Product Guides
StamPLC
VAMeter
Unit RollerCAN
Display & Interaction
Tab5 Keyboard
Chain DualKey
Robotics & Maker Projects
Atom Printer
BalaC Plus
Faces Kit Gameboy
RoverC & JoyC
StampFly & Atom Joystick
RoverC & JoyC Remote Control
This tutorial demonstrates how to flash wireless control firmware to RoverC and JoyC, pair them, and perform basic control operations. The firmware in this tutorial is compatible with StickC / StickC-Plus / StickC-Plus2 main control devices. Please refer to the tutorials below and flash the firmware directly using M5Burner.
2. USB Driver Installation
  • Before flashing the firmware, you need to install the appropriate driver based on your main controller device.
For StickC / StickC-Plus
  1. Select the driver file that matches your operating system from the list below, download it, and extract it. You can also visit the FTDI Chip official website for additional FTDI driver versions.
Driver Name Download Link
Windows_Desktop_x64 Download
Windows_Desktop_x86_32 Download
Windows_Desktop_ARM Download
MacOS_Intel Download
MacOS_ARM64 Download
  1. Connect the device to your PC, open Device Manager, and install the FTDI driver (the screenshot below uses Windows 10 as an example). (Note: On some systems, you may need to install the driver twice for it to take effect. The unrecognized device is usually named M5Stack or USB Serial.)
For macOS users: Before installation, go to System Preferences -> Security & Privacy -> General -> and allow apps downloaded from App Store and identified developers.
For StickC-Plus2
Driver Installation Tip
Click the link below to download the driver matching your operating system. The CP34X driver package (for CH9102) should be extracted, and the appropriate installer (based on system architecture) should be run. If you encounter flashing errors (timeout or "Failed to write to target RAM"), try reinstalling the driver.
Driver Name Chip Download Link
3. Port Selection
Connect the device to your computer via USB. Once in download mode, select the corresponding device port in M5Burner.
4. Flashing Firmware
Flash the respective Master and Remote firmware to RoverC and JoyC.
5. Pairing
Switch the power of both RoverC and JoyC to ON. Turn on the StickC on RoverC first (starts in AP mode), then power on the StickC on JoyC.
Once the StickC on JoyC scans and detects RoverC, press and hold the middle button to connect. When the remote status appears on the screen, the connection is successful.
6. How to use
Operation Instructions
The left joystick controls movement, and the right joystick controls steering. Pressing the left/right joystick buttons controls the servo clamp (clamp/release). (Note: Clamping functionality is only supported by RoverC-Pro)
