Product Guides
StamPLC
VAMeter
Unit RollerCAN
Display & Interaction
Tab5 Keyboard
Chain DualKey
Robotics & Maker Projects
Atom Printer
BalaC Plus
Faces Kit Gameboy
RoverC & JoyC
StampFly & Atom Joystick
AtomS3R Xiaoling Voice Assistant
This tutorial will use the AtomS3R device together with the Atomic Voice Base hardware combination. By using M5Burner to burn the Xiaoling Voice Assistant firmware, you can build a personal voice assistant application.
According to the operating system you are using, click the button below to download the corresponding M5Burner firmware burning tool, then unzip and open the application.
Software Version Download Link
M5Burner_Windows Download
M5Burner_MacOS Download
M5Burner_Linux Download
2. Firmware Burning
  1. Double-click to open the Burner tool, select the corresponding device type ATOMS3 from the menu on the left, and click Download to download the AtomS3R Xiaoling Voice Assistant firmware.
  1. After the device is connected via USB, press and hold the reset button (about 2 seconds) until the internal green LED lights up, then release it. The device is now in download mode, waiting for burning. The green LED turns off after the button is released, confirming that the device is in download mode.
  1. Click Burn, select the port corresponding to your device, then click Start and wait for the burning process to complete.
3. Wi-Fi Configuration
  1. After the device starts, it will prompt you to connect to the AP hotspot. You can connect your phone to the hotspot Xiaozhi-xxx, or visit 192.168.4.1 to enter the network configuration page.
  1. Follow the instructions on the page to complete the Wi-Fi configuration.
Once the Wi-Fi configuration is successful, the Xiaoling Voice Assistant will enter listening mode, and you can start a conversation.
4. Bind WeChat Mini Program
  1. Obtain the device verification code. Once Wi-Fi configuration is successful, the device will automatically broadcast: Please log in to the control panel to add the device and enter the verification code xxx.
  2. Search for the mini program Xiaoling Voice Assistant in WeChat, select Open Source Kit, enter the verification code broadcast by the device, and log in as prompted on the interface to bind the device.
After binding the mini program, you can view historical conversation logs.
5. Unbind Device
In the Xiaoling Voice Assistant mini program interface, click Settings → Unbind → Confirm to unbind the device.
