Product Guides
StamPLC
VAMeter
Unit RollerCAN
Display & Interaction
Tab5 Keyboard
Chain DualKey
Robotics & Maker Projects
Atom Printer
BalaC Plus
Faces Kit Gameboy
RoverC & JoyC
StampFly & Atom Joystick
Module GNSS DIP Switch Explanation Document
1. Overview
To avoid pin conflicts when Module GNSS is stacked with the main unit, the module uses a DIP switch to flexibly switch the connection of key pins. Users can adjust the corresponding pin configuration based on the host they are using (such as Core/Basic, Core2, or CoreS3) to ensure stable system operation.
DIP switch illustrationDIP switch illustrationDIP switch illustration
2. DIP Switch Position and Pin Mapping
2.1 DIP Switch Position
The DIP switch is located at the specified position on the module, as shown in the diagram below:
Module appearanceDIP switch close-up
As shown in the diagram, the DIP switch is used to switch three functional pins: TXD, RXD, PPS
2.2 Pin Mapping Table
The pin mapping options for different hosts are as follows:
CORE CORE2 CORES3
PPS G34 G34 G14
G35 G35 G10
G0 G0 G0
TXD G0 G0 G0
G12 G27 G6
G15 G2 G13
G17 G14 G17
RXD G35 G35 G10
G34 G34 G14
G13 G19 G7
G16 G13 G18
Note:
  • TXD, RXD, PPS can be selected through the DIP switch to choose the specific pin to connect. For example, on Core (Basic) host:
    • PPS: Choose from G34, G35, or G0 (one of the three)
    • TXD: Choose from G0, G12, G15, or G17 (one of the four)
    • RXD: Choose from G35, G34, G13, or G16 (one of the four)
3. DIP Switch Switching Operation
Please follow the steps below to adjust the DIP switch configuration:
  1. Power Off
    Before adjusting the DIP switch, make sure the module is completely powered off to avoid hardware damage.
  2. Set the DIP Switch
    Select the corresponding pin mapping according to the host you are using.
DIP switch setting illustration 1
As shown in the image, the DIP switch is set as follows: ( Core (Basic) + Module GNSS )
PPS → G34
TXD → G34
RXD → G25
  1. Rewire and Power On
    After setting the DIP switch, reconnect the module and power it on for subsequent use.
