本章节介绍将 Unit AMeter 电流计集成至 Home Assistant 的配置方法与实操步骤。
i2c:
sda: GPIOXX
scl: GPIOXX
scan: true 这里的 GPIO 引脚会因为使用的主控设备不一而不同。比如使用 Atom Lite 作为主控:
i2c:
sda: GPIO26
scl: GPIO32 Unit AMeter 配置范例:
ads1115:
- address: 0x48
- platform: ads1115
multiplexer: "A0_A1"
gain: 0.256
sample_rate: 128
name: "Unit AMeter A0_A1 Ref"
update_interval: 10sAIN0 和 AIN1 两个通道,所以最多可以使用 3 个 multiplexer: "A0_A1"、"A0_GND"、"A1_GND";而此处测量电流,仅用到了 A0_A1 参与电流计算。Template Sensor 创建自定义数据:i2c_device:
address: 0x51
# Previous ads1115 declarations
- platform: template
unit_of_measurement: "A"
icon: "mdi:current-dc"
accuracy_decimals: 2
lambda: |-
float d = id(diff).state;
if (isnan(d)) return NAN;
const float PRESSURE_COEFF = 0.05f;
const uint8_t EEPROM_REG = 0xF8;
uint8_t calib[8];
uint16_t hope, actual;
if ( id(eeprom).read_register(EEPROM_REG, calib, 8) != i2c::ERROR_OK ) {
ESP_LOGD("ameter.sensor", "Failed to read from EEPROM..");
return NAN;
uint8_t xor_result = 0x00;
for (uint8_t i = 0; i < 5; i++) {
xor_result ^= calib[i];
if (xor_result != calib[5]) {
return NAN;
hope = (calib[1] << 8) | calib[2];
actual = (calib[3] << 8) | calib[4];
float calibration_ratio = (float)hope / actual;
ESP_LOGD("ameter.sensor", "Factory calibration factor: %f", calibration_ratio);
float ain = - d / PRESSURE_COEFF;
ain = ain * calibration_ratio;
return ain;gain 值,修改 lambda 表达式中 EEPROM_REG 读取地址:// In lambda expression
// remember to change the 'EEPROM_REG' if you changed the 'gain'
// for an example, when 'gain' is 0.256
const uint8_t EEPROM_REG = 0xF8;| ADS1115 Gain | EEPROM Data Register | Max Input Current (theory) |
| 6.144 | 0xD0 | - |
| 4.096 | 0xD8 | - |
| 2.048 | 0xE0 | - |
| 1.024 | 0xE8 | - |
| 0.512 | 0xF0 | 10 A |
| 0.256 | 0xF8 | 5 A |
推荐的 gain 值为 0.256,分辨率 0.3mA,仅能测量 AIN0 或 AIN1 其中一路,请勿将两路都接上输入。
当添加至 Dashboard 之后,您可以在 Home Assistant 中查看传感器数据。
