN
RS485 & CAN Port Output Power Config
When using the SC8721 buck-boost power supply for forward output, INA226_PWR must be enabled. RS485_CAN_PWR enables OEN_PWROUT for forward output, enables SC8721_DCDC_PWR, and PDCDC_REFLOW must be held low.
RS485 & CAN Port Reverse Power to Main Unit Config
In this mode, disable SC8721, set OEN_PWROUT low, and PDCDC_REFLOW high. This allows external power to backfeed to the host via the PWRCAN or PWR485 ports.
ESP32-S3 G14
EXT 2.54-16P 5V PWR OEN_5VO
STM32G031 PB0 PA6 PB5
CHARGE CHG_EN CHG_STAT
WAKE_UP nSTBY_WAKE_UP
HY2.0-4P
PORT.A GND 5V G15 G16
PORT.C GND 5V G1 G2
EXT 2.54-16P
PIN LEFT RIGHT PIN
BAT-2S 1 2 BAT-2S
HVIN 3 4 5VOUT
GND 5 6 GND
G43 7 8 RST
G44 9 10 nWKUP
G42 11 12 G7
G41 13 14 G6
G4 15 16 G5
Model Size
Datasheets
Softwares
Quick Start
ESP-IDF
PlatformIO
[env:m5stack-powerhub]
platform = espressif32@6.10.0
board = esp32s3box
framework = arduino
upload_speed = 1500000
monitor_speed = 115200
board_build.arduino.partitions = default_16MB.csv
board_build.arduino.memory_type = qio_opi
build_flags =
    -DESP32S3
    -DBOARD_HAS_PSRAM
    -DCORE_DEBUG_LEVEL=5
    -DARDUINO_USB_CDC_ON_BOOT=1
    -DARDUINO_USB_MODE=1
lib_deps =
    https://github.com/m5stack/M5Unified.git#develop
    https://github.com/m5stack/M5GFX.git#develop
Internal Firmware
Protocol
Video
  • PowerHub Product Introduction and Case Demonstration
