Unit NCIR Home Assistant Integration
This tutorial describes how to integrate the Unit NCIR single-point infrared thermometer sensor into Home Assistant to achieve non-contact temperature monitoring.
Environment Setup
  1. Install Home Assistant by following the official Home Assistant documentation.
  2. Install the ESPHome Device Builder add-on by following the official ESPHome documentation.
  3. Refer to the following resources:
Hardware Products
  • Unit NCIR
  • A compatible controller (such as an Atom, Stamp, Stick, Core, or Basic series device)
Unit NCIR requires a compatible controller to integrate with Home Assistant. Select the controller model and interface pins according to your project.
2. Modify Configuration
The I²C component needs to be enabled in the ESPHome configuration:
i2c:
  sda: GPIOXX
  scl: GPIOXX
  scan: true
The GPIO pins here will vary depending on the main controller used. For example, using Atom Lite as the controller:
i2c:
  sda: GPIO26
  scl: GPIO32
Unit NCIR Configuration Example:
yaml
1 2 3 4 5 6 7
  - platform: mlx90614
    ambient:
    object:
    update_interval: 10s
3. Getting Started
Once added to the Dashboard, you can view the sensor data in Home Assistant:
