Unit Watering Home Assistant Integration
Unit Watering is a capacitive soil moisture sensing and control Unit. It integrates a water pump and sensing electrodes to detect soil moisture and drive pumping, making it easy to implement moisture sensing and irrigation control in smart plant care scenarios. The electrodes use a capacitive design; compared to resistive probes, this helps avoid electrode corrosion in real use.
Unit Watering is only a standalone sensor platform. You need an additional main controller (Atom series, Stamp series, Stick series, Core/Basic series, etc.) to integrate it with Home Assistant.
Configure the sensor
The capacitive soil moisture sensor reports voltage/ADC readings, so you need to enable and configure the ADC component according to the controller you use:
# Example configuration entry
  - platform: adc
    pin: GPIOXX
    update_interval: 60s
For example, using Atom Lite:
  - platform: adc
    pin: GPIO32
Configure the water pump switch:
switch:
  - platform: gpio
    pin: GPIO26
This lets you control the pump on/off from the Home Assistant frontend.
Complete configuration example:
  - platform: adc
    pin: GPIO32
    attenuation: auto
    update_interval: 10s
  - platform: template
    lambda: |-
        return roundf( id(voltage).state * 1000.0f );
text_sensor:
    name: "Soil Moisture"
    icon: "mdi:water-percent"
    lambda: |-
        const int ADC_DRY       = 1550;  // Dry threshold
        const int ADC_WET       = 1450;  // Wet threshold
        if ( id(adc_reading).state >= ADC_DRY) {
          return {"Dry"};
        } else if ( id(adc_reading).state >= ADC_WET) {
          return {"Wet"};
          return {"Saturated"};
switch:
  - platform: gpio
    pin: GPIO26
    icon: "mdi:water-pump"
    restore_mode: RESTORE_DEFAULT_OFF
Here the template sensor can be adjusted based on actual readings to report soil moisture level using thresholds:
In general, the drier the soil, the higher the value; the wetter the soil, the lower the value. You can also create automations based on the sensor readings to control the pump for scheduled or moisture-based watering.
If you want to schedule on/off in ESPHome, refer to the time component.
For example, turn on the pump at 7:30 AM on weekdays, water for one minute, then turn it off:
time:
  - platform: homeassistant
    on_time:
      # Every morning on weekdays
      - seconds: 0
        minutes: 30
        hours: 7
        days_of_week: MON-FRI
        then:
          - switch.turn_on: water_pump
          - delay: 60s
          - switch.turn_off: water_pump
Add the sensor to Home Assistant
After configuration, you can view the sensor data in Home Assistant.
Video
