Product Guides
StamPLC
VAMeter
Unit RollerCAN
Display & Interaction
Tab5 Keyboard
Chain DualKey
Robotics & Maker Projects
Atom Printer
BalaC Plus
Faces Kit Gameboy
RoverC & JoyC
StampFly & Atom Joystick
AtomS3R-M12 Volcengine Voice Assistant
Use Case
This tutorial will use the AtomS3R-M12 Volcengine Voice Assistant, flash the Volcengine Voice Assistant test firmware via M5Burner, and build your personal voice assistant application.
Please, according to your operating system, click the button below to download the corresponding M5Burner firmware burning tool, unzip it, and open the application.
Software Version Download Link
M5Burner_Windows Download
M5Burner_MacOS Download
M5Burner_Linux Download
2. Firmware Burning
  1. Double-click to open the Burner tool. In the left menu, select the device type AtomS3, then check the Only Official option at the top of the interface, and find the AtomS3R-M12 Volcengine Voice Assistant firmware to download.
  1. After connecting the device via USB, press and hold the reset button (for about 2 seconds) until the internal green LED lights up, then release. The device has now entered download mode, waiting for burning. The red indicator turns off after the button is released, confirming that the device is in download mode.
  1. In the Burner tool interface, click Burn. In the popup window, select the corresponding port for your device. Click Start, and wait for the burning to complete.
3. Hotspot Configuration
Use your phone to enable a 2.4 GHz hotspot, set the hotspot name to M5VolcRTC and the password to m5volcrtc. Once the device successfully connects to the network, voice interactions can begin.
4. Getting Started
After completing the above configuration, you can start the conversation. You can view real-time status and logs via the serial port (115200 bps).
