Unit ENV-Pro Sensor Home Assistant Integration
This section introduces the configuration methods and practical steps for integrating the Unit ENV-Pro environmental sensor into Home Assistant.
Since Unit ENV-Pro is an independent sensor platform, an additional controller (such as the Atom series, Stamp series, Stick series, Core/Basic series, etc.) is required to integrate it into Home Assistant. The above component utilizes the proprietary software BSEC2. The BSEC2 library can only be used after accepting its Software License Agreement. By enabling this component in your configuration, you explicitly agree to the terms of the BSEC license agreement. Please note that this license prohibits the distribution of any compiled firmware binary files containing this component.
Preparation
  1. Refer to the ESPHome official documentation: bme68x_bsec2
  2. Prepare a compatible controller (such as the Atom series, Stamp series, Stick series, Core/Basic series, etc.)
  3. Confirm the I2C pinout of the controller (pin definitions vary by device)
Configure Sensor
Enable the I²C component in the ESPHome configuration:
i2c:
  sda: GPIOXX
  scl: GPIOXX
  scan: true
The GPIO pins here will vary depending on the controller used. For example, using Atom Lite as the controller:
i2c:
  sda: GPIO26
  scl: GPIO32
Unit ENV-Pro Configuration Example
  • Component Declaration
yaml
1 2 3
bme68x_bsec2_i2c:
  address: 0x77
  model: bme688
  • Sensors
yaml
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47
text_sensor:
  - platform: bme68x_bsec2
    iaq_accuracy:
      name: "BME68x IAQ Accuracy"
  - platform: template
    name: "BME68x IAQ Classification"
    lambda: |-
      if ( int(id(iaq).state) <= 50) {
        return {"Excellent"};
      else if (int(id(iaq).state) >= 51 && int(id(iaq).state) <= 100) {
        return {"Good"};
      else if (int(id(iaq).state) >= 101 && int(id(iaq).state) <= 150) {
        return {"Lightly polluted"};
      else if (int(id(iaq).state) >= 151 && int(id(iaq).state) <= 200) {
        return {"Moderately polluted"};
      else if (int(id(iaq).state) >= 201 && int(id(iaq).state) <= 250) {
        return {"Heavily polluted"};
      else if (int(id(iaq).state) >= 251 && int(id(iaq).state) <= 350) {
        return {"Severely polluted"};
      else if (int(id(iaq).state) >= 351) {
        return {"Extremely polluted"};
      else {
        return {"error"};
    temperature:
    pressure:
    humidity:
    iaq:
    co2_equivalent:
      name: "CO2 Equivalent"
    breath_voc_equivalent:
      name: "Breath VOC Equivalent"
Due to the use of the BSEC2 library, the sensor's update_interval configuration option will be unavailable (the polling interval cannot be configured). Data is processed and published by the proprietary library.
Getting Started
  1. After completing the configuration and uploading, add the sensor to Home Assistant.
Video
