Product Guides
StamPLC
VAMeter
Unit RollerCAN
Display & Interaction
Tab5 Keyboard
Chain DualKey
Robotics & Maker Projects
Atom Printer
BalaC Plus
Faces Kit Gameboy
RoverC & JoyC
StampFly & Atom Joystick
M5StickC Plus2 Restore Factory Firmware
Factory Firmware
When the device encounters operational issues, you can try re-flashing the factory firmware to check if there is any hardware malfunction. Refer to the following tutorial. Use the M5Burner firmware flashing tool to flash the factory firmware onto the device.
  • Refer to the M5Burner tutorial to complete the firmware flashing tool download, and then refer to the image below to download the corresponding firmware.
2. USB Driver Installation
Driver Installation Tip
Click the link below to download the driver matching your operating system. The driver package for the CP34X (for the CH9102 version) can be downloaded and installed by selecting the installation package corresponding to your operating system. If you encounter issues with program download (such as timeout or "Failed to write to target RAM" errors), try reinstalling the device driver.
3. Port Selection
Connect the device to the computer via a USB cable. After the driver installation is complete, you can select the corresponding device port in M5Burner.
4.Burn
Click "Burn" to start the flashing process.
The effect is as shown below:
