Product Guides
StamPLC
VAMeter
Unit RollerCAN
Display & Interaction
Tab5 Keyboard
Chain DualKey
Robotics & Maker Projects
Atom Printer
BalaC Plus
Faces Kit Gameboy
RoverC & JoyC
StampFly & Atom Joystick
Camera-Tool Tutorial
Firmware Compatibility
Camera-Tool is available for both TimerCAM and UnitCAM series products, UnitCAM requires the GROVE interface to be connected to a PC via a TTL-TO-USB adapter board before use.
Driver Installation
  1. Select the driver file that matches your operating system from the list below, download it, and extract it. You can also visit the FTDI Chip official website for additional FTDI driver versions.
Driver Name Download Link
Windows_Desktop_x64 Download
Windows_Desktop_x86_32 Download
Windows_Desktop_ARM Download
MacOS_Intel Download
MacOS_ARM64 Download
  1. Connect the device to your PC, open Device Manager, and install the FTDI driver (the screenshot below uses Windows 10 as an example). (Note: On some systems, you may need to install the driver twice for it to take effect. The unrecognized device is usually named M5Stack or USB Serial.)
Note for MacOS Users
For MacOS users before installing please check System Preferences - > Security & Privacy - > General - > Apps Allowed to be Downloaded from the Following Locations - > App Store and Approved Developer Options.
Software Introduction
Camera-Tool is used to control the Timer-CAM camera to take pictures, and currently supports both serial and WiFi connection modes.
Software Download
Currently only available for windows
Version Download
cameraToolsV1.5 Download
Burning Firmware
Open the host software, connect the device to the computer, select the corresponding port, click Burner to burn, wait for the pop-up window successful means that the burner is complete.
Wait for the pop-up window to be successful to indicate that the burner is complete. > Note | Do not click Connect before burning the firmware, otherwise it will occupy the port and cause failure of burning the firmware.
Serial Mode
In Serial Mode, the device is connected to the computer via USB and the Camera-Tool is used to access the serial port of the device/acquire images.
Note: Unit-CAM series, when using CameraTools, the image transfer interface is Grove interface. Please connect the TX and RX of Grove interface to PC via USB-TTL adapter board, and then select the corresponding port for connection.
Wi-Fi Mode
Connect the device to the port, click the Configure button, enter the Wi-Fi name and password, click Connect, the face will automatically switch to the HTTP tab Switch the mode to Wi-Fi-HTTP and display the image.
Taking pictures
The shooting menu can be expanded by clicking the Fold switch. The operation bar provides functions for Shooting, Time-lapse, and Setting the picture save path.
Parameter Adjustment
The Configuration menu on the left provides a series of image parameter settings for adjusting the imaging effect of the picture.
Mobile APP
In network mode, you can also use the mobile version of the APP to take pictures and view the monitoring.
Version Download
TimerCAM-App-Android v1.0 Download
