LLM630 Compute Kit - StackFlow API LLM Demo
StackFlow
StackFlow is an AI framework developed for the Module LLM and LLM630C Kit. This framework integrates AI algorithms such as speech, vision, and large language models. The LLM630 Compute Kit has StackFlow pre-installed by default. Users can use the LLM630 Compute Kit as an LLM compute server and access it via APIs for LLM inference.
1.Preparation
  • Refer to the LLM630 Compute Kit - Config tutorial to learn how to configure network and file transfers on the LLM630 Compute Kit, and obtain the device’s IP address.
2.Client Program
Download the client test script, ensuring that the PC and the LLM630 Compute Kit are on the same network segment. Run the script, passing in the device IP address as a parameter.
python .\llm-qwen2.5-1B.py --host 192.168.20.24
Setup LLM...
Setup LLM finished.
import socket
import json
import argparse
    sock.connect((host, port))
    return sock
def send_json(sock, data):
def receive_response(sock):
    response = ''
    while True:
        response += part
        if '\n' in response:
            break
    return response.strip()
def close_connection(sock):
    if sock:
        sock.close()
def create_init_data():
    return {
        "request_id": "llm_001",
        "work_id": "llm",
        "action": "setup",
        "object": "llm.setup",
        "data": {
            "model": "qwen2.5-0.5B-prefill-20e",
            "response_format": "llm.utf-8.stream",
            "input": "llm.utf-8.stream",
            "enoutput": True,
            "max_token_len": 1023,
            "prompt": "You are a knowledgeable assistant capable of answering various questions and providing information."
def parse_setup_response(response_data, sent_request_id):
    request_id = response_data.get('request_id')
    if request_id != sent_request_id:
        print(f"Request ID mismatch: sent {sent_request_id}, received {request_id}")
        return None
        return None
def setup(sock, init_data):
    send_json(sock, init_data)
    return parse_setup_response(response_data, sent_request_id)
    send_json(sock, deinit_data)
    print("Exit Response:", response_data)
        return None
    return response_data.get('data')
def main(host, port):
    sock = create_tcp_connection(host, port)
    try:
        print("Setup LLM...")
        init_data = create_init_data()
        llm_work_id = setup(sock, init_data)
        print("Setup LLM finished.")
        while True:
            user_input = input("Enter your message (or 'exit' to quit): ")
            if user_input.lower() == 'exit':
                break
            send_json(sock, {
                "work_id": llm_work_id,
                "action": "inference",
                "object": "llm.utf-8.stream",
                "data": {
                    "delta": user_input,
                    "index": 0,
                    "finish": True
            while True:
                data = parse_inference_response(response_data)
                if data is None:
                    break
                delta = data.get('delta')
                finish = data.get('finish')
                print(delta, end='', flush=True)
                if finish:
                    print()
                    break
        exit_session(sock, {
            "request_id": "llm_exit",
            "action": "exit"
    finally:
if __name__ == "__main__":
    parser = argparse.ArgumentParser(description='TCP Client to send JSON data.')
    parser.add_argument('--host', type=str, default='localhost', help='Server hostname (default: localhost)')
    parser.add_argument('--port', type=int, default=10001, help='Server port (default: 10001)')
    args = parser.parse_args()
    main(args.host, args.port)
3.Start Interaction
Enter your message (or 'exit' to quit): who are you?
I am a large language model created by Alibaba Cloud. I am called Qwen. I am designed to assist with a wide range of tasks, from simple questions to complex problem-solving. I can answer a wide variety of questions and provide information on various topics. I can also help with language translation, writing, and more. My goal is to be a helpful and informative assistant to those who use me.
